Drivetrain K&N Apollo 57A-6037 Air Intake for R56 S
Old Apr 18, 2008 | 10:12 PM
mr_r56's Avatar
mr_r56
Hey,
I got an email from K&N the other day about a new Intake for the R56 Cooper S.
Details are as follows:
K&N Apollo Cold Air Induction Systems incorporate a washable/reusable K&N High-Flow Air Filter within a protective shell. They come with custom mounting hardware to fit specific vehicle applications. The Apollo's shell reduces heat build-up and feeds cool air into your engine, resulting in improved volumetric efficiency and increased power gains. Apollo Cold Air Induction Systems allow for updating your vehicle's intake system while retaining a closed environment.
57A-6037 Product Specifications
Product Style: 57i Series International Kits
CARB Exempt: No
Weight: 3.7 lb (1.7 kg)
Product Box Length: 10 in (254 mm)
Product Box Width: 10 in (254 mm)
Product Box Height: 10 in (254 mm)
Link: http://www.knfilters.com/search/prod...?Prod=57A-6037
Old Jul 29, 2008 | 01:29 PM
seebobgo's Avatar
seebobgo
Looks like it would work.
Old Jul 29, 2008 | 04:31 PM
bearcat245's Avatar
bearcat245
I would like to see a picture of it installed and hear how it sounds.
The cost is $239 and change.
Old Jul 30, 2008 | 07:41 AM
KyleJ's Avatar
KyleJ
Fig #22 on their instruction sheet PDF on that page makes it look like air would get constricted in that tube the way it kinks doing a U-turn just before the filter. The pictures make it hard to tell how harsh that bend is.
One distinct difference with this design is that it is utilizing only the factory air tube to take air in from just behind the grill and not any hot air in the engine bay itself. I can't see it being as loud as the intakes that are more like the DDM Street or Alta. That's a lot of twisting tubes for air to flow through.
Old Jul 30, 2008 | 02:59 PM
bearcat245's Avatar
bearcat245
I see what you mean. Not looking efficient for smooth air flow. For the price I think the Alta is a cleaner system, but I am not sure it's the way to go. Listened to a sound bit of Alta and was not impressed.
Going to re-listen to see if the setup might have been the cause of it sounding whinny.
Old Mar 9, 2009 | 04:17 PM
vrum_rum's Avatar
vrum_rum
Just a general question related to K&N replacement air filter:
Anyone out there having problem of engine running too lean with a replacement K&N air filter? I have a replacement filter (K&N #33-2936) in my 2008 Cooper S (manual trans); the engine check light comes on every several thousands of miles. The dealer would clear all the faults in the ECU under the warranty (of course they did not know of the K&N filter in the Cooper!). My guess of the engine running lean was based on my experience on other vehicles such as Ford and Toyota. If indeed a problem, anyone know of a work around solution, eg. a device that allows me to clear the engine faults myself?
Thanks,
Old Mar 9, 2009 | 09:47 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
I like my Scan Gauge
http://www.scangauge.com/products/
I can scan and clear codes while driving.
Old Mar 10, 2009 | 08:40 AM
vrum_rum's Avatar
vrum_rum
Thanks so much. I'll check it out.
Old Mar 10, 2009 | 12:56 PM
vrum_rum's Avatar
vrum_rum
Hi th3118:
Could you give me some info./tips on the ECU whereabout on the car? By the way, the ScanGauge II sounded as if it would be a fantastic tool; I already placed an order for one.
Thanks so much.
chrisx18240
26
Mar 16, 2022 09:56 AM
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
theblackfalcon
Aug 26, 2015 09:18 AM
