Drivetrain Downgrade CAI?
Old Jul 13, 2007 | 07:14 PM
  #26
jeffc's Avatar
jeffc
7th Gear
I think I will put the original hose and partition in tomorrow and take it for a ride or 2..
Old Jul 13, 2007 | 07:18 PM
  #27
Dr Obnxs's Avatar
Dr Obnxs
Don't worry about the hose...
it's the baffle at the back by the firewall that's getting you.
Matt
ps, the HAI will give you better response but no more power unless you do some work to get some more cold air to it.
Old Jul 13, 2007 | 07:31 PM
  #28
jeffc's Avatar
jeffc
7th Gear
Matt what HAI are you running?
I love the whine of the Alta just don't like the low throttle whistle.
Old Jul 13, 2007 | 08:24 PM
  #29
Dr Obnxs's Avatar
Dr Obnxs
Same as most...
K&N on the TB. I did some mods to the front radiator support to keep some of the hot air away....
Not too pretty, but keeps the hot air from the radiator away....
Matt
ps, if your curious about some data on the HAI, take a look at my gallery, here.
Old Jul 13, 2007 | 08:26 PM
  #30
jeffc's Avatar
jeffc
7th Gear
How does it sound? Any whistle at low throttle?
Old Jul 13, 2007 | 08:30 PM
  #31
Dr Obnxs's Avatar
Dr Obnxs
A bit.
the wistle is from air going over the edge of the throttle plate. It's not heard on the stock cars because of all that plumbing and the accustic ressonators that are on the tube from the airbox to the front of the car.
Getting rid of that isn't easy, but not having removed the rear panel when I did the HAI keeps the sound pretty close to stock. A bit louder, but none of that slurpy sucky sound that I've heard on cars with nothing between the passenger compartement and the TB. (Some AGS cars have this but good!)
Matt
Old Jul 14, 2007 | 08:11 AM
  #32
jeffc's Avatar
jeffc
7th Gear
I just put back in the rear panel (Cut a section of it) on my Alta CAI and the whistle is gone. The SC Whine is quieter(I love the SC whine) but I am happy with the new sound or lack of. The fit is tight with the rear panel but everything fit back in.
Putting the back panel may be a easy solution for those that like the alta without the whistle. The compromise is not having the full whine from the SC that I have a grown to love.
Old Jul 14, 2007 | 09:51 AM
  #33
Red Scooter's Avatar
Red Scooter
Ditto. I just put the OEM firewall back in, too (no cutting). "Shaves off" the super-high whine/whistle that was a bit too much for me. The supercharger whine is still there just a bit more "refined". Seems to kick in/crank up at 3000+ RPMs.
It didn't/ hasn't reduced the performance gain though. At least not as far as my butt dyno can tell.
DEFINITELY a solution for those who find the Alta (and others?) too whiny.
Old Jul 14, 2007 | 04:57 PM
  #34
jhiggs26's Avatar
jhiggs26
Just wait a few thousand miles until the Alta filter picks up some minute debris then the whistle will go away! When you clean your filter just pop in the rear plastic panel for a few thousand miles then remove.....and on and on. I personally like the whistle though. Keep enjoying your cooler air intakes!
Jeremy
Old Jul 14, 2007 | 05:53 PM
  #35
jeffc's Avatar
jeffc
7th Gear
My whistle never went away I have 10k miles on it. I think every car is a bit different but pleased with the car and this tweak.
Old Jul 14, 2007 | 06:37 PM
  #36
jhiggs26's Avatar
jhiggs26
I agree fully Jeffc. Every car is unique! That's what makes us MINI operators smile! Best of luck to you!
Jeremy
Old Jul 18, 2007 | 02:52 PM
  #37
dakuze's Avatar
dakuze
The DDM unit adds a nice level of whine at most speeds and really gets your attention when you jump on it! I like mine as a pleasant compromise between stock and what I've heard about the Alta.
Pker
Apr 11, 2017 12:14 AM
slash695
Apr 26, 2016 06:27 AM
simo711
Oct 8, 2015 07:07 PM
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
thebombardier
Sep 15, 2015 02:53 PM
