Drivetrain Help 3k rpm stumble/flutter
Old May 6, 2007 | 09:22 PM
Urban_Assault_JCW's Avatar
Urban_Assault_JCW
Thanks in advance for any help.
Here is the problem my car is mildly modded, I have methnol injection on a jcw car with k&N filter. After running the meth injection I fouled the factory JCW NGK spark plugs. I think used to large of an injector the first time. I started to notice at 3k rpm that the car stummbles for a second and the sound comming from the exhaust sounds like a flutter or a gurgle. So I changed the spark plugs with the NGK #7 BKR7E I think is the part number, there a colder plug my friends with turbo cars that make 400 + hp use them so I figured I'd give them a chance. Gap is set to .40, I noticed a diffrence right away the car accelerated very smoothly compared to how it did, I didn't realize how fouled they were. Any way the car drives fine, pulls hard, with or with out the methanol injection on, but between 3-4k I get the stumble as long as the cars not in boost. If the car is in boost I have no problems at all.
PS, last night I drove all the way to about 6k rpm without getting into boost, I didn't know the car could go that high with out getting into boost. I was acclerating at a fairy constant slow pace trying to stay out of boost.
Old May 6, 2007 | 10:05 PM
checkmate2006's Avatar
checkmate2006
What year is your MCS because 02-06 the MCS is supercharged and that form of forced induction has constant boost and you reach full boost at 3500rpm.
Old May 7, 2007 | 06:04 AM
norm03s's Avatar
norm03s
Do you have a boost/vacuum gage?
This is not true.
I have a gage and the VGS mod. and can accelerate very smoothly to red line without going into boost. If anything, with the VGS mod I can activate the bypass valve sooner. The bypass valve is vacuum operated which is directly related to throttle plate tip in.
Old May 7, 2007 | 06:48 AM
Urban_Assault_JCW
Yes I do have a boost gauge, That's how I know that it only does it when the cars not in boost. My car is an 06 if that matters. It just started out of no where. I'm puzzled
Old May 7, 2007 | 08:41 AM
MiniMacPR's Avatar
MiniMacPR
might be a faulty bypass valve, do a search on it and see if the info that comes up sounds familiar
Old May 7, 2007 | 10:08 AM
checkmate2006
I have an 06 MCS and I have experienced this stumble and stall when ever i get old or dirty gas i just put a bottle of Lucas in and corrects the problem pretty quick and I have also found that going to different gas stations has done it also different qualities of gas cause the engine to go crazy. so to correct it I always stick to one gas station that i know has quite abit of traffic so the premium is always fresh and not old
Old May 7, 2007 | 02:23 PM
Urban_Assault_JCW
After doing some research I believe the problem is the mini ECU. I read that a few other members were having the same problem under the same conditions. I'll be getting a uni chip soon so hopefully that corrects the problem. But I'm still open for sugestions.
Old May 8, 2007 | 06:14 AM
norm03s's Avatar
norm03s
Urban_Assault_JCW
You may want to search around a bit more the uni chip might not be the proper bandage.
Just from reading a ton of posts others haven't had much praise for its effectiveness.
Check out a GIAC ECU Flash.
Old May 8, 2007 | 07:41 PM
Urban_Assault_JCW
Thanks Norm, I'll look in to it. Update the car seems to be doing it primarly in first gear.
Old Sep 26, 2007 | 04:29 AM
Babes's Avatar
Babes
my modified jcw is doing the exact same thing. I had it in today for custom unichip install to replace the MTH map hoping that would sort it but if anything it has made it more noticable. Same thing driven nicely it is no problem, at WOT it has a definate stumble at 3000.
It has only done it since adding screamin deamin ignition and nology hotwires, it goes to BMW tomorrow to run their fault codes to see what it throws and back to tuners next week to try different plugs.
Old Sep 26, 2007 | 04:44 AM
luckydoggarage's Avatar
luckydoggarage
I can fix that for you. My LDG tunes are the best out there for increased power and driveability. Stay away from piggy backs on the Mini as they just don't work. PM me for info.
Old Sep 26, 2007 | 05:00 AM
Dr Obnxs's Avatar
Dr Obnxs
If it didn't do it and now it does,
you may want to look for some vac leaks and the like before spending the problem away. FWIW, GIAC doesn't have the most stellar rep aroudn here too. But it's ECU rev dependant as well.
Matt
Old Sep 26, 2007 | 07:56 PM
Babes's Avatar
Babes
I had the butterfly flap removed from back of the JCW airbox at the same time as fitting ignition and wires, bmw seem to think that is the problem so will be taking flap back in for refitting to see if it sorts it.
Old Sep 26, 2007 | 08:38 PM
golfersmurf's Avatar
golfersmurf
Hmmm, my '06 does not have this problem, it's not a JCW but seems to run like one, err minus the stumble.
How many miles do you have? Mine's up to 8,600 I think...
I would see what your dealer thinks, either way you should track this down before doing more mods!
Old Sep 28, 2007 | 08:39 AM
fullcollapse40's Avatar
fullcollapse40
anyone try swapping in a know good coil pack from another mini ? It's worth a shot before you spend big money.
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Mini ni
Sep 24, 2015 05:42 AM
mtwaddle
Sep 13, 2015 08:10 PM
Sep 2, 2015 11:15 AM
