Drivetrain maf sensor cleaning
Old Mar 10, 2008 | 07:35 PM
ENGINE 58's Avatar
ENGINE 58
maf sensor cleaning
anybody cleaned there maf sensor after getting filter oil on it? if you have can you post up the procedure you used to clean it and what product you used as well . also how the car performed before and after the cleaning. if you can give signs of what to look and feel for when the sensor is dirty. any info on the subject will help. thank you nammers.
Old Mar 10, 2008 | 07:36 PM
ENGINE 58's Avatar
ENGINE 58
i think this could help those of us with after market intakes and homemade intakes as well.
Old Mar 10, 2008 | 08:58 PM
ACEkraut11's Avatar
ACEkraut11
I havent done it on my MINI but I have done it on my 94 Mazda B4000 pick-up. NAPA sells specific MAF sensor cleaner. On my truck the procedure is to disconnect the battery, clean the sensor, reassemble the sensor, hook up the battery and off you go. On my truck the battery must be disconnected about 20 minutes so that the computer can "forget" what it has learned and reset itself, reprogramming itself to how the sensor reads now that it is clean again.
Old Mar 10, 2008 | 09:06 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
I have used this:
Same procedure as ACEkraut11, never really noticed a difference.
Old Mar 10, 2008 | 09:16 PM
ENGINE 58's Avatar
ENGINE 58
thank you guys.
Old Mar 10, 2008 | 09:26 PM
ENGINE 58's Avatar
ENGINE 58
th3118- so there was no difference after cleaning the maf. i was wondering if a dirty maf could have caused a cel to come on. what was the reason for cleaning yours did you have any oil on it? i have the homemade cai with a big foam filter. i was thinking that the boost from the alta pnp might have sucked in some oil on the maf and cause the cel i was getting. any thoughts on this?
Old Mar 10, 2008 | 09:37 PM
ACEkraut11's Avatar
ACEkraut11
Big difference on my truck but there was a lot of carbon built up on it, no oil.
Old Mar 11, 2008 | 07:20 AM
th3118's Avatar
th3118
I run a Alta drop in flat filter when I auto-x in stock class. It was soaked in oil when it arrived, used paper towels to mat most of it off, but was still worried about the MAF. It had a very light oil film on it, so I cleaned it.
Maybe unnecessary, but it was easy to do.
Old Mar 11, 2008 | 11:04 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Never hurts.
But yes always remove the excess oil if possible during filter installation!
Motown
Apr 20, 2018 09:31 AM
HaveATank
Sep 4, 2015 08:04 AM
absolutcamper
Aug 24, 2015 12:27 PM
Marktheman
Aug 23, 2015 11:45 AM
M7Speed
Aug 6, 2015 01:48 PM
