Drivetrain Pulley torque specs comparison
Old Aug 9, 2007 | 05:00 AM
Aeromax's Avatar
Aeromax
Curious- those of you with pullies installed on your car, what pulley do you have and what are were the torque specs for the bolts, that the instructions gave you?
Old Aug 14, 2007 | 08:14 AM
Aeromax's Avatar
Aeromax
Bump. Someone has to know the torque specs on the bolts of various pulleys...
Old Aug 14, 2007 | 08:21 AM
El_Griton's Avatar
El_Griton
I dont have my instructions any more but I think this is right.
Mini-Maddness 19% pulley 6 bolts, 38 inch pounds. i think.
Old Aug 14, 2007 | 08:23 AM
El_Griton's Avatar
El_Griton
why do you need to know for different pullies? if you get one, you only need those instructions.
Old Aug 14, 2007 | 09:28 AM
MUShadd's Avatar
MUShadd
alta v2.0 3 bolts 80 inch lbs
Old Aug 14, 2007 | 11:14 AM
Aeromax's Avatar
Aeromax
I'm installing a pulley that doesn't come with instructions, and it's not from one of the "big tuners".
Old Aug 14, 2007 | 07:39 PM
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
I put "lock-tite" on mine and went to a quarter past firm. Probably a lot more than 75-80 inch-pounds, but what the hey... it has lasted over 65,000 miles. If it is that important to you (and I am not judging) probably somewhere around what the others take is safe. As for "lock-tite", that's just what I do.
dan
Old Aug 14, 2007 | 07:52 PM
El_Griton's Avatar
El_Griton
I think I went with blue loc tight when I did mine as well.
Old Aug 14, 2007 | 08:26 PM
Aeromax's Avatar
Aeromax
dan
That's what I'm trying to figure out. Some pullies say 40in/lb, some say up to 80in/lb. I guess anywhere inbetween is safe...
And loctite is a must for sure.
Old Aug 14, 2007 | 08:39 PM
MUShadd's Avatar
MUShadd
how many bolts does your pulley have? seems like the more bolts, the less in. lbs required.
Old Aug 15, 2007 | 04:38 AM
Aeromax's Avatar
Aeromax
Mine has 4. At first I was thinking 40in/lb because alta uses 4 bolts and requires 40 in/lb.
Old Aug 15, 2007 | 06:50 AM
Helix13mini's Avatar
Helix13mini
The Helix pulley has 6 which should be torqued at 60 in/lbs each.
Old Aug 15, 2007 | 09:08 PM
minibeel's Avatar
minibeel
I have a Helix pulley. Never knew the torque spec 'til now...
dan
Old Aug 15, 2007 | 09:11 PM
EDM's Avatar
EDM
Is it a 2 piece or 3 piece? My minimania is 3pc and requires 70 in/lbs.
Old Aug 16, 2007 | 04:41 AM
Aeromax's Avatar
Aeromax
This is a 2 peice.
Old Aug 16, 2007 | 07:14 AM
norm03s's Avatar
norm03s
Helix13 pulley
dan
Me either, just gut und fest within reason for the screw size and a dab of blue lock-tite.
40,000+ miles, keine Probleme
BernieCoop
Sep 10, 2021 03:15 AM
one73ronin
23
Sep 22, 2015 09:56 AM
boydie
Sep 13, 2015 05:06 PM
smbmkay
Sep 11, 2015 09:45 AM
cw40342
Sep 2, 2015 06:01 AM
