Drivetrain "Standard" mods only make 7 WHP ???
I had my car dyno'd when it was stock, and just had it redone after having the "standard" mods done to it, namely pulley, intake and exhaust. Specifically, I added:
WMS 15% reduction pulley
Alta V2 Cold Air Intake
Milltek Exhaust
I also had the dealer flash it with the JCW flash. Is it possible the JCW flash is making things worse? I had been expecting more like a 25 WHP difference, but only picked up 7.
Here's the dyno charts:
Stock 2005 Cooper S Convertible, 17x7.5 inch Rota Subzero Wheels. Run in 3th Gear.
Atmospheric Conditions: 76.09 deg. F, 28.18 in-Hg, 12% Humidity. STD 1.06
Modified 2005 Cooper S Convertible, 17x7.5 inch Rota Subzero Wheels. 15% WMS pulley, Alta V2 CAI, Milltek Catback Exhaust, JCW ECU Mapping. Run in 3rd Gear.
Atmospheric Conditions: 94.24 deg. F, 27.63 in-Hg, 6% Humidity. STD 1.10
Milltek Exhaust
You made 20 ft/lbs of torque, that's not something cry about. As for the HP, remember each dyno run is going to be slightly different. Did you run 3 times and average the runs?
163 wHP isn't that bad either. Remember the car is rated from the factory at 168 wHP. At 163 wHP, with 10% drivetrain loss you're making 181 bhp.
With a pulley, intake, and exhaust, most people are making between 170 and 185 whp. 170 wHP is certainly respectful considering it was close to 95 degrees out when you did the run
JCW software isn't going to do anything at all for your HP.
Milltek Exhaust
Milltek Exhaust
Thanks for the info Nick,
I am running 91 octane, (the best we can get here for pump gas), but I did not change the plugs when I changed the pulley. So cooler plugs might help? Any recommendations?
I personally run the NGK's and haven't had any issues.
One Heat Range colder would be BKR7E1X-11, I run 2 ranges colder, BKR8EIX-11 I think.
I'd definitely run colder plugs with more boost to prevent pinging, especially because it seems like you live in a warm climate. If your car is indeed pulling timing to prevent pinging you could pick up anywhere from 5-15 HP depending on how much timing it's pulling.
I remember seeing a post the other day with an online store selling the plugs for $9 each or so, I can't seem to find it now though. Where are you physically located? Danny at MiniCorsa in Van Nuys, CA sells them for a similar price. I'm sure he'd be willing to send you a set in the mail. Just give him a call and let him know you want a set of NGK Iridium Plugs 1 or 2 steps colder. He knows all the part numbers. Tell him I sent ya
Well, for one thing it was 76 deg. when you did your baseline dyno and it was 94 deg. when you dyno'd with the mods. And with all that extra heat you would surely need colder plugs, otherwise the ecu will retard the timing.
Call Danny, he'll get a set of plugs out to you and you can see where it goes from there. You may want to ask the dyno shop to give you a copy of your dyno runs corrected to SAE (59F, 29.92 in/hg, At Sea Level). That will give you a better idea of what kind of power you actually made
These appear to be the JCW plugs at a great price:
http://www.ngk.com/results_cross.asp...r7equp&x=0&y=0
Shadetree Modder
I think my 'corrected average' was 178wHP. I didn't think that was too shabby. And the 'butt dyno' says it went from stupid grin to $h*t eating grin... so I'm happy!
Also, have you had the ECU remapped/reflashed/piggybacked to take advantage of the extra ponies? I'm saving up for that now, so that with my recent exhaust 'upgrade' and the ECU, I'm hoping to stay in the 190's solidly...
Well, the car definitely feels stronger under acceleration, and responds better when cruising at 70 mph without having to down shift. Before, it seemed like I had to keep it around 3000 rpm to have throttle response, now I have it at lower rpms.
Steve
The guys at the dyno shop seemed to think there was a timing problem, so maybe the plugs in the warm shop were causing some problems.
Steve
On another JCW topic, could there be a problem using the JCW flash without the JCW injectors?
Steve
Steve, the temp makes a huge difference. I had my car on the dyno last night too (just after Steve's) and the heat soak between runs was crazy. My 1st pull had me at 174hp at the wheels, 10-15 mins later, it came in at 156.
According to this post https://www.northamericanmotoring.co...38&postcount=4
they are NGK BKR7EQUP so Hwydsgnr's post lists the correct plugs, which are the 4 electrode type. Supposed to cost $35 to $40 each at the dealer.
That was a suggestion I was going to make, but you beat me to it. If your software is looking for 380cc injectors and they aren't there, then it may be getting starved of the fuel it needs.
Since it's an OEM program, there's a good deal of latitude in the programming, it should automatically adjust to the injectors in there. Honestly the JCW program doesn't even do anything. I didn't notice any difference at all. The only reason I flashed the JCW program instead of stock is because I didn't have access to the stock program at the time.
HP sells cars and TQ wins races, Cheers
