Drivetrain "Standard" mods only make 7 WHP ???
Old May 3, 2007 | 02:43 PM
  #26
Steve_LV's Avatar
Steve_LV
Originally Posted by rustyboy155
Since it's an OEM program, there's a good deal of latitude in the programming, it should automatically adjust to the injectors in there. Honestly the JCW program doesn't even do anything. I didn't notice any difference at all. The only reason I flashed the JCW program instead of stock is because I didn't have access to the stock program at the time.
I've ordered the NGK Iridium plugs, so hopefully that will help the timing issue. Can a different ecu tune or flash (MTH, Unichip, or custom) also affect the timing, or only the air/fuel ratio?
Old May 3, 2007 | 03:00 PM
  #27
SharoSC02's Avatar
SharoSC02
Originally Posted by Steve_LV
I'm in Las Vegas, so yeah, it gets real hot here. The second set of dyno runs were done about 20 degrees hotter. How much difference would that make?
Steve
Steve the heat is THE major factor in power loss. I recently ran 3 tests on my car. The 1st 2 runs when the car was hot with 79 degree heat it came to 191 whp. The 3rd run however I cooled the car down and then ran it and I came to 206 whp. A whopping 15 extra horses.
My next project is going to be brand new MSD coils from Summit Racing, better CAI (possibily Alta or M7), SGR air-air IC from England (water to air is too expensive and some have stated that water does tend to get warm on hot days and when running the car for a long period of time) and a DT BPV.
I will then drive my car to Burbank Cali to meet with Emil that worked on Mario's car and get a nice tune. I like to see my car do somewhere close to 240 whp by then.
Old May 3, 2007 | 03:21 PM
  #28
chows4us's Avatar
chows4us
163 wHP isn't that bad either. Remember the car is rated from the factory at 168 wHP. At 163 wHP, with 10% drivetrain loss you're making 181 bhp.
An 05 MINI is rated at 168 WHP from the factor? Since when.
I thought it was BHP, not WHP?
Old May 3, 2007 | 03:59 PM
  #29
TonyB's Avatar
TonyB
I too noticed that earlier post, but was too busy to reply, and since forgot. Stock MINI's (53's) typically dyno in the mid 140 range - WHP. Indeed, the 163/168 is at the crank...
Old May 3, 2007 | 06:12 PM
  #30
SharoSC02's Avatar
SharoSC02
I 3rd this motion.
Old May 3, 2007 | 07:32 PM
  #31
Steve_LV's Avatar
Steve_LV
I knew the rated 168 hp was at the crank, that why I was happy with the stock 163 whp, though I didn't really believe it. From everything I had read, the important number was the delta, the difference between the two readings. That's why I was more disappointed with the 7 hp difference, rather than the 170 hp total.
Steve
Old May 4, 2007 | 06:52 AM
  #32
chows4us's Avatar
chows4us
Steve
You didn't quote that ... Rusty said that. Sounds like you had a strong engine to begin with
Old May 13, 2007 | 12:43 AM
  #33
howsoonisnow1985's Avatar
howsoonisnow1985
High octane petro? At AmVIV I noticed most Rebel Petrol Stations had 94 OC and 100 Octane petrol (from 76), the NGK Iridium Plugs plus cooler wires will be good. Also some tips try you dyno run early in the morning (cooler) and buy the biggest/cheapest fan at your nearest home depot and stick it in front of your MINIs intercooler on highest setting. Please post results after 100 octane and plugs /wires upgrade plus fan.
Old May 13, 2007 | 03:03 AM
  #34
Paul Webster's Avatar
Paul Webster
I now understand why some of the cars on there dyno sheets are flat lining at 6000 due to the 91 that you are using, I couldn't understand why this was as most of our cars continue the line at 6000 to 7000.
We are lucky to have very good 93+ over here as well, though we have had cases where staions have been selling 93 but really they've had 91 in the tanks.
Old May 13, 2007 | 10:16 AM
  #35
Sin MINI's Avatar
Sin MINI
Originally Posted by Agro
Steve, the temp makes a huge difference. I had my car on the dyno last night too (just after Steve's) and the heat soak between runs was crazy. My 1st pull had me at 174hp at the wheels, 10-15 mins later, it came in at 156.
Agro, I'm thinking of doing the same mods as you on the drive train (one-ball, HAI, and the pulley. Do you have before and after Dynos?
Old May 13, 2007 | 01:51 PM
  #36
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I have a dyno with just the pulley and a BMP intake, and then the recent one with pulley, HAI, one-ball and Fireballed ECU. No stock one, sorry.
