Drivetrain Does anyone cleans their own Alta CAI?
Old May 2, 2008 | 06:51 PM
Eddie818's Avatar
Eddie818
hi everyone,
i think most of us own a Alta CAI for our MCS.
Just wondering does anyone cleans the intake and how?
In order to maintain the intake quality, i think cleaning is needed.
Does anyone knows how by ourself?
I also realized that Alta CAI is very oily.
Wouldnt the engine sucking oil instead of air in?
Old May 2, 2008 | 07:07 PM
bad venge's Avatar
bad venge
Are you talking FILTER ???
Old May 2, 2008 | 07:16 PM
ENGINE 58's Avatar
ENGINE 58
i cleaned my alta intake filter today its easy with the uni filter cleaning kit and i will be able to clean it at least three more times with it.
Old May 2, 2008 | 07:29 PM
chili_red07's Avatar
chili_red07
I cleans my own intake too.
heres the link to the cleaning kit
COR BLMY's Avatar
COR BLMY
Alta does carry the foam filter cleaning kit.
Also any motorcycle parts, even dealer will have what you need.("no toil" is earth friendly)
Don't get a kit for fabric filter (K&N)
Old May 3, 2008 | 03:00 AM
Eddie818's Avatar
Eddie818
Thank you everyone, and guess i will buy the foam cleaning kit from alta.
Old May 3, 2008 | 07:36 AM
jonnieoh's Avatar
jonnieoh
It is very easy.
Remove the red foam filter from the car.
Spray the cleaning spray onto the filter.
Hose off the filter from inside and out, removing all the old oil and cleaner.
Let it sit out in the sun and/or breeze for a couple hours. Once it is completely dry, both inside and out, spray it with the oil from the kit, and lightly massage it in. I find that if you put the filter in a plastic shopping bag after spraying it, you can then massage the oil in, and also install it back in the car, without getting your hands all oily. You can hold the filter on with one hand, (with the bag still around the filter), then with the other, tighten the clamp with a screwdriver.
Once tight, (not too tight; because if you over tighten the clamp, the filter will be squeezed off), then simply pull off the plastic bag.
Voila! you're done.
Old May 3, 2008 | 01:33 PM
ALTA_Ken's Avatar
ALTA_Ken
Thanks guys and gals! Excellent points. For sure if you are in a pinch use what is available at a local ATV store for cleaning foam filters.
Let us know if we can help out in the future!
Old May 11, 2008 | 06:37 PM
Lost's Avatar
Lost
+1
No Toil is great and a kit will last forever. Its also a nice plus that its "earth friendly"...
Old May 11, 2008 | 06:52 PM
Kirkland's Avatar
Kirkland
Clean the thing outside because the cleaner smells more potent than napalm.
Old May 12, 2008 | 11:20 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Excellent point! Protect the brain!
patsum
26
May 29, 2021 06:29 PM
bahman
Nov 15, 2019 05:45 AM
rtk90
Aug 29, 2019 09:08 AM
Mb460
Sep 14, 2015 05:50 AM
Emnotek
Sep 11, 2015 04:16 PM
