Drivetrain Recirculated Or BOV
Old May 6, 2007 | 07:06 PM
dxl007's Avatar
dxl007
Recirculated Or BOV
So I just got my R56 and from what I understand its recirculated, hence no psssst endless you install an after market intake.
Has anyone looked into making it a true BOV? I know some cars will almost cut off if it has a MAF and you change it to BOV.
Thanks.
Old May 6, 2007 | 09:13 PM
ygblat's Avatar
ygblat
Preliminary thought is that venting to atmosphere will fool the MAF and drive the ECU crazy, with imminent power loss. When someone finally cracks the ECU and provides a user-tuneable program (ARE YOU LISTENING, VISHNU???), maybe a provision could be made for a BOV but until then, I can't imagine it will do anything positive for the car unless you are just after the pssst.
Old May 7, 2007 | 05:06 AM
dxl007's Avatar
dxl007
Yeah, I am just looking for the loud pssssst. As childish as it may be, it makes me smile every time.
Old May 7, 2007 | 07:10 AM
RR56's Avatar
RR56
Put the intake on and you got the sound.!!!!!
Old May 7, 2007 | 09:10 AM
mikeg4572's Avatar
mikeg4572
+1 on that.
Old May 7, 2007 | 09:29 AM
dxl007's Avatar
dxl007
Is it loud, or is it LOUD?
Old May 7, 2007 | 09:37 AM
mikeg4572's Avatar
mikeg4572
Its not LOUD, but the car next to you can hear it too.
Old May 7, 2007 | 11:31 AM
Klasse Act's Avatar
Klasse Act
Please read!
Check out the "homemade intake" thread, this mod is gaining momenturm
Old May 7, 2007 | 02:45 PM
dxl007's Avatar
dxl007
Yeah I did, waiting on alta to see thiers
Old May 7, 2007 | 03:19 PM
RR56's Avatar
RR56
saw the ALTA piece first hand at the Dragon....I still think that the filter needs to be enclosed into a cold air box. ALTAs intake lets the pressurized hose from the headlamp take its normal path and pours its air out under but parallel to the filter. The one I am working on turns the air feed up to force it into the filter and once I create my box to trap the air it should show more improvement. I wonder if my setup is louder than others? I can really hear the car when it comes on boost, not just when the valve closes.
Old May 7, 2007 | 04:43 PM
cboggess's Avatar
cboggess
Generally, when going from a recirc bypass valve to a atmos. BOV without a proper tune you will run very rich at shifts. Additionally, the ECU will NOT be happy, and will start to do things to pull power.
Old May 21, 2007 | 01:00 PM
jymontoya's Avatar
jymontoya
This is not always true.
VW's new 2.0T runs fine when using a diverter valve release:
http://www.atpturbo.com/Merchant2/me...egory_Code=FSI
Yet another area where we should be looking at the VW guys for help.
Old May 21, 2007 | 01:45 PM
MotorMouth's Avatar
MotorMouth
I've heard a r56 with an aftermarket intake. You could easily hear the pssshhht from a good distance away.
Old May 22, 2007 | 11:14 AM
improvius's Avatar
improvius
Here's what Mike from Forge Motorsport (a very reputable tuning/aftermarket manufacturing shop) had to say recently on a thread at vwvrotex:
Neither type of valve is "better" than the other concerning function, operation, reliability, etc.Both serve to vent residual charge pressure at throttle lift to prevent reversion back into the compressor wheel preventing lag upon reapplication of the throttle. Whether the air is vented to atmosphere or recirculated makes no difference as to preventing reversion and subsequent lag.
The only reason to reciculate is if the engine management system (MAF-based usually) requires it or for quiet operation.
MAP-based engine management systems can easily run an atmospheric valve with no change to the driveability of the car. The reason OEM's use recirculating valves, however, is to maintain quiet operation. Think Neon SRT-4, BMW 335i, etc.
Since VW uses MAF-based engine management systems, they then have to use reciruclating valves. Had they used a MAP-based engine management from the begining, they still probably would have used a recirculating valve as OEM, but only because they're quieter.
The FSI ECU, however, does not appear to be quite as sensitive to atmospheric vs. recirculating operation, and is why we're not seeing any issues with our valve spacers. There are other reasons why adapting universal atmospheric valves are not having success as I've mentioned in another thread.
Old Jun 7, 2007 | 10:43 AM
AZMCS's Avatar
AZMCS
Just to clarify, the Forge "BOV" that has been available for a long time now is simply a spacer and noise maker. The electronic DV is still in place and functions in recirc mode. They have recent released a new DV solution for the 2.0TFSI engine that allows the use of a mechanical valve for reliability at high boost levels as many of us were blowing the rubber diaphragm in the OEM units. This new setup still incorporates the electronic system in a piggyback style fooling the ECU so no CEL's are thrown. The issue I have heard with this already is serious compressor surge. No bueno for your turbo long term.
In regards to MAF vs. MAP based tuning, even with an ECU reflash it is no simple deal to convert from a recirc system to an atmospheric system. The MAF will still be looking for that flow. True, you do run a LARGER MAF housing, but it is still there. Believe me, this causes no end of fits for those of us running FI VR6 applications. It's easier to run recirc bottome line. Leave the "pfffssst" to the SRT-4's.
Old Jun 9, 2007 | 12:58 PM
a96bimmerm3's Avatar
a96bimmerm3
I installed one of the forge plates in a buddys gti, the actuator just vents to atmosphere, there is little to no recirculation. How do you think it makes noise? His car acted fine with it. Had apr tune and a turboback. e-dv rules
Old Jun 9, 2007 | 04:35 PM
AZMCS's Avatar
AZMCS
Hey, just going off what Mike at Forge has said time and again on the Mk5 forums and golfmkv.com......The spacer is just that.....a spacer......I can think of few things more annoying than hearing this thing go off. It is crazy that tooling around in a parking lot, off boost, that it makes noise...just screams RICE....IMHO....
Old Jun 9, 2007 | 07:12 PM
a96bimmerm3
For the first 3 minutes it was a cool mod... but YES i agree totally. Its like the SRT4 bov plate, it goes off ALL THE TIME and gets pretty irritating. I think the sound you get from an intake is more than noticable enough.
Old Jun 9, 2007 | 10:08 PM
AZMCS's Avatar
AZMCS
TOTALLY agree. With a nice intake the car sounds sick. Add a good ECU flash like APR or Revo and the car is very fast.
Old Jun 10, 2007 | 11:33 AM
a96bimmerm3
apr should make a mini tune
Old Jun 10, 2007 | 01:18 PM
-Vampyre-'s Avatar
-Vampyre-
I didn't think recirculating was done for quietness. I though it was technically illegal to vent to atmosphere in the U.S. I may be wrong though.
Old Jun 10, 2007 | 05:28 PM
a96bimmerm3
You are entirely correct.
Old Jun 11, 2007 | 12:33 AM
AZMCS's Avatar
AZMCS
Both reasons are true.
Old Jun 29, 2007 | 08:31 AM
lalaboi's Avatar
lalaboi
It's here! Just reach here a moment ago.haha..
Installation should be very easy. Just a adapter to the existing solenoid with holes to let the gas out, Said to improve performance because it expel the hot air from the recirculation valve instead of turning the hot air back to the intake.
www.forgemotorsport.co.uk
Will update again after installation!
Old Jun 29, 2007 | 10:59 AM
Hattat's Avatar
Hattat
I have the same BOV but I removed after 2 weeks of motoring. It started to be disturbing to hear the pssst noise every time I remove my foot from the gas pedal.