Old May 13, 2007 | 01:52 PM
  #37
AZMCS's Avatar
AZMCS
Couple of things:
1-you can try to estimate what you would put down if your ambients were the same all day long. Bottom line is unless you can dyno in an A/C setting you will have to wait until the fall to see just how much the temp was affecting your total WHP
2-Out here in the SW I know several folks who run 2 steps colder for their plugs. I have been doing this for 2 years without any cold start problems or idle issues.
3-Hitting the numbers you did on a Dynojet seem low. With similar mods I hit 169whp on 2 seperate mustangs and a dyno dynamics unit. Maybe try a shop with one of these? If you are looking for numbers.
Anyway, I congratulate you onhavingput in the effort to dyno before and after the mods you did. Kudos!
Old May 13, 2007 | 02:00 PM
  #38
Guest's Avatar
Guest
Typo... I meant bHP. Many stock 05-06 MINI's ARE dynoing in the 155-160 wHP range though . All the higher HP cars appear to be the new engine with the new SC.
Old May 13, 2007 | 03:04 PM
  #39
Alex5's Avatar
Alex5
Fitting the gen. 5 supercharger and Alta V2 15% made 33whp on my early '03 MCS. The only other mods I have (which were on before any dyno testing) were GRS intercooler and Madness CAI). Alta say the pulley should give 20whp with no other mods on their site, so the SC must be responsible for some of the gain. In the end 186.7whp
Old May 13, 2007 | 04:53 PM
  #40
Guest's Avatar
Guest
Indeed MINI made several running design changes. Most of the people having issues coming close to 200 wHP without spending 8-10k have the 02-04 MINI's. The SC with coated veins would definitely lower IAT's by a bit, and *should* be more efficent.
Old May 14, 2007 | 09:58 AM
  #41
greatgro's Avatar
greatgro
I had my car dyno'd when it was stock, and just had it redone after having the "standard" mods done to it, namely pulley, intake and exhaust. Specifically, I added:
WMS 15% reduction pulley
Alta V2 Cold Air Intake
Milltek Exhaust
I also had the dealer flash it with the JCW flash. Is it possible the JCW flash is making things worse? I had been expecting more like a 25 WHP difference, but only picked up 7.
Absolutely put the stock flash back on. I know a guy who did this (actually he posted his experience on this site - probably 3 or more years ago). He got the above mentioned mods and the JCW thinking the JCW tuning would be better. He actually lost significant amounts of HP. In fact, he switched it to the GIAC software (avail from Helix) and gained 20 more HP I think. Normally the GIAC makes 7-10 hp I think but since the JCW tune lost power, adding the GIAC was night and day.
The JCW is tuned specifically for the JCW. The JCW also uses larger fuel injectors. If you don't have the exact JCW mods, the JCW tuning will make your car worse, not better.
Old May 14, 2007 | 10:26 AM
  #42
SpiderX's Avatar
SpiderX
Good advice...
Old May 14, 2007 | 10:42 AM
  #43
davydo's Avatar
davydo
ASide from injectors, remember *headwork*, as I mentioned on page 1.
Mini wouldn't go through the trouble of putting another head on unless it was somewhat worth it IMO.
Old May 14, 2007 | 10:44 AM
  #44
minimusprime's Avatar
minimusprime
debatable... i believe injectors are the root of the issue. Still another reason to throw on the pile to remove the jcw flash.
just remember with bolt ons... 2+2 != 4 (for those of you coders)
I'd be pretty pumped about your tq gains.
Old May 14, 2007 | 11:06 AM
  #45
Steve_LV's Avatar
Steve_LV
Thanks for all the input. I've got the cooler plugs on now (1 step cooler NKG's) and I think I have a dyno appointment set up for early Saturday morning. Will post when I get it done.
As far as the JCW flash, It really smoothed my car out from the stumble when it was cold. The car used to try to die when I was backing out the driveway, so in that respect, I like it. I have been looking at getting either different flash, or a custom tune eventually.
Steve
Old May 14, 2007 | 11:43 AM
  #46
AZMCS's Avatar
AZMCS
Steve
The Garret flash is quality. Another, better option IMHO, is to send your ECU off to LDG and have a semi-custom tune done. I know they are turning these around within a week with overnigth shipping....something to look into.
sevin
May 2, 2026 06:11 AM
ebowling
90
Aug 4, 2019 09:15 AM
boostedhaze
Jan 2, 2018 07:26 PM
minipopkart
Aug 13, 2015 05:22 AM
flredmini
Aug 12, 2015 06:35 PM
