Drivetrain NEW ALTA R56 Plug-n-Play ECU Q&A Thread
Old Jun 26, 2008 | 07:46 AM
  #526
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Originally Posted by hopper
Stupid Alta PNP question:
I have just ordered a pnp ecu, cai and cat-back exhaust from Alta. I talked to Ken and requested the ecu map to accomodate my anticipated mods and home elevation along with my normal gasoline preference of 93 octane. So my question is, which map (0 or 1) will that be, and since the other map is not the same thing tuned to 91 octane, what is the other map?
TIA,
Richard
Map O is the UniChip Tuned Base Map, the Map I is the ALTA map specific to your mods. UniChip is now requiring that we map them this way to help with any diagnostic concerns. Also, all warranty is now handled directly through UniChip Vs. ALTA was was done previously.
THANK YOU for your business and your questions!
Old Jun 26, 2008 | 08:19 AM
  #527
new22003's Avatar
new22003
Originally Posted by ALTA_Ken
Hey guys and gals! Sorry for any confusion or concern. We never intended to irritate or "wiz off" any clients. If you purchased your UniChip for the R56 from ALTA directly within the month of June before the special, we will extend an instore coupon for the amount above $549.99 - freight etc.
WE already did this for clients that phoned me directly. Sorry for not checking this thread. Let me know personally if I can help further.
Thanks again for choosing ALTA and UniChip!
Ken.Jubb@altaminiperformance.com
Nice. More vendors need to take a similar attitude. So many companies forget "the customer is always right". I am amazed that some companies argue with their customers, or even worse, blame them for problems or grumble about the way the customer handled things. It may cost a bit of money in the short term but the goodwill is priceless. Because of how this was handled I will certainly shop alta when my mini arrives.
Old Jun 26, 2008 | 08:23 AM
  #528
minim8o's Avatar
minim8o
Towards any of the Alta employees... What are the plans for a '09 JCW specific tune by you/UniChip? Yes, I know someone's got to get their hands on it 1st. <grin> I'm just wondering if estimations were made of the form "we expect we could have our tune altered specific to that model N number of days from the date we get our hands on one..."?
thnx,
-steve
Old Jul 1, 2008 | 01:10 PM
  #529
BDBMCS's Avatar
BDBMCS
CEL
I recieved my PnP last week. During install, I was not able to engage hook on rearmost plug. The others went fairly easy. Any ideas on how to correct this? Yesterday the car threw a CEL that has not gone away even on "0" setting. Tried the stop/restart thing at least 5 times. I'll try to get to Autozone soon to read the code. Any thoughts in the mean time?
Old Jul 1, 2008 | 03:59 PM
  #530
BDBMCS's Avatar
BDBMCS
CEL
Well, today the CEL is gone. As I mentioned earlier, I couldn't hook the rearmost plug at the ECU. Trying to engage the today it broke (the metal hook). Is the hook a requirement? The plug will not enter any further to make a new hook a better solution. Any suggestions?
Old Jul 1, 2008 | 05:34 PM
  #531
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
I'd say if you have the PnP ECU hooked up with only 2 of the three connections, you bet your gonna have problems.
I don't think the metal hook on the connector closet to the windshield is required, it would help hold the connector in place but it should be a tight enough connection that it is unlikely to come loose.
The first time I took off that smaller connector on mine, it was a pain trying to get it off. The front two connectors go in/out much easier. The more common problem is not having enough slack for the larger connection in front. Once you add in the connection adapter you don't have a lot of slack in the cable to make the connection.
Old Jul 1, 2008 | 07:09 PM
  #532
BDBMCS's Avatar
BDBMCS
connectors...
As far as the front plug, I did what a couple other guys in this thread did. I plugged the Mini plug into the connector from the PnP then both into the ECU. There was enough slack in the cables that it fit easily. Hope you're right about the last plug. Just had a thought, I might be able to circle the ECU and plug with a zip tie. As a last resort.
Old Jul 1, 2008 | 07:50 PM
  #533
ADAMSALTAMINI
Best to check that the plugs are fully engaged. If they are, then no problem. The use of a wire tie to hold the lot is likely A-ok! If the car starts and runs fine, then no reason for concern.
Let us know how we can help in anyway further!
