Drivetrain Any updates on the RMW Rotrex SC kit?
Old Aug 7, 2007 | 07:39 PM
  #76
Uncl3's Avatar
Uncl3
Originally Posted by MSFITOY
How did I miss this thread?
Just so the rest of you clowns understand...when I get mine, you'll get yours...
just jokn...
BTW... I'm loosing my taste for cheese...
Cheese always gives me gas.
Old Aug 7, 2007 | 07:50 PM
  #77
typer139's Avatar
typer139
+1 (actually all dairy tends to gas me up, and don't ask about the wife, )
Old Aug 8, 2007 | 08:50 AM
  #78
Dr Obnxs's Avatar
Dr Obnxs
Centripital Superchargers and the like...
I'm actually very interested to see how the Rotrex optimization will pan out. It's basically a mechanical turbo (all marketing vocabulary aside) that has a slightly more efficient drive mechanism than the belts and gears that others use. It would be very interesting to see just how much more efficient the drive mechanism is....
As far as Don's post from Magnussen, it's right, as far as it goes. The Centripitals have done very, very well on some applications, like N/A V-8 conversions. These motors typically are pretty good down low, but loose breathing at the top, so the power adding curve of the centripital is well matched to the existing power fall off of the motor, and you get gobs of power (I was reading a story that went from about 300 to well over 450 HP just by adding a Vortex).
Now, putting one on a Mini is an interesting proposition. Independant of the drive mechanism, the centripitals have a "turbo-like" boost curve. With the low compression ratio of the motor, I wonder just how much will be available down low. Up top I have no doubts that this will scream. Will it be the best for you? That will depend on how you drive....
Matt
ps, now back to the dung slinging!
Old Aug 8, 2007 | 10:06 AM
  #79
Dr Obnxs's Avatar
Dr Obnxs
If you want to see what's inside a Rotrex
and all about it from the horses mouth, so to speak, I found this PPS presentation....
http://www.w2wpowertrain.com/images_...esentation.pps
Matt
Old Aug 8, 2007 | 11:17 AM
  #80
JIMINNI's Avatar
JIMINNI
Matt
Very cool, thanks . Does Longboards car have the oil cooler?
Old Aug 8, 2007 | 01:01 PM
  #81
Longboard Mini's Avatar
Longboard Mini
Yes it does.
Check YouTube for the video.
Longboard
W0TM8
Dec 19, 2019 07:50 AM
blackie
Sep 2, 2015 09:16 PM
