Drivetrain Intake Modification?
I picked up a promini intake for my girls 05 MCSCa a few months ago. It wasn't my #1 choice for intake but I got it brand new off ebay for $31 (shipped), can't beat that
. Anyways since it is not a closed box, just the metal shield, I wanted to know if anyone has cut to make a larger hole where the cold air goes into the stock box too increase colder air and air flow into the filter? Are there any draw backs to this?
If I understand your question right, I think MiniMadness has the setup for you: http://www.mini-madness.com/index.as...ROD&ProdID=174
I have their CAI and this replacement cowl that opens an intake duct at the rear of the engine compartment for cooler airflow. I like it, and have had no problems... except for the permagrin from hearing my supercharger spooling up clearer!
good luck!
good luck!
good luck!
good luck!
That's exactly what I was referring to, so you haven't had any problems with sucking in any rain water or anything like that?
good luck!
good luck!
I have the same intake and have cut the cowl. Louder whine.
I have not noticed any problems with water.
A number of other intake systems modify or remove the cowl wall - similar to what you've indicated an interest in. I cut the cowl wall for a intake somewhat similar to yours in the past and never had any problems with water/rain (you can do the modification yourself, no real need to order one which is already modified unless you are interested in keep your original intact - I used a dremel and cut-off wheel). You will hear additional supercharger whine once done, but some may argue it's more music than whine
Back in my old Toyota Tacoma days there was a mod called the "Deck Plate" mod...Comes with a screw on lid in case you want to quiet things down for a road trip or whatever. Pick up at any boat store for a few $$..
patsum
26
May 29, 2021 06:29 PM
COOPT UP
Sep 11, 2015 04:59 AM
