Drivetrain Odd loss of thrust
Old Jan 24, 2008 | 04:22 PM
Viper Freq's Avatar
Viper Freq
Odd loss of thrust
At 75MPH and staying in 6th gear, I push the gas to pass and the turbo spools up until about 3500RPM and then it sounds like the turbo lets off and there is a noticeable loss of power.
About the same time the check engine light comes on.
Within a couple starts the check engine light goes out and the dealer doesn't seem to think there is a problem since that light keep going out.
It has happened with the stock air filter, and with the K&N.
Anyone had this happen? Any suggestions as to what it could be?
Old Jan 24, 2008 | 04:25 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Semi known issue. Relates to the DSC and Traction system. It will pull back boost over 70 mph unless sport is engaged, and the DSC turned off. Try that and see what happens!
Old Jan 24, 2008 | 04:27 PM
tony1athome's Avatar
tony1athome
That's positively silly!
Old Jan 24, 2008 | 04:41 PM
Terry @ BMS's Avatar
Terry @ BMS
Have you pulled the code?
Old Jan 24, 2008 | 04:43 PM
Viper Freq's Avatar
Viper Freq
Haven't pulled the code. Is that something I can do from home?
Old Jan 24, 2008 | 04:54 PM
Terry @ BMS
You would need a code reader. Is the SES light on, or did the code appear and disappear when you restarted the car?
Old Jan 25, 2008 | 11:40 AM
SlowB00st's Avatar
SlowB00st
One note is that if the ecu after some restarts of the car sees that the problem does not persist the light will go off but depending on the code it will be store and could be read by a scanner for later reference.
Old Jan 27, 2008 | 05:58 PM
Ryephile's Avatar
Ryephile
Originally Posted by Viper Freq
...the check engine light comes on.
The CEL is telling you there's a problem with the engine that shouldn't be; get it taken care of!
Old Jan 28, 2008 | 06:42 AM
kenatminimania's Avatar
kenatminimania
This may be related to the 'No Turbo' problem posted on MINI2.
ken
eMINI of the State
Oct 2, 2015 03:12 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
EVMini
Sep 28, 2015 10:20 AM
daviday
Sep 25, 2015 01:31 AM
Sep 3, 2015 02:06 PM
