Drivetrain What is code 0107?
Old May 20, 2007 | 04:03 PM
mistro's Avatar
mistro
What is code 0107?
On the NJ Turnpike last night my exhaust (Borla, there have been fitment issues) suddenly developes a throater sounf and my dsc and Check Engine Light come on. Pull over turn of engine, restart dsc is off but check engine remains. OBD codes are P0300 which I believe was already in there (I had added Nologies) and this code P0107. Anyone know what it is?
Check Engine Light is on but car is running fine. TIA Michael
Old May 20, 2007 | 04:17 PM
vader's Avatar
vader
P0107 - Manifold Absolute Pressure/Barometric Pressure Circuit Low input
Old May 20, 2007 | 04:20 PM
dragonwang's Avatar
dragonwang
I would suggest to continue to drive the vehicle disregarding that CEL for about a week and see if it goes away. I have that same problem with my exhaust and header. The CEL comes and goes.
Old May 20, 2007 | 04:22 PM
mistro's Avatar
mistro
OK appreciate that but what exactly does that mean? Especially if one just got a new exhaust to fit right with no leaks...
Old May 20, 2007 | 04:50 PM
Guest's Avatar
Guest
I don't know if it means low input like low pressure or low voltage. Low voltage could be that the sensor is going bad, low pressure, I'm not sure. Sounds like for some reason you're developing too much vac?
Old May 20, 2007 | 05:40 PM
vader's Avatar
vader
Just a guess but I would say that since you described a funny, 'throater' sound, that your bypass valve stuck open causing a low pressure situation. When you restarted, it closed and all is now OK.
Old May 20, 2007 | 06:45 PM
AZMCS's Avatar
AZMCS
I agree with the BPV suggestion. Also, why do you think your nologies should cause a code? Mine don't.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
