Drivetrain I know Air Filter should be oiled a bit... I thought not dripping...
Old Oct 9, 2007 | 01:11 PM
joonskim's Avatar
joonskim
Hey guys...I just bought an air filter from Mini Mania and it was very oily...is it suppose to be that oily??
what if the oil gets into my intake?
Is anyone using the same filter from Mini Mania? Could you tell me hows your filters are??
Thanks!!
Old Oct 9, 2007 | 01:18 PM
Guest's Avatar
Guest
Thanks!!
It most definitely should NOT be dripping
Old Oct 9, 2007 | 01:51 PM
MRmidge's Avatar
MRmidge
The filter should be wet no more no less. If it is driping, pat it down with a paper towel try not to remove to much oil, just enough to stop the driping.
*edit* Fixing my half sentences.......
Old Oct 9, 2007 | 01:56 PM
MiniMacPR's Avatar
MiniMacPR
I've read that some manufacturers even recognize that the filters come with too much oil when new.
Dripping = WAY too much oil
Old Oct 11, 2007 | 08:16 AM
ALTAPerformance's Avatar
ALTAPerformance
We do!!!!
WE do mention that when you get your new ALTA filter, remove the excess oil with a paper towel or similar prior to installation. When ours are made, they seem to over oil some of them, and it is beneficial to remove the excess prior to installation.
Let me know if I can ever help with any of your modding plans!
adam@altaminiperformance.com
Old Oct 11, 2007 | 01:46 PM
Frank Matyja's Avatar
Frank Matyja
Blew By U
Remove the excess oil! If the filter is too wet oil will get into the intake and gum up the mass air flow sensor (MAF) and create erroneous readings for the EEC. The car will run shitty...
silence2-38554
98
Sep 21, 2016 02:52 PM
tr3y003
Oct 22, 2015 10:48 AM
polotska
Aug 23, 2015 09:10 AM
pre shrunk
Aug 18, 2015 11:09 AM
minipopkart
Aug 13, 2015 05:22 AM
