Drivetrain So much debate about intercoolers and intakes
Old May 11, 2008 | 08:32 PM
  #51
Malcon's Avatar
Malcon
Originally Posted by Revolution Mini Works
if it makes you feel better, I can charge you 12K
haha. Its good your looking out for the consumer
haha thats funny
-Malcon
Old May 12, 2008 | 08:57 AM
  #52
Luys's Avatar
Luys
Jan what kind of inetercooler you will produce classic or Top mount Intercooler (DFIC2)
Old May 12, 2008 | 09:00 AM
  #53
Revolution Mini Works's Avatar
a Water to Air
the DFIC's don't work in our applications
Old May 12, 2008 | 09:12 AM
  #54
00zero's Avatar
00zero
Jan what are your thoughts on the Dinan intake?
I want a JCW but i really don't want to wire it up ect... and performing a flapectomy and not worring about the wiring seems link kind of a waste for the cost.
any input?
-Jonathan
Old May 12, 2008 | 09:19 AM
  #55
any input?
-Jonathan
I like the "factory" style ones best, they shield much better from the heat
Old May 12, 2008 | 09:21 AM
  #56
eager2own's Avatar
eager2own
Is that cabrio running pure stock JCW intake (or did it have the flap removed)?
(just curious -- I realize this is an inconsequential detail in light of the bigger issues addressed in this thread. . . thanks)
Old May 12, 2008 | 09:22 AM
  #57
stock JCW intake
Old May 12, 2008 | 10:00 AM
  #58
Longboard Mini's Avatar
Longboard Mini
I agree which is why I'm running the Voltage intake. The cover is the same size and shape as stock but uses a real velocity stack and a great filter. It maintains the stock front fresh air tube and is open in the back (cold air from cowl) and is made from hand laid fiberglass. Simple and as close to stock as they come.
Old May 12, 2008 | 10:04 AM
  #59
PGT's Avatar
PGT
the Dinan is nice and a good alternative to the JCW but the filter is pricey. Perhaps the Dinan box + an Amsoil filter = a good alternative to the JCW. That S2 uses a standard UNI filter which is easy to clean
Old May 12, 2008 | 10:59 AM
  #60
BlimeyCabrio's Avatar
BlimeyCabrio
+1
Dinan box (not filter) is functionally equivalent to JCW without the flap - same type of material & sealing, etc. A cheaper way to get something that works just like the JCW w/flapectomy. I started with a Dinan, but went to JCW (w/AMSoil) for low-rpm throttle noise abatement. Love the JCW.
Old May 12, 2008 | 12:24 PM
  #61
minimusprime's Avatar
minimusprime
I was @ the track this last weekend with a stock IC and a scangaugeII.
My IAT's were pretty stable through out the day. Temps were in the low 80's iirc. Typical IAT's on the straights were 145-150. There was a point where I was trying to drop down into 2nd for a corner or two where I shouldn't have been and that shot IAT's up to about 180-190... that wasn't so fun.
So imo the stock intercooler is going to cool well enough to put 210hp down while beating the crap out of your car on the track.
Old May 12, 2008 | 12:27 PM
  #62
Guest's Avatar
Guest
It took my poundings quite well at 231 whp. The issue of heat is only really an issue if you spin your car up past about 7400 RPM's. I was going all the way to 8200 (WAY out of efficiency range), hence my intake temps being 60-75 above ambient.
Old May 23, 2008 | 08:45 PM
  #63
Haggardsk8er's Avatar
Haggardsk8er
Do you loose that sweet sweet SC whine??
And Is that a complete custom RMW Fab IC or something u can buy thats been modded with bigger end tanks? Never seen any of them like that one...
Old May 23, 2008 | 09:27 PM
  #64
Guest's Avatar
Guest
It's custom fab, and no the rotrex doesn't whine .
Old May 23, 2008 | 10:12 PM
  #65
Haggardsk8er
I tried Googling that Voltage S3r intake too... to no avail... Got a link?
Old May 23, 2008 | 10:30 PM
  #66
ninjlao's Avatar
ninjlao
Ninja Mini
http://www.voltageproductsonline.com/
Old May 23, 2008 | 10:31 PM
  #67
Longboard Mini
Trust me when I say that after one drive in my car you won't care that the whine is gone. This car sounds amazing.
Longboard
Old May 23, 2008 | 11:48 PM
  #68
batrugger's Avatar
batrugger
I used to have the Alta v.2 and I thought it worked great. At the track after a 20 min session, and at dyno's, you could lay your hand on the outlet side and it would be cool. Can't say the same for people who had the one from the alpha numeric tuner. The only reason it was removed was because of California CARB worries and we went back to the stocker.
Old May 24, 2008 | 09:37 AM
  #69
Haggardsk8er
Longboard
Hmm... Def gonna have to take you up on that!!
One drive?? or a ride
Old May 24, 2008 | 09:45 AM
  #70
Haggardsk8er
Wow built in velocity stack! Pretty nice!!!
I like the pedals they do too!!!
Old May 24, 2008 | 11:57 AM
  #71
Longboard Mini
I have a set of the pedals. Really nice and the best deal around for pedals like these.
Longboard
Old May 24, 2008 | 12:01 PM
  #72
Haggardsk8er
Longboard
Custom paint too... Im goin for orange so the stock one might work out!!
Add this one to the list!!!
Do I get a discount for mentioning the 300x model? haha
Old May 24, 2008 | 07:47 PM
  #73
Haggardsk8er
You know that old trick muscle car guys used to use... "paint the underside of your intake white and than the top black cause it'll help with heat issues..."
What if you did that with the IC??? Think I might try that... Thoughts???
Its just paint if it dont work after all...
Old May 24, 2008 | 08:03 PM
  #74
Silent1's Avatar
Silent1
What's the theory behind painting the top black? Why not paint it white as well?
Old May 24, 2008 | 08:15 PM
  #75
Haggardsk8er
Well I'm not certain on how legistical it is or whatnot... but i know muscle car guys do it all the time... not astetically pleasing to the eye but works...
