Drivetrain Helix 17% + JCW Belt + Stock Crank Pulley
Old Mar 9, 2008 | 01:16 AM
Marwan's Avatar
Marwan
Hello guys. I'm changing my stuck SC pulley to helix 17% one, as recommended, I'm changing the belt to the JCW one. Does this ensure no slippage? Shall I get a smaller belt?
Old Mar 9, 2008 | 08:02 AM
norm03s's Avatar
norm03s
I would run a smaller belt and do on my helix 17%.
Old Mar 9, 2008 | 08:04 AM
Marwan's Avatar
Marwan
it would slip?
Old Mar 9, 2008 | 08:42 AM
sandini's Avatar
sandini
I just participated in Jans RMW tune Friday and the recommended belt size for the 17% pulley slipped on the dyno . Napa # 060535 works great
Old Mar 9, 2008 | 08:58 AM
Jhud's Avatar
Jhud
ive read somewhere ( possibly alta website ) that with a 15% pulley and a 2% crank you can use stock belt. is this the IDEAL belt or will the stock belt just work.?
Old Mar 9, 2008 | 11:43 PM
Marwan's Avatar
Marwan
Well, Jan is the one who recommended JCW belt on the 17% pulley.
Old Mar 10, 2008 | 07:20 AM
Revolution Mini Works's Avatar
I think you might have misunderstood, we never run that belt with a 17% pulley. The 535 should be right
Old Mar 11, 2008 | 03:10 AM
Marwan's Avatar
Marwan
thanks Jan!!!! Yeah, I guess I misunderstood
Old Mar 13, 2008 | 06:18 PM
Marwan's Avatar
Marwan
Received the package yesterday . And yes you were right, I've got the 535 belt . Just wanted to confirm everything is perfect!
Old Mar 13, 2008 | 06:22 PM
Glad to hear everything made it there
let me know how it goes once you get it put together!
Old Mar 13, 2008 | 06:26 PM
Marwan's Avatar
Marwan
After the 17%...
Yeah sure I will. Jan, I'm going for your tune. Do you think I should do a dyno run before getting the tune, or shall I save my money, do your ECU tune then go for a dyno run? Do you need the dyno numbers before applying the ECU tune on cars?
Old Mar 13, 2008 | 06:58 PM
it's not necessary for me, but if you want to keep it for your records then by all means do it
Old Feb 8, 2014 | 05:29 AM
IQRaceworks's Avatar
IQRaceworks
I know this is an old thread, but I need some help. I just put a 17% pulley on my 03' JCW and the NAPA belt 060535 is way to small to get it on, even with the tensioner cranked back as far as I can get it. I noticed the Craven and a few other companies say to use the larger 060539 belt with a 17% pulley. Right now I put my JCW belt back on, and it looks like it fits fine and the tensioner still has plenty of travel.
How did you guys get the 060535 belt to fit???
Old Feb 8, 2014 | 08:14 AM
GreekDrifter91's Avatar
GreekDrifter91
with a 17% you should be using a 532 belt
Old Feb 8, 2014 | 08:16 AM
IQRaceworks
If I could get it on I would use it....but it seems like it's way to small.
Old Feb 8, 2014 | 08:17 AM
GreekDrifter91
a word of advice loop the belt get as much slack out as possible and leave the idler pulley last. then walk it on to there. its a bit of a pain but possible.
Old Feb 8, 2014 | 08:20 AM
GreekDrifter91
if you absolutely have to loosen the idler pulley, so that its canted. with a few threads still in the hole. slip the belt on then screw the pulley back in. be careful not to strip threads. but that worked for me on my buddy's car, on my car i had no problem getting the 532 on.
Old Feb 8, 2014 | 08:35 AM
IQRaceworks
Maybe I'm confused.....but everyone in the thread is saying use a 535 , and you are saying use a 532? And all the pulley manufactures say use a 539. Very confusing.
Old Feb 8, 2014 | 09:41 AM
ZippyNH's Avatar
ZippyNH
Your confusion is due to the age of the thread....
Folks once used the 535 for both the 15% and the 17%....
But experience has proven the 532 works better with the 17%...a bit shorter...
You might need to have the tensioner pinned back, then get a 2nd person to PULL BACK A BIT ON THE TENSIONER TOOL....this last 1/4 inch of wiggle should let you thread it over the pulley....
You are much less likely with a nice tight belt like this to toss it from a bad tensioner damper or have it stretch to the point of squeezing or slipping. It just works better.
If you toss a 535 belt on...fine...should be changing it yearly or so with a 17% anyway....it is only a 25$ part at most.... And a 15 minute job if combined with a tire/wheel change.
Old Feb 8, 2014 | 11:39 AM
IQRaceworks
OK, thanks for the info guys. I'll try squeezing that 532 belt on there one more time. Even with the age of this thread, I'm still surprised that if you go to WMW, Helix, or Craven's website...they are saying is a 539 for the 15% and 17% pulleys.
I'll try that trick with the idler....hopefully I can squeeze that 532 on.
Old Feb 10, 2014 | 05:36 AM
TheBigChill's Avatar
TheBigChill
We should make a quick Sticky on belt part#'s and the pulleys they work best with. There are a ton of belt threads out there, but they're 90% people just blurting out random anecdotes with no backing information.
I know to an extent multiple sizes work on certain pulleys but, using the stock belt length we can do a simple calculation to find what length belt a 15%, 17%, 19%, etc, actually require. Math & stuff
Old Feb 10, 2014 | 06:58 AM
IQRaceworks
I would think that all of the companies that make and sell the pulleys would want to update all of their info....they all say use a 539 belt which I found out is way to loose. I think some company's (alta?) even supply a 539 belt in their kit. .....the 532 belt was a little tricky to get on, but once I used your trick of slipping it on the idler pulley last...it slid right on. It fits great....I'd say its the shortest belt that would work with a 17% pulley.
Yes, I agree that there needs to be a sticky on the correct size of belt to use with different sized pulleys, lots of bad info floating around out there.
Toolman
Jan 20, 2016 06:50 AM
Lt. Dan
Aug 10, 2015 12:46 PM
Aug 7, 2015 09:51 AM
