Drivetrain Turbo Manifold build...
Old Feb 12, 2009 | 09:55 PM
  #51
Trickle X's Avatar
Trickle X
Mike,
Me too....Let me know when you have your ecu tuning sorted, as I may be a good candidate possibly.
Thanks!
Old Feb 16, 2009 | 02:53 PM
  #52
Trickle X's Avatar
Trickle X
finally got around to pix...now back to work...
Old Feb 16, 2009 | 04:01 PM
  #53
soccerbummer1104's Avatar
soccerbummer1104
i see no pics :(
Old May 26, 2009 | 09:33 PM
  #54
Trickle X's Avatar
Trickle X
Took a week off work and did nothing but work on this for 8 days straight from 3pm till 7am until it was finished. I have to take more pix of everything together, but you get the gist. I fired it up at 7am on Tues morning and only have a few small issues to adjust before a temp tune and roadtest. Hope you enjoy, as there is not allot showing how much thought and design went into this from the pix, I am just happy I knocked it all out one very long week. I must say thanks to my buisness partner Tom for helping and adding allot of the creativity in the design, I let him run with some of it, as I just kept the welding table hot.
Old May 26, 2009 | 10:10 PM
  #55
cartar452's Avatar
cartar452
Old May 27, 2009 | 07:28 AM
  #56
checkmate2006's Avatar
checkmate2006
Woohooo Trickle finally got it done. Just checked out the pics on your photobucket and the intercooler plumbing is pretty trick. I like the way you went through that one factory mount for the cold side of the intercooler. I really like the special touch with the skull in the front bumper support..... was it one of those ADD episodes while working.
Old May 27, 2009 | 07:30 AM
  #57
cartar452's Avatar
cartar452
Originally Posted by checkmate2006
Woohooo Trickle finally got it done I am looking forward to seeing pics
Check the first post
Old May 27, 2009 | 07:42 AM
  #58
checkmate2006
I checked his photobucket and thanks Cartar
Old May 27, 2009 | 08:23 AM
  #59
iwashmycar's Avatar
iwashmycar
Originally Posted by cartar452
Old May 27, 2009 | 10:29 AM
  #60
Some Guy's Avatar
Some Guy
I LOVE how you used the bumper support as part of the piping, that is just so creative.
Old May 27, 2009 | 01:17 PM
  #61
Longboard Mini's Avatar
Longboard Mini
Really really nice job Trickle . I love how simple you "made" things look. I'm sure there was a lot of thought, effort and hard work getting to this point.
Again Man,
Congratulations as it looks awesome
Longboard
Old May 28, 2009 | 07:55 AM
  #62
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Let this baby breath FIRE!!!
Old May 28, 2009 | 03:53 PM
  #63
Mini-Morgan's Avatar
Mini-Morgan
Congrats Cole! Really impressed with all the work you are going to yourself! Top Work! Really has come a long way from the old Twurbo kit a couple of years back. Look forward to seeing the final tune and rolling road.
Old May 28, 2009 | 04:36 PM
  #64
oxtox's Avatar
oxtox
so bummed i will miss you on the 10th
at least i can say i was the car tuned before yours (i'm last on the 9th). i'm guessing chili_mini_pa will be going turbo within a year of seeing your ride (he's after you on the 10th). congrats on all your hard work and +1 on waiting to see the dyno graph
Old May 28, 2009 | 06:13 PM
  #65
Trickle X's Avatar
Trickle X
Thanks guys...
I am running into a few snags....for one my starter died, was making some awful noise, had me going back over the turbo looking for it till it snapped and died, then the car sounded fantastic until I shut it down and it wouldnt restart...lol Got a replacement starter today, but it wouldnt fit as it ended up being one for an auto. Have another one coming, but prolly wont be here til monday. I snapped off the oil port for the turbo removing the top start bolt, so I had to pull my oil filter housing back out and will have to re-weld that. Now on to my biggest snag....my FX600 CM clutch wont dis-engage. I can not get it into gear while running. I went back and perused my pix from when i installed in 1.5 years ago, all looks well, but i could either possibly have the plates in backwards(has happened to me b4 at 3am on an audi TT) or I could need to re-bleed out my new slave cylinder to get more pressure on it. That is going to be the caviet to making it to the tune. Everything else is fine so-far....
