Drivetrain Pinging under boost
Old Nov 25, 2007 | 06:26 AM
qluber's Avatar
qluber
Pinging under boost
Hey guys, I have an '05 MCS, 15%, Magnaflow catback, iridiums, DDM CAI, GIAC tune. For a couple of months now I have noticed considerable pinging around 5k rpm and up. I changed the spark plugs, toyed with the gap settings, I even did and upper intake cleaning as well to no avail. Any suggestions? Problem doesn't seem to be temperature related either, as it does it at all ambient temps?
Old Nov 25, 2007 | 08:25 AM
ED955S's Avatar
ED955S
Can you try a higher octane gas? I have that too if I put 91 octane (due to wrong place & wrong time) but not on 93+. Are your spark plugs one step colder heat range?
Old Nov 25, 2007 | 08:29 AM
qluber's Avatar
qluber
Yes to 1 range colder, and always 93 octane.
Old Nov 25, 2007 | 09:01 AM
ED955S's Avatar
ED955S
Might be your tune but not sure because GIAC is famous here and with good remarks but I remember GTT (Roland) in Mini2 said the 05 & 06 have more advanced timing than the older models, hence the higher HP rating. Go to Mini 2 and this subject is well discussed and maybe find an answer. Good Luck.
Old Nov 25, 2007 | 09:18 AM
Big Dog's Avatar
Big Dog
There are many things that can cause pinging. Audible pinging in a Mini is a big deal. If the pinging coincided with the GIAC tune then there's your answer. If it started sometime after then there is most likely another reason because the tune doesn't change. A slipping belt, for example, can cause pinging on a supercharged Mini.
Old Nov 25, 2007 | 10:47 AM
qluber's Avatar
qluber
The pinging started well after the tune, sometime around the time I changed plug wires........hhhmmmm....
Old Nov 25, 2007 | 12:51 PM
herbie hind's Avatar
herbie hind
try rapping on the block while it's held at say 2000 rpm and see if it adjusts to the knock . do it near the knock sensor .
Old Nov 25, 2007 | 02:54 PM
qluber's Avatar
qluber
And how does this help, or what will it tell me?
Old Nov 25, 2007 | 07:21 PM
Guest's Avatar
Guest
Because if it adjusts to the knock you know your knock sensor is good. Your car shouldn't really be knocking with 93 octane and colder plugs. I don't have any issues with knocking even in the 115+ degree heat out here with IAT's approaching 180 degrees. I think what he's getting at is that your knock sensor could be bad.
Old Nov 25, 2007 | 07:28 PM
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
You mentioned that it occurs above 5,000 rpm. Do you think it could be due to higher boost at those engine speeds?
dan
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
mbatech
Sep 10, 2015 03:40 PM
