Drivetrain Revolution Mini Works Camshaft..... taking orders
Old Jan 13, 2009 | 04:44 PM
  #326
big howe's Avatar
big howe
Originally Posted by soccerbummer1104
i did, and it fixes the problem most of the time. When i ran 87 octane i actually had it shudder to almost stalling once, but now i only use 93 octane. every now and then the car starts vibrating a little harshly, but most of the rumble is just noise now. Now it mainly idles high some times on cold starts :P, to the point that i can smoothly let out the clutch without hardly touching the gas and it wont yoyo or stall. Once its warmed up though most of my issues disappear.
87 octane?
Old Jan 13, 2009 | 05:22 PM
  #327
MUShadd's Avatar
MUShadd
mine shutters now from time to time with a stock cam. it lopes to the point it sounds like its going to quit, but never does, either pulls itself out of it, or i can tap the gas if i want it to straighten up immediately. oddly enough dropping from 93 to 89 octane fixes the problem. from what ive read, its a common stock problem....so i'm pretty used to some shuttering.....sometimes i like to pretend im in an old muscle car as it shutters at a traffic light or drive thru lol
Old Jan 13, 2009 | 06:02 PM
  #328
drsilvermini's Avatar
drsilvermini
Mine does the same exact thing, I haven't tried switching gas octane though, I feel bad putting lower than 93 even though it will run on lower octane. I haven't tried pretending I'm in an old muscle car, maybe I should try that...
Old Jan 13, 2009 | 07:12 PM
  #329
oxtox's Avatar
oxtox
i have found variation with this problem at the same octane (93)....so i think some brands may be better than others (?higher alcohol content in some winter gas?)? i know bmw's are pretty notorious for rough idles with cold starts, so it could be something that bone stock mini's experience as well? i don't know, i only had a bone stock mini for about 2 weeks
my point is that this may not be related to the cam at all
Old Jan 13, 2009 | 08:48 PM
  #330
davisflyer's Avatar
davisflyer
I've had my cam for 4 months now and have not noticed any difference in the idle, cold or warm.
Old Feb 2, 2009 | 06:34 AM
  #331
itonano's Avatar
itonano
Hi there, i want to buy a RMW cam, im from Europe, how can i buy it?
thanks
Old Feb 2, 2009 | 06:48 AM
  #332
Revolution Mini Works's Avatar
thanks
if you want the Newman cam it's cheaper to buy direct from Newman if in Europe
if you want our proprietary one, you will need our head/header and tune for it to work properly
Old Feb 2, 2009 | 07:06 AM
  #333
itonano's Avatar
itonano
Hi there, ok thanks, but at this moment i won't change the head, i will change the header and put the cam, is that fine too?
and how much would be the head/header and cam from you?
thanks
Old Feb 2, 2009 | 07:48 AM
  #334
thanks
you can contact me through email and I will go over your wants/needs with your car and help you get the right cam for the application
jan@revolutionmini.com
Old Feb 2, 2009 | 07:51 AM
  #335
skillet's Avatar
skillet
I'm a little Confused... I thought you only had one cam...
If so, I thought your cam worked just fine with the stock head and tune...but obviously better with your head and tune.
or, do you have 2 cams? One being the Newman cam and one being a custom ground cam? If you could shed some light, Jan, I would appreciate it.
Old Feb 2, 2009 | 07:54 AM
  #336
I have 2 other cams already and 2 more on the way
these are more extreme cams and probably not for street use
Old Feb 2, 2009 | 11:15 AM
  #337
Luys's Avatar
Luys
Can you explain to us, what are the 2 other cams? for which engines? BTW I bought from you the cam but I don't know if it works well with the stock head? I asked this qus cause you said you need to RMW head for itonano!
Old Feb 2, 2009 | 12:47 PM
  #338
skillet's Avatar
skillet
Thanks, Jan!
Old Feb 2, 2009 | 02:22 PM
  #339
you have the proper cam for your application
Old Feb 2, 2009 | 02:30 PM
  #340
PGT's Avatar
PGT
so, I got an off-the-shelf cam for my RMW head (i.e. the wrong app?)
Old Feb 2, 2009 | 02:39 PM
  #341
yes, you got the best available for your situation, it was the best at that time of all of the cams we tested, and I tested over 8 different cam grinds
What we have now are not really street cams nor just for the 1.6L
as you well know things evolve, Honda's just didn't start producing 300whp overnight either. It was and still is a progression of sorts.
I doubt it ever really ends
kinda like this thread
Old Feb 2, 2009 | 10:52 PM
  #342
El_Griton's Avatar
El_Griton
your my boy blue!
Old Feb 2, 2009 | 10:55 PM
  #343
silversmoke06's Avatar
silversmoke06
Guess this means im gonna be buying a new cam.
I guess boat isent the only thing that has a break out another thousand sort of situation.
I aught to just get a shotgun and blow the wallet off my *** while im ahead.
Old Feb 3, 2009 | 06:32 AM
  #344
it's never going to beat your Vette............unless you go TVS
Old Feb 3, 2009 | 07:21 AM
  #345
itonano's Avatar
itonano
Hi RMW, i sended to you an email but didn't answer, i about the cam with my stock head
thanks
Old Feb 3, 2009 | 07:23 AM
  #346
thanks
it works
Old Feb 3, 2009 | 07:48 AM
  #347
itonano's Avatar
itonano
ok email sent
Old Feb 3, 2009 | 01:37 PM
  #348
silversmoke06
I have the cam with the stock head. it helps alot.
If you need a ride to prove it and your local Pm me ill make it happen.
Jan theres worse things than going tvs i was actualy gonna call you.
I know we talked about a head for a second but gotta set up a plan here. Ill email you later today.
Old Feb 4, 2009 | 12:02 AM
  #349
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
Looks like I'll have to buy a few minis to try all of your different setups
Old Feb 4, 2009 | 12:12 AM
  #350
muladesigns1's Avatar
muladesigns1
Ok..... it has been slow getting geared up for this as the demand has been through the roof. We are trying to fill orders as fast as possible. IF you have not received your cam please put your name on this list so we can get it to you as fast as humanly possible. I have another 30 coming
Price is $400 + $15 shipping in the USA
Yes it works great on stock heads.....
expect around 10whp and 8-10ft lbs of torque
any chances of the price coming down to a respectable amount?
10 wHP. for $400 seems like not much bang for the buck.
