Drivetrain Has anyone installed intercooler muffler delete?
Old Dec 13, 2013 | 08:40 PM
  #101
cerenkov's Avatar
cerenkov
Made my own out of 304 stainless for $20. I had a muffler shop flare the ends for me.
If I decide to install different one like NM or Alta it will be a lot quicker since that PITA torx screw isn't there anymore.
As an extra bonus - I saved a whopping 100 grams in weight.
Old Jan 2, 2014 | 11:26 AM
  #102
Dr. Spade's Avatar
Dr. Spade
I installed mine yesterday. VIP parts one. Definitely a lot of work
Old Jan 4, 2014 | 08:43 PM
  #103
Systemlord's Avatar
Systemlord
Has anyone figured out why Mini chose to install the muffler on the intercoolers cold side? It can't be related to sound.
Old Jan 6, 2014 | 05:05 PM
  #104
cerenkov's Avatar
cerenkov
I don't think anyone really knows except for the guy that designed it, probably some summer intern project...hey design this worthless doohickey just don't bother me what ever you do.
I didn't notice a difference in sound.
Old Jan 6, 2014 | 05:38 PM
  #105
Systemlord's Avatar
Systemlord
My guess is the engineer over-engineered it for a purpose, but it didn't quite work out the way it was meant to.
Old Jan 6, 2014 | 05:44 PM
  #106
danjreed's Avatar
danjreed
A lot of times, engineers work hard on killing vibrations or sounds, my guess this muffler was designed to quiet down some frequency at a certain RPM that upset grandma in testing.
Kinda like the air intake design. Who the F@#K does not enjoy the sound of that open intake.
"Its too loud.. eeeewww, I don't want to hear anything, I want to live in an insulated Jaguar..."
Old Jun 26, 2014 | 02:04 AM
  #107
justinheilbron's Avatar
justinheilbron
Originally Posted by p8ntbollr
Well being that the muffler has a perforated chamber inside of the larger housing, it gives the air from the turbo room to expand and slow down, creating a slight loss in boost and bit of lag in throttle response. Granted its not much, but in theory I definitely see how it would be slightly restrictive.
Hi Guys. I have been researching this for the past week. Would it not be an option to seal off the perforations inside the chamber using a high heat-resistant silicone or epoxy?
Old Jun 27, 2014 | 12:52 PM
  #108
broncobuddha's Avatar
broncobuddha
I don't know that I would want to risk doing something like that where something could dislodge and get sucked through the intercooler, or worse, into the engine.
I do like the idea of sleeving the factory muffler to retain the stock look for warranty/inspection purposes.
Did anyone try it?
Old Apr 21, 2015 | 06:15 PM
  #109
HZBJCW's Avatar
HZBJCW
In an earlier post someone cut theirs in half. The diameter necks down in side where the perforations are so if you sleeve it down you would be increasing restriction. Maybe the better way is bore it out, slide if over a straight thru tube. I don't think it will look stock after all of that. Once you are over 70K miles all warranties are over for that kind of stuff, then you mod away.
I've been wanting to do this mod since the day I bought the car. My coolside turbo inlet tube (which by the way is made of plastic) snapped right under the hose clamp on my 09 so I have a Forge silicon hose
http://www.ecstuning.com/Mini-2009-C...d/F/ES2209703/
on order to avoid this problem form re-occuring. I sure hope they send good instructions because the PCV vent is in a completely different spot on this one. While I am in there I will do the muffler delete. Any reduction in pressure drop has to increase power but I won't get my hopes up too high.
Old May 27, 2015 | 11:15 AM
  #110
rckrzy1's Avatar
rckrzy1
so far this mod had been the most USELESS and most PAINFUL to date. Took me 3 1/2 hours of arm scratching, nuckle banging and for NOTHING I can feel , hear or see.
I felt no gaines, heard no more turbo , nodda, zip.
SO anyone who spent $130 or more for a silicone pipe or fancy alum pipe, I feel you wasted alot of money. I spent $15 on a SS pipe.
Old Jun 9, 2016 | 08:47 PM
  #111
lemarzmini's Avatar
lemarzmini
I agree, I just finish installing mine and I cant hear nor feel any difference. I used an aluminum pipe $17
Old Jun 10, 2016 | 04:37 AM
  #112
digitaldagor's Avatar
digitaldagor
Glad to know it made little to no difference. Save me from the difficult task.
Old Jun 16, 2016 | 02:24 PM
  #113
Steven_RW's Avatar
Steven_RW
You guys who just did it... why do you think you didn't get the power increases the guys back in 2007 did? I think they must have been drinking when they felt the extra power ;-).
We removed mine when we replaced it with the simple forge hose. I'd suggest no power increase and no real difference at all. Just less complex engine bay.
RW
Old Jun 16, 2016 | 02:53 PM
  #114
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by Steven_RW
You guys who just did it... why do you think you didn't get the power increases the guys back in 2007 did? I think they must have been drinking when they felt the extra power ;-). We removed mine when we replaced it with the simple forge hose. I'd suggest no power increase and no real difference at all. Just less complex engine bay. RW
Ditto. I didn't notice a difference, but I love buying mods
mQubed Motorsport, Manic Tuning Dealer
Old Jul 2, 2016 | 06:50 PM
  #115
Naylia's Avatar
Naylia
Swapping out my turbo and it's all going to be opened up so can't resist this!
Old Jul 28, 2016 | 01:36 AM
  #116
edwkmho's Avatar
edwkmho
Hi guys,
I have installed the straight stainless steel pipe spec as per this forum but it gets rip out whenever i have boost, not sure why. I have restore it to stock and waiting for my samco hoses. 2 more weeks the Samco turbo kit will be here.
Old Jul 28, 2016 | 10:30 AM
  #117
nkfry's Avatar
nkfry
Originally Posted by edwkmho
Hi guys,
You either need better clamps, or the tube needs lips put on the ends to keep tension on the clamps to keep from blowing the hose off the tube.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
06BLKchrgd
GP Talk (2006)
Feb 14, 2016 12:07 AM
The_Kid
Aug 18, 2015 06:50 PM
bleonard1401
Aug 11, 2015 02:53 PM
bleonard1401
R60/R61 Stock Problems/Issues
Aug 10, 2015 02:15 PM
jrezzo
Aug 9, 2015 10:32 PM
