Drivetrain Belt tensioner bolt torque
Old Feb 3, 2008 | 10:23 AM
MCLeonard's Avatar
MCLeonard
Does anyone know the recommended torque for the bolt (in the upper right of the picture) that mounts the tensioner assembly to the supercharger and do you know if over torqueing will cause the assembly not to pivot and then not to tension the belt properly or do you know of problems with the assembly pivoting properly?
Old Feb 3, 2008 | 10:44 AM
jhiggs26's Avatar
jhiggs26
Drive belt tensioner to supercharger M10=33ft-lbs.
Jeremy
Old Feb 3, 2008 | 01:38 PM
MCLeonard's Avatar
MCLeonard
Jeremy
Thanks Jeremy how about the 16mm bolt?
Old Feb 3, 2008 | 01:46 PM
jhiggs26's Avatar
jhiggs26
I found a 5/8 socket to fit better. And that was the bolt I was refering to: so 33 ft-lbs it is!
Jeremy
HighLife4136's Avatar
HighLife4136
There's a 17mm that also gets 33lbs.
The 8mm gets 7lbs.
Old Feb 3, 2008 | 03:43 PM
carbonized's Avatar
carbonized
M10= 10 m/m thread, 17m/m head and 33 lbs it is!
USA-RET
Nov 9, 2015 07:27 PM
Sep 4, 2015 09:23 AM
Sep 3, 2015 10:29 AM
Sep 2, 2015 11:15 AM
cw40342
Sep 2, 2015 06:01 AM
