Cleaning Under the Hood
Old Jan 26, 2007 | 04:29 AM
rc'S's Avatar
rc'S
MCS, can I clean the engine compartment/motor with the $0.25 carwash? Or best way if not....
Old Jan 26, 2007 | 04:58 AM
ScottRiqui's Avatar
ScottRiqui
You can, but keep in mind that a pressure washer is a powerful tool, and like any other tool, can be misused/abused with disastrous results.
Keep the tip of the sprayer a safe distance away from electrical parts like the ECU & Fusebox to reduce the pressure. Don't spray down the engine while it's hot, and make sure you rinse off all of the soap/cleaning solution.
Old Jan 26, 2007 | 08:49 PM
OctaneGuy's Avatar
OctaneGuy
Yep when I wash the engine bay I spray on a light degreaser, then I use a soft square wheel brush with a handle and gently brush the parts. I use different sized brushes to get to smaller and tighter areas. The paint on the engine bay isn't clearcoated so it will rub off if you rub too hard. Like Scott said, you need to be VERY gentle. Watch out for the alternator on the left side of the engine by the drive belt.
I use very gently flowing water to rinse off the engine bay or use a bug sprayer filled with water when I need a bit more pressure.
Old Jan 27, 2007 | 06:42 AM
kenchan's Avatar
kenchan
octaneguy- so basically you wipe off the crud with paper towels at the end?
i use paper towels mostly and use like 1/2 a roll (well, not that much but
feels like it). (more on my commuters).
is there anyother way to lessen the wasted paper?
Old Jan 27, 2007 | 06:57 AM
lotsie's Avatar
lotsie
Try this. Spray Simple Green on a slightly warm engine, spray it on everything. Close the bonnet and let it sit on there for 15-20 minutes, QD the rest of the car to pass the time. When the time is up, rince with a hose, just watch the air intake, I stuff a rag in it when I start.
Then I spray everything black/plastic with Aerospace protectant, leave that on the still warm engine for a few minutes, then wipe that down. I use QD on the painted parts, and it looks great.
I tried paper towels, but I tended to get paper bits on the pointy bits, so I use older micro towels.
Mark
Old Jan 27, 2007 | 08:25 AM
OctaneGuy's Avatar
OctaneGuy
I don't think I ever mentioned paper towels. I dry it with an old Absorber. It's great for soaking up those little pools of water around the engine mounts.
The crud is removed with the soft body brush and car wash soap. If I need more cleaning, Super Degreaser or APC (All Purpose Cleaner) are sprayed on first, then brushed with the body brush and car wash soap. Then it's rinsed off.
I then dress the plastics with Hyperdressing (spray on, let dry, wipe off excess with mf towels), a water based dressed with an extremely high flash point that won't ignite or promote engine fires when heated up.
Richard
Old Jan 27, 2007 | 08:29 AM
kenchan's Avatar
kenchan
thanks, octaneguy. i should get those target/costco MF for such
occassions then... and i'll probably end up tossing them after use.
Old Jan 27, 2007 | 08:38 AM
OctaneGuy's Avatar
OctaneGuy
That's what I use them for too, but I keep them and reuse them.
They stay black and dirty after washings so you will never confuse them for body towels.
Richard
Old Jan 28, 2007 | 08:15 AM
ImagoX's Avatar
ImagoX
Good tip... Thanks!
Old Jan 28, 2007 | 09:05 AM
Crashton's Avatar
Crashton
Very good tips here. I've used Simple Green to good effect over the years. I'd advise using a somewhat diluted solution. My best tip is clean your engine once a year & it will never get dirty enough to need much cleaning. As for drying I blow the engine off with compressed air & use the cheapie microfibers for any hard to get water.
Old Jan 28, 2007 | 09:45 AM
ScottRiqui's Avatar
ScottRiqui
Yep - my motto when it comes to detailing cars and bikes is "The cleaner you keep it, the easier it is to keep it clean!"
Old Jan 28, 2007 | 10:30 AM
morknmini's Avatar
morknmini
I did that with old cars (pre-computer chips). Compared to today's engines those things were simple and industrial. I would be afraid to knock something out of place using a powerwash hose on a MINI's compact engine.
This might have been aired here already but I read that the German government, due to potential dangers, may become the first to advise against using power hoses to wash tires and the edge between the rim and the tire. I spent extra time doing that especially because of the brake dust.
Old Jan 28, 2007 | 02:45 PM
kenchan's Avatar
kenchan
hey, that's my toilet cleaning motto!
YO MUDA
Oct 5, 2015 04:14 PM
minners
Sep 21, 2015 09:26 PM
OdzBodkinz
Sep 11, 2015 07:20 PM
Sep 3, 2015 01:45 PM
MiniSMan
Sep 1, 2015 06:49 PM
