Steering Wheel Emblem
Old Dec 29, 2006 | 11:12 AM
DOT191's Avatar
DOT191
The Mini Logo in the Center of the Steering has started to flake & look like it is Peeling. Mini says these are replaceable with a New Emblem. They are atttached with Double Back tape.They said you can use a small pick to remove the damaged one & then put the New one on. The emblem itself sells for $3.90. Not a bad Price. My question is has anyone done this? If so was it difficult removing the emblem & then putting the New Emblem on? Thanks.
2003 MC. PW/B, CVT,DSC, Premium Pkg, Fog Lamps, After Mkt Rear Spoiler & Center & Door Arm Rests.
Old Dec 29, 2006 | 11:15 AM
rubyred3's Avatar
rubyred3
it'll come off pretty easy, my wifes actually bent cuz she slammed her horn so hard at this SUV that almost merged into hers, and the emblem started to peel up on the side. Good to know that it can be replaced, she was really worried about it. You don't have a part number do you?
Old Dec 29, 2006 | 01:04 PM
ddminikc's Avatar
ddminikc
Originally Posted by DOT191
...They said you can use a small pick to remove the damaged one & then put the New one on...
Did MINI just change this? I took mine in about 2 months ago for a peeling emblem and they replaced the entire airbag. They said it would have been over $500 if not under warrenty!
Old Dec 29, 2006 | 01:11 PM
DOT191's Avatar
DOT191
Emblem
No i did not get the P/N From the Mini dealer.I plan to order one Next Week.
Call or E-Mail your Dealer,s Parts Dept. They should be able to Help you. Thats how i found out about this. Thanks for info. Glad to hear your Wife escaped That RUDE SUV Driver.
Old Dec 29, 2006 | 01:15 PM
dickdavid's Avatar
dickdavid
That's what I heard. Mine has been peeling up since the first week and i forgot to get them to fix it at my first service. Looks like I'll need to get it done on the second because I'm not forking out $500 for a defective product.
Old Dec 29, 2006 | 01:24 PM
DOT191's Avatar
DOT191
Emblem
The Dealer, Mini Of Peabody, told me that the Steering Wheel & or the Emblem was covered if Vehicle was still under Warranty. If out of Warranty the Emblem was $3.90 & The Steering wheel was appx. $310.00 + Installation. So, since my Steering is Fine just going to change the Emblem
Old Dec 29, 2006 | 01:50 PM
05DSMCS's Avatar
05DSMCS
That's great to hear. Mine was pulling up and I was trying to see if I could pop it out and it bent. I asked my dealer about replacing it and he said that since I messed with it, I'd have to pay for it (fair, but a bummer) and only quoted me the full airbag replacement cost. I'm going to look into this, as the service guys bent it back into place for me, but it still doesn't look great.
Old Dec 29, 2006 | 07:06 PM
kenchan's Avatar
kenchan
yah, doesn't it suck? when you press that emblem to sound the horn
and all you hear is CRACK!
Old Dec 30, 2006 | 01:27 AM
DOT191's Avatar
DOT191
Wheel Emblem
The Emblem that i am replacing is for an 03 Mini. The Steering Wheel is a 2 Spoke Wheel. I believe that Mini Changed the Design of the Steering Wheel on the 05 models. So not sure if the Emblem,s are the same. As i understand from my dealer i only have to peel off the old Emblem & put the new one on. Removal of the Center Hub is not necessary & should not be removed due to the Air Bag.Hope this further info helps
Old Dec 30, 2006 | 06:48 AM
jonnieoh's Avatar
jonnieoh
Mine isn't peeling or bending, but it has many small dents in it. This is because as I put the seatbelt on and take it off, the metal sometimes "brushes against" the embem, and the silver trim ring surrounding it, leaving small dents.
Apparently the trim ring material is not ver durable, because I am not really contacting it very roughly...
This is a cosmetic thing only, but it annoys me. I hope they replace it under warranty, because it seems awfully fragile to me.
BTW, my car is an '04 with the 2-spoke (the superior) steering wheel...
Old Dec 30, 2006 | 07:11 AM
DOT191's Avatar
DOT191
Steering Wheel
I was born in Syracuse & raised in Rochester. Was in Rochester this Past June. Took our Mini. About an 8 hr drive from NH.Got 36 MPG & a lot of Positive Comments on the Mini from those attending the reunion. Could not agree with you more re we have the the Better Steering Wheel.
Doug
Old Dec 30, 2006 | 08:59 AM
rhawth99's Avatar
rhawth99
On the 2005 three spoke steering wheel, the entire unit (which includes the airbag) is replaced when the emblem starts to stick up. We've had two replaced on my wife's - it's been the only thing that has gone bad besides the clock not keeping correct time.
Old Jan 1, 2007 | 09:26 AM
05DSMCS's Avatar
05DSMCS
Shoot, so no luck with the '05's and later, huh? I would really like to change mine out, but don't want to spend the $500 on it.
Old Jan 2, 2007 | 12:35 PM
jwardell's Avatar
jwardell
Interesting, I had always been under the assumption that it was not available separately from the steering wheel. Mine's not looking very good any more either. I was going to ask if this was for the newer 3-spoke but you then said it is for (my) older 2-spoke.
Next time I'm in MOP I'll grab one from Scott. You were able to just pry it out with a small crewdriver? A heat gun will probably help too. I may try this soon.
Old Jan 2, 2007 | 12:49 PM
The Italian Job's Avatar
The Italian Job
Emblem
I have an '02 with the two spoke wheel and my emblem started to look quite pitted. The dealer replaced it under warrantee but my service advisor, and the receipt, said it required the entire airbag assembly to be replaced. I can't imagine MINI USA paying for an airbag replacement if it only required a $4 part and some sticky tape.
I hope, for you, that was bad info and all you have to do is pry the old one off. I would consider disconnecting the battery and/or whatever else would be required to deactivate the airbag. It could be very dangerous if it accidentally goes off because your pry tool slips or something.
Good luck
Old Jan 2, 2007 | 01:01 PM
planeguy's Avatar
planeguy
OK....I think we need to clarify what part is peeling and what part is replaceable. My understanding is that the center black piece with emblem is replaceable, but the outer silver is not! I found this photo once that told me that I was out of luck because it is the silver ring that i need to replace on mine....but if it is the black badge then you may be in luck
Old Jan 2, 2007 | 01:02 PM
rubyred3's Avatar
rubyred3
I just spoke to the parts guy at Flow mini and he said that it was not possible to order just the emblem for any year cooper, and that the airbag cover would have to be replaced to get a new emblem.
Old Jan 3, 2007 | 05:42 AM
DOT191's Avatar
DOT191
Emblem
You and others are correct. Mini of Peabody informed me Yesterday that they had misinformed me re this. Sorry about this.I will live with the Emblem that i have
Old Jan 3, 2007 | 09:33 AM
jwardell's Avatar
jwardell
Damn. :( I wonder if someone like AC can at least make nice stick-on ones?
woodstudio
Mar 15, 2020 08:28 AM
Manny_cooper
Sep 10, 2015 11:09 AM
trw92a
Aug 26, 2015 01:47 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
