Drivetrain Turbo back exhaust...
Old May 23, 2007 | 02:56 PM
mikael pug 207 gt's Avatar
mikael pug 207 gt
Hey there. I'am new here, and live in denmark. I drive an new 207 GT Turbo with has the same engine as the r56. The 207 has only 150bhp. If i fit an turbo back exhaust, will the ecu then go in safe mode, or will it work just fine like the oem system? Have you seen the dump valve from forge motorsport?
Here is a link: http://www.forgemotorsport.co.uk/con...oduct=FMDVP207
Mikael
Old May 23, 2007 | 03:46 PM
Klasse Act's Avatar
Klasse Act
Welcome aboard and if you check out Ryan's 3" turbo-back post you'll see/read that he's had NO problems with that. I too did an exhaust too, but only a flexpipe back w/o a problem BTW, can you post a pic of your ride?!
Old May 24, 2007 | 01:03 AM
mikael pug 207 gt
Hey you. I have no pics yet, but i will try to post some when i get time
What do you think of the dump valve from Forge?
Mikael
Old May 24, 2007 | 01:40 AM
Hattat's Avatar
Hattat
Mikael
I have the valve from forge. I read some reviews before about the forge valve and as far as I remember it reduces the lag. But could not notice the difference.
Everytime I remove my feet from the gas pedal, I hear the pssst noise coming from the valve. Sometimes it's boring but most of the times I enjoy hearing it.
Old May 25, 2007 | 06:23 AM
Ryephile's Avatar
Ryephile
I say full steam ahead with a turbo-back exhaust. I'd also look into logging the boost pressures, as I'd bet your engine is running less boost than the MCS, and that's why the 206's engine is rated for less power.
As for the blow-off valve, save your money for mods that work. That vent-to-atmosphere BOV will only skew the MAF's readings and cause the car to spike rich every time you let off the throttle. There's no reason right now to believe the stock diverter valve isn't 100% acceptable. If you want to hear the "Psssshhh" then I'd recommend replacing the stock airbox with a cone-type filter bolted straight onto the MAF that some of us on the forum have been trying out.
Cheers,
Ryan
Old May 25, 2007 | 12:26 PM
mikael pug 207 gt
Cheers,
Ryan
Hey Ryan. The 207 GT runs 0,8 bar of boost, and don't have the overboost function to 1 bar as the mini. I think the mini and 207 GT runs with the same 0,8 bar of boost. And for the MAF thing, it seems like the 207 don't have one. But it has a MAP sensor instead. I know that the mini have them both.
Here is a link so you can see the engine of an 207 GT with no MAF http://photos207.online.fr/2035.jpg I think i will go for a bigger intercooler, 2,5" or 3" turbo back exhaust, open filter, forge dump valve and a ECU flash, if they can break the code. Here they have done the ECU http://www.clemens-motorsport.de/207_turbo.htm
Mikael
Old May 25, 2007 | 12:58 PM
lttletimmy's Avatar
lttletimmy
Ryan,
I believe the reason the 207 makes less power is that it does not have an intercooler. As far as I know that's the only difference between our engine and theirs.
Old May 25, 2007 | 01:05 PM
mikael pug 207 gt
Originally Posted by lttletimmy
Ryan,
It has and intercooler
Mikael
Old May 25, 2007 | 06:14 PM
Ryephile's Avatar
Ryephile
Ah yes I keep forgetting euro-spec Prince engines don't have the MAF, so a VTA BOV wouldn't be a problem. Thanks for the link to the ECU tuner!
Old May 25, 2007 | 10:42 PM
lttletimmy's Avatar
lttletimmy
Mikael
I must have been mistaken, I could have sworn i read that somewhere
Old May 31, 2007 | 11:02 AM
Klasse Act's Avatar
Klasse Act
Pic of the 2007 Puegot 207 GTI
09R56
Nov 16, 2022 10:49 AM
surfblue
Oct 24, 2018 01:20 AM
theunlimitedone
Aug 31, 2015 08:17 PM
rckrzy1
Aug 26, 2015 09:12 AM
Aug 11, 2015 09:01 AM
