No, it doesn't shrink, but becomes less pliable. It also will smoke a little the first time you run the engine, but all lagging does that the first time it gets hot.
Thanks. Just trying to figure out how much the rod moves to the right or left. That left pad is under the linkage with the wire tight. Just hope the left metal block on the linkage doesn't catch on the wire. Assume I will get a check engine light if something is wrong?
Not much, at most a half inch. The flapper is fully open in the photo.
I hope so too on the check engine light. I have to do my water pump now so I won't be able to check while driving. I suppose if it doesn't drive like it used to under acceleration than that's a clue.
Not yet. Still putting a few more parts together before the test drive! I did install the OEM shield. I kind of like just having it on since I have a CF overlay on the valve cover.
Leave it with the factory then. I'm going to keep mine with just the factory cover.