Old Jul 2, 2008 | 09:20 AM
  #534
hopper's Avatar
hopper
Thanks for the update Adam. I have the ecu, but the intake and exhaust have not come. Will it throw a cel if I install and run on map 0 with no mods?
Old Jul 3, 2008 | 07:59 AM
  #535
ADAMSALTAMINI
Nope! Go for it! Should be a-ok!
Thanks again for the patience and the business!
Old Jul 3, 2008 | 09:36 AM
  #536
hopper's Avatar
hopper
Great! I'll pop it in this afternoon. I assume that there is no issue with mounting the ecu on the fuse box cover as originally shown? The instructions that came with the pnp direct you to route things to the passenger compartment which seems to be a more involved install and harder to reverse for service should one choose to do so.
Old Jul 3, 2008 | 12:34 PM
  #537
hopper's Avatar
hopper
PnP installed. Nothing challenging except the previously stated fact that the front plug lead is VERY short and EXTREMELY tight. There is a noticable difference and the car pulls strongly now. Since the car is stock and only has 1400 miles I'm running map 0. Hopefully things will stay CEL-free when the CAI and Cat-back arrive and I switch to map 1.
The extra power magnifies the torque steer issue and though I don't want to wreck the daily-driver ride, I guess I'll have to consider lowering.
Thanks Alta
Old Jul 10, 2008 | 01:49 PM
  #538
ukaussi's Avatar
ukaussi
PnP installed today. Only problem I experienced in the install was that the middle and rear OEM plugs have tiny zip ties on them and because they were being pulled more than usual the ties were stopping the locking bracket that pulls over the top of the connector from fully "clicking" into place. Had to push the tie out of the way whilst pulling over the bracket and all ok.
Zip tied the OEM cover over the top of the connectors for good measure
Mounted the Unichip on top of the fuse box and taped up the connectors so they wouldn't get any water if it got all the way up there.
Took car out on setting '0' - all ok, seemed to actually pull a little better in the mid and upper end.
Switched to setting '1' after 2 or 3 miles - - initially drove ok, though didn't seem as good as '0' and then after about 1/2 mile I stepped on it a few times at low rpm in 3rd and it just bogged down. Tried again in 4th a few times at higher speed (but low rpm) and same and then got limp mode so no boost.
Now, I had heard of some issues with some Alta intakes collapsing and my intake already appeared a little "squashed" about 2/3 of the way from the MAF. So I grabbed a large hose clamp and placed it around the suspect section and tightened it up so that it evenly touched around the pipe resulting in a more circular appearance.
I then took it out again and it was a lot better and didn't bog down immediately but in higher gears (4th & 5th) it was definitely worst than setting '0' and after a few pulls it went into limp mode again and threw a CEL. CEL did not reset after 8 consecutive restarts but it did
Will contact ADAM and get him to send me an updated intake pipe. In the meatime I switched it back to '0' and it runs fine even with CEL
Old Jul 10, 2008 | 03:54 PM
  #539
ukaussi's Avatar
ukaussi
ETA on add-on module ?
Any news on the an in-car tuning/performance meter, upgrade? Are all ECU upgrades compatable or should we wait to order?
TIA
Originally Posted by ADAMSALTAMINI
Thanks for asking. Those upgrades are completely usable with the current ECU. It is an add on module. (Like what we currently offer for the R53.) So you can buy now and then upgrade to that module later on.
Thanks again for asking!
Any ETA yet ADAM ?
Old Jul 10, 2008 | 06:29 PM
  #540
FugitiveAI's Avatar
FugitiveAI
put your OEM turbo inlet back on and see how it works. That solved the CEL and boost issues for me. Just a suggestion to help you get to the bottom of it faster... so you can go faster! MAP 0 is for the grannies
Old Jul 10, 2008 | 09:10 PM
  #541
ADAMSALTAMINI
Thanks for the post and the feedback. I am out of the office until Monday, so lets chat then! Thanks again!
Old Jul 11, 2008 | 11:51 AM
  #542
ukaussi's Avatar
ukaussi
PnP installed today. .........
UPDATE :-
Changed out the ALTA intake pipe and reinstalled the OEM pipe .... NOTE ... the OEM pipe is MUCH sturdier than the ALTA when you try to squeeze it.