Old May 29, 2009 | 04:56 AM
  #66
Mini-Morgan
I am finding similar problems with my FX400 at the moment. Hard to change gear sometimes and when you stop, all of a sudden you get a jult like the clutch starts to rub and picks up the slack in the transmission.
Old May 29, 2009 | 07:35 AM
  #67
Haggardsk8er's Avatar
Haggardsk8er
Hey Cole sick job on finishing up the manifold!! And very ingenious on the IC piping layout using all aspects of the bumper and crash beams... Looking forward to seeing it all with the bumper and hood down!!
As far as the clutch issue... Sound exactly like what we're going thru with Sushi's car... Only we just decided to pull the trans last night. More than likely a slave issue as they are known to be bad freom the dealer. Installed a new clutch and pressure plate none the less and even throwout bearing... Triple check that slave before pulling your trans, unless your just bored and forgot what it looks like in there
Again, great job on the manifold and piping!!!
Old Jun 3, 2009 | 06:32 AM
  #68
Trickle X's Avatar
Trickle X
ok....I am now having a starter issue...it will not disengage from the flywheel. It is the alum CM flywheel. I measured the distance from the block to the gear ring and have 28.5mm, unfortunely I can not find in any documentation what the distance should be. I measured the distance on the starter gear while disengaged and it is 26mm, so it has 2.5mm of clearance when it should be disengaged. It is hanging up on the flywheel ring and not retracting and burning up the starter (went through 2). I may space the starter out a few mm to see if this resolves this, but does anyone or can anyone take a measurement of the flywheel ring to the block? If not, I will have to pull the transmission and send the flywheel back to CM to inspect, which will put me out of the tune next week for sure. I may just push start it thought to get it there, but it makes it a real pia to finish troubleshooting the rest of the car....
Old Jun 3, 2009 | 09:52 AM
  #69
herbie hind's Avatar
herbie hind
pm kheuvo he may know or have one apart .
Old Aug 5, 2009 | 09:48 PM
  #70
cartar452's Avatar
cartar452
Any updates?
Old Aug 6, 2009 | 12:33 AM
  #71
user 7082082's Avatar
user 7082082
Great work man. I love how you routed the IC piping. Very clean.
Old Aug 6, 2009 | 09:30 PM
  #72
Trickle X's Avatar
Trickle X
Any updates?
Clutch Masters sent me a new flywheel, I have installed it and the engine and tranny are back in the car and that is about it. I hope to get some time this weekend to finish hooking everything back up and testing the starter and new flywheel. I've just been to busy working on everyone else's stuff to finish anything of my own. But soon...real soon!!
Old Jan 20, 2010 | 01:18 PM
  #73
cartar452's Avatar
cartar452
Did you ever get this up and running?
Old Jul 26, 2010 | 07:48 PM
  #74
Trickle X's Avatar
Trickle X
I am very proud to report and on my Bday at no-less, this BEAST is running, and running better than ever. It drives 10x better then it ever did when twin-charged. It is super smooth, and faster than I ever imagined it would be. I am only boosting to 16psi, currently, but it is easily putting down more power than it did twin-charge running at 27 psi. I haven't gone WOT yet, just 50%, until I get a few more miles on the new engine and I make sure no oil/coolant/boost/hydraulic lines aren't popping off, nor anything else that I may of missed since I have built and tore it down at least 5 times with my prior clutch disengaging issues.
I just have a few things I need to sort out as every once and a while I go into limp mode if I give it too much throttle from low rpm.
I am one happy man!
Old Jul 26, 2010 | 08:39 PM
  #75
kcle730's Avatar
kcle730
Congrats!, glad to hear this beast is running!
