Drivetrain how should i spend $1100 on my MCS?
Old Nov 14, 2007 | 01:49 AM
mini_macky's Avatar
mini_macky
this has been bugging me for sometime now and i gotta let it out
i'm choosing between one of the following (or any combination):
1. Detroit Tuned BBK for 16" wheels (used or bnew)
2. Volt exhaust (bnew) + header
3. ANY reputable catback (used) + header
why consider getting a used reputable catback? i live in the philippines so if i were to buy a catback from the U.S., i'd have to pay sea freight through my friend's contact so i don't mind getting a used exhaust as long as it's fresh. the only bnew exhaust that i can find that's under $500 (cheapskate) is the volt exhaust + $110 shipping to the freight forwarder in CA
how much to have a catback shipped to the philippines? $225-240 that's why it's crucial to find an exhaust that fits the bill
i'm also considering the DT BBK mainly because it's relatively cheaper compared to other BBK kits...and the money i save ultimately goes to shipping costs
how do i use my Mini? trackdays with friends about 4-6 times a year, very spririted mountain driving about 6 times a year. i'm not considering coilovers because i would like to have a "street" suspension setup (and it would add bragging points to beating other cars who have coilovers ) i'm ok with the stock suspension, i just added Eibach springs, powerslot rotors, hawk pads and Advan AD07 (and a 19mm swaybar soon). other mods done to my Mini are in my sig
any inputs would be greatly appreciated. thanks
Old Nov 14, 2007 | 07:52 AM
Bahamabart's Avatar
Bahamabart
a suggestion on the exhaust/header - you might want to see if OBX is available since they come out of the far east - this might save you some shipping $$. In the states the exhaust cost about 300 delivered and the header about 200.00
There are plenty of threads on the header and a few on the exhaust. I happen to run both so if you have any questions drop me a line.
Old Nov 14, 2007 | 08:19 AM
Deviant's Avatar
Deviant
I'd go for a one-ball exhaust upgrade with an electronic cutout the way Thumper on this site has done it (I believe that's his screen-name), it looks like a great way to get a budget exhaust and it has that stealth aspect to it as well. Combine that with a header and some upgraded brake pads with stainless steel lines and you'll be good to go.
Old Nov 14, 2007 | 11:13 PM
mini_macky's Avatar
mini_macky
Bahamabart: yup, i've read the numerous threads on the OBX header...but the exhaust? i'll have to look into that one. what again are the main concerns regarding the OBX header? (all i remember is that when laid down flat, some of them aren't completely flat)
Deviant: electronic cutout? on the exhaust?
Old Nov 15, 2007 | 07:59 AM
Big Dog's Avatar
Big Dog
Best bang for the buck is a pulley and a tune. You've got the pulley so why not try a tune. MTH gives a good result and their process allows guys like you who don't have other options to get a good base flash that you can do yourself.
Old Nov 15, 2007 | 08:37 AM
minimusprime's Avatar
minimusprime
do you have any brake fade on the track with your current setup. While I think the dt bbk is a great kit... the reality is that a bbk is not really necessary in 99% of cases. I have one and the only reason i do is i got it used off the marketplace for a price i couldn't pass up. If i had to do it over again i would not buy it.
As for exhaust I would personally get a one ball and a header such as obx with a cat.
Do you have camber plates? if you do track days camber plates make a profound difference in the handling of this car.
Old Nov 15, 2007 | 05:22 PM
mini_macky's Avatar
mini_macky
Big_Dog: there's a shop here that does dynapack tuning (partial throttle tuning), i'm definitely looking into that
minismusprime: you got a point, i don't do wheel to wheel racing with my buddies, so basically i really slam on the brakes ONLY on my hot lap, i take it easy on my out and in lap thanks for the input
Old Nov 15, 2007 | 05:26 PM
PGT's Avatar
PGT
I've got an Alta system coming off tomorrow. I've heard quite a few systems and it's one of the best out there. Plus, it's a single can exhaust, so shipping will be far less than the normal designs. I'm only replacing it because the header I'm getting requires a custom rear section to fit. I don't expect the new system to sound better by any means.
Old Nov 15, 2007 | 05:35 PM
Johan's Avatar
Johan
Can you load a dyno pack?
Old Nov 15, 2007 | 06:05 PM
cooper99's Avatar
cooper99
Based upon your current list of mods in your sig, I recommend a header/exhaust combo. It will definitely allow your engine to breathe a lot easier and probably free 10-15hp.
If I were you, I would get:
1. OBX header- Like others have said, buy from ebay for around $200+ shipping.
2. Doug Thorley exhaust- This is a super good bargain on a brand new exhaust. My friend, Aaron, the owner of OutMotoring, had this on his R53 MCS for a while and it sounded great. It's only $475+$75 with a resonator. Not sure what international shipping rates would be though.
Or if you are looking at a used exhaust and saving some $$$, I would look for a Milltek.
Old Nov 15, 2007 | 10:59 PM
mini_macky's Avatar
mini_macky
PGT: i've been looking at your ad for some time now...tempting
Johan: the brand of the shop's dyno is dynapack, think they use a different software to tune cars. they usually tune by 500rpm increments (partial throttle tuning)
cooper99: yup, the OBX seems like the way to go, but i'm concerned that my Mini might lean out with a header + exhaust combo, which means i may have to push through with the tuning early which i can't afford now, which is the reason why i'm looking at catbacks
the doug thorley exhausts are indeed a bargain...but the tips are...umm...nevermind LOL
there is/was a used milltek on the selling section posted a few days ago, i jumped at the opportunity but someone may have been already 2 steps ahead of me...
Old Nov 16, 2007 | 11:25 AM
Johan's Avatar
Johan
Thanks, but is the motor under a load when tuning or in other words is there resitance added from the dyno to make the engine work or bog?
I don't have any experience with a dyno pack.
techgearpro
Jul 23, 2019 07:09 PM
wildwestrider
Dec 27, 2015 08:20 PM
jesterofatlas
Sep 4, 2015 11:23 PM
Sailorlite
Sep 4, 2015 07:03 PM
schwac2
Sep 3, 2015 08:56 PM
