Drivetrain question about the ags v2
Old Jun 13, 2007 | 04:44 PM
RA080624's Avatar
RA080624
is it better to have a plastic ags or a metal one? also what are the pro's of having this mod rather than the oem. does it just put more air into the engine?
Old Jun 13, 2007 | 04:52 PM
Partsman's Avatar
Partsman
Legion_of_Doom
If I had a choice, I would go with the plastic one. The area where the AGS lives is surrounded by heat generating parts.
Old Jun 13, 2007 | 05:47 PM
RA080624's Avatar
RA080624
would i need a heatsheild for it? if it is plastic
Old Jun 13, 2007 | 05:48 PM
RA080624's Avatar
RA080624
and what are the differences from the m7 v1 throguh v3
Old Jun 13, 2007 | 06:12 PM
Partsman's Avatar
Partsman
Legion_of_Doom
No, I believe it is a plastic composite, which will withstand the amount of heat generated in that area.
I'm not exactly sure with V.1 and V.2, and obviously V.3 is metal.
Old Jun 27, 2007 | 05:02 PM
1FSTMINI's Avatar
1FSTMINI
Partsman......Whats the trick with sealing the v.2. heard alot of people are having trouble with leaks.
Old Jun 27, 2007 | 05:05 PM
Partsman's Avatar
Partsman
Legion_of_Doom
A decent amount of RTV and let it sit overnight.
Old Jun 27, 2007 | 05:24 PM
1FSTMINI's Avatar
1FSTMINI
thanx.....i happened to get one with the CF cover so when i get a chance im goin to install it.
Old Jun 27, 2007 | 05:43 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Cool, good luck with it. I think i'm going to try out the MCSa tube when I do the electric water pump, so I can keep my airbox setup.
Old Jun 27, 2007 | 05:47 PM
1FSTMINI's Avatar
1FSTMINI
i was following that discussion on the AT tube for awhile until the AGS came out then it died. which do you think performs better.
I also wanted to do the electric pump. can you put me on the trail for the parts needed and the gains. sorry for goin off topic
Old Jun 27, 2007 | 06:12 PM
Partsman's Avatar
Partsman
Legion_of_Doom
As far as performance, I would have to say that the shorter AGS tube would be better. The only thing I don't like about it is that it's not a sealed system, unless you're moving, your sucking some seriously warm under hood air.
I know Tuls found no gain from when he compared the MCSa tube to the 6-speed tube, but to me it seems the air would flow better through the nice consistent diameter of the MCSa tube. Like I posted above, I want to keep my airbox/filter/induction hose setup because I plan to ram air into it from somewhere, either on top of the hood or from the front.
I contacted Dave from DDM about the electric water pump conversion, he's a really nice guy and didn't mind me picking his brain in PMs and on the phone.
He gave me some very valuable info as far as flow direction, what needs to be plumbed together, and what I have to make. He said he may offer a kit for it, but i'm not sure where that is on his list.
Old Jun 27, 2007 | 06:23 PM
1FSTMINI's Avatar
1FSTMINI
So your waiting on DDM to make a kit or your piecing one together?
Old Jun 27, 2007 | 06:40 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I'm doing it myself. The kit will be nice for those who don't have the means to make the stuff needed to do the conversion. I have a good friend that owns a metal/machine shop where I do all the work on my car, betweeen the two of us we'll be able to make all the stuff to do it, except the pump of course.
Old Jun 27, 2007 | 06:46 PM
1FSTMINI's Avatar
1FSTMINI
o ok....so let me know when ur done so i can take a ride up to CT for you to do mine also....lol
Old Jun 27, 2007 | 07:03 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I could always make 2 or 3 of everything...
Old Jun 27, 2007 | 07:04 PM
1FSTMINI's Avatar
1FSTMINI
At what price would everything be you think roughly? And the gains?
Old Jun 27, 2007 | 07:43 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Once I get into it and see what needs to be done and what we use, i'll have a better idea.
The gains...less drag on the SC is the main one, definitely free up some power there. You also won't have to worry about the water pump drive lube going away.
Old Jun 27, 2007 | 07:46 PM
1FSTMINI's Avatar
1FSTMINI
ok...can you PM me when you have an idea on the cost
Old Jun 27, 2007 | 07:58 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I sure will.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
Carwash
Sep 15, 2015 02:02 AM
cinnabun
Sep 11, 2015 05:55 AM
marc0011
Sep 10, 2015 10:04 PM
