Drivetrain Removing SC pulley without a puller
Old Sep 18, 2007 | 09:40 PM
The_R1_Kid's Avatar
The_R1_Kid
I searched but I didn't find much. I am installing a M7 pulley in 2 weeks. I don't have a purpose built pulley puller. Will this be an issue? I have access to a full pulley removal set that you see at a auto shops.
Thanks,
Kyle M.
Old Sep 18, 2007 | 10:02 PM
neilgj's Avatar
neilgj
My recommendation is to either buy or rent or borrow a proper puller. Check your local MINI club, they usually have a puller or two available
Old Sep 19, 2007 | 04:06 PM
Some Guy's Avatar
Some Guy
If you have access to a pulley removal set at a shop i dont see why you need to borrow one from a retailer or whatever.
Old Oct 16, 2009 | 04:27 PM
PinesMini's Avatar
PinesMini
I am changing mine tomorrow and would like to know can it be done? How hard are those pulleys on their? Thanks
Old Oct 16, 2009 | 04:34 PM
BlimeyCabrio's Avatar
BlimeyCabrio
I have done it with a standard puller (because somebody else started it against my advice) and it was a nightmare, but eventually got done and completely destroyed the pulley in the process. I HIGHLY recommend you get a purpose-built puller before doing this. They don't cost that much. In most areas, you can find a club member who has one.
Old Oct 16, 2009 | 08:39 PM
The_R1_Kid's Avatar
The_R1_Kid
Holy old thread... I would recommend getting a purpose built puller. I ended up buying an Alta puller and reselling it here after i used it. It cost me about $10 in all. It was very easy with the alta tool i tried with a standard puller first but space is very limited.
Old Oct 17, 2009 | 09:18 AM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
My brother and I ground mine off VERY carefully and separated the pulley enough to pull it off.
Old Oct 17, 2009 | 11:47 AM
ZippyNH's Avatar
ZippyNH
WOW.....most places that sell pulleys will rent you a puller for a couple bucks!! You probably spent more money and time on grinding wheels than you saved on the 10 puller rental....but if it worked who cares!! Good story to tell!!
Old Oct 17, 2009 | 04:30 PM
ClintTheMiniOwner
I work at a body shop. Took about 45 minutes
Old Oct 19, 2009 | 10:36 AM
PinesMini's Avatar
PinesMini
Does anyone one have pics of this puller and or have one I can rent or buy? Thanks
Old Oct 19, 2009 | 10:59 AM
Dr Obnxs's Avatar
Dr Obnxs
Where do you live?
I'd start with local clubs if there are any in your area? And there are lots that make pulley tools for the car. Check with the vendors listed in the vendor site. Also check the Marketplace. Lots of pulley tools get resold there.
Good luck!
Matt
Old Oct 20, 2009 | 05:22 PM
ZippyNH's Avatar
ZippyNH
Pullers can be used hundreds of times......New they are $60 ish, but for the cost of $10 or so you can rent one, or sometimes get a free loaner when you buy your pulley.
Installing a pulley is not super hard, but it is well worth the $$ to have it installed by someone who has prior experience, (that's why pulley parties are a popular club event!!) because if the install goes bad, you car maybe stuck, or very screwed up. Sometimes if you have a misaligned pulley, it will not even be apparent till you drive a few hundred miles, throw a belt, and need to replace a tensioner. For another $25 or so I strongly recommend adding a Detroit Tuned Tensioner Stop to prevent damage if the belt is thrown or breaks.
There a many people who have been down that dark and $$$ road. Many more of course who have had no problems. Some very good installers (mine for one http://www.greasysgarage.com ),
will sometimes sell 15% for $200 installed (even seen $175.00), and then charge you only $25 or so for a new belt if you need one...for a total of about what the dealer will charge ya for a belt change!!
Old Oct 26, 2009 | 05:17 PM
PinesMini's Avatar
PinesMini
Well I had a 3 jaw puller and it worked great. Very easy to pull off. The only thing the OEM pulley had 3 bite marks on it so that means it can never be used again. I don't think OEM pulley can be re installed because of being pressed on.
Old Oct 26, 2009 | 05:41 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The stock pulley makes a cool desk sculpture.
Old Oct 26, 2009 | 06:21 PM
ClintTheMiniOwner
The older crank pulleys make great door stops!
Old Oct 27, 2009 | 07:20 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Way Motor Works still does Pulley parties. So if anyone wants to do an "olde fashion" pulley party. Let me know. It could be alot of fun, it was always a good time.
Old Oct 27, 2009 | 08:10 PM
MINICHEF's Avatar
MINICHEF
OK what about a puller for a JCW pully ?
Old Oct 28, 2009 | 12:23 AM
Luys's Avatar
Luys
I have cut it, without hurting the SC.
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
greekzilla
Aug 23, 2015 03:44 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