I Checked the other ALTA silicon pipes and although they were a bit stiffer than the ALTA intake pipe they were no where near as stiff as the OEM intake, however, they dont need to be as stiff as they handle positive pressure not negative. They just need to be stiff enough that they don't "swell".
This explains why true racing engines use custom steel piping that will neither collapse nor swell.
So, took car for a run on setting '0' to warm the engine up and all was well so switched to '1' and all was still good with no "bogging" or limp mode but it actually felt a little LESS powerful than setting '0'.
After driving a few miles I took it back home and double checked the clamps I could reach and they were all tight (couldn't reach OEM clamps on FMIC exit side)
I then decided to disconnect battery and depress brake pedal as I believe this resets the ECU learning/adaptive software, right ?
Anyways, took it out for a drive and again all was good on '0' with no real change felt from before the reset but then when switched to '1' you could now feel it was more powerful than '0', just not what I was expecting (having had a 2002 GTI 1.8T chipped) but it has yet to fully learn so will give it time and then disconnect it all and run stock to compare.
I am obviously not making the most of the ECU upgrade as I do not have a DP and CB exhaust. On my 2002 GTI I did the same and had the ECU done prior to any exhaust mods. I then had a 3" DP & catback installed and it was as if 50% of the power/tq gain was waiting for the exhaust to be installed.
Anyway, no exhaust for me on this car so will try it out and see for a week or so.
Old Jul 11, 2008 | 12:16 PM
  #543
ADAMSALTAMINI
FYI: The newest versions of the ALTA Inlet tubes now feature an internal wire to help maintain shape in even the highest of boost levels or plugged filters.
The earlier versions (if cured properly) should be just as firm as what he describes the boost tubes to be. If yours is softer than you expected it to be PLEASE let us know. A few early softies did cause some issues as described above.
Thanks again folks! As always let me know how I can ever help further!
Old Jul 11, 2008 | 12:43 PM
  #544
ukaussi's Avatar
ukaussi
.... and for those contemplating an ECU PnP unit I would highly recommend you get at least your boost tubes upgraded to better flowing aftermarket tubes from ALTA, Forge, M7 etc as it definitely made a difference on my engine performance and smoothness. This is all assuming you have upgraded to a better flowing intake filter system 1st
Also, forgot to add that testing conditions where I live in Ft Worth TX were 92 F and around 750'-1000' above sea level
Old Jul 11, 2008 | 02:18 PM
  #545
ADAMSALTAMINI
Excellent points!
Old Jul 11, 2008 | 02:32 PM
  #546
hopper's Avatar
hopper
Okay, silly ECU question here.... do the ECU's actually "learn" or have any real adaptive capacity? I thought they were "map" or table driven. Is the "learning" thing urban/internet legend?
Old Jul 11, 2008 | 04:38 PM
  #547
ukaussi's Avatar
ukaussi
Almost every engine management computer and every automatic transmission management computer in every new vehicle available for sale has adaptive learning. They have been this way for quite a few years now.
Old Jul 11, 2008 | 04:56 PM
  #548
minim8o's Avatar
minim8o
They are map/table driven. However the active map can be switched.
It's more accurate to say the ECUs switch between several different maps, based on the driving style. I.e. the throttle angle and rate of speed of the change of the throttle angle, the rate of release of the throttle, etc. I'm sure that an ECU can't "interpolate" and algorithmically select an AFR & ignition timing as the RPM changes based on load requirements... it's all programmed into a table and the active table that is used is swapped in & out. ...the way I know it.
...I also thought this was a trait only of automatic transmissions... With manual transmissions this doesn't occur, other than having the "sport"/"standard" button. I may be wrong.
MB started using this in the mid-90s. Is is also the single most vile thing ever invented. I call it the car going into "grandpa mode". If I don't beat on my C43/55, the responsiveness to movement in the throttle becomes close to non-existent. With the E55 engine swapped, in, I need to press the peddle even less to get up to speed ... accelerating the activation of "grandpa mode"! <grrr>
Old Jul 11, 2008 | 06:08 PM
  #549
jcap287's Avatar
jcap287
School away from MINI
im still lurking haha . How much will it cost to upgrade the inlet hose and intake hose? Also, do I have to get new boost tubes?
Old Jul 12, 2008 | 07:52 PM
  #550
jcap287's Avatar
jcap287
