Cleaning your detailing cloths?
Old Nov 20, 2006 | 12:20 PM
  #26
kenchan's Avatar
kenchan
Originally Posted by S Curvz
Ken do you have the shinny racks from sams? I have some of those on wheels its very nice. wish they weer not as deep, I find I keep alot of junk on them just because the space is there. Hence the need for the detail cart. I will get pictures of the garage soon, well, as soon as the MINI goes into storage.
is that like the ones at the ContainerStore? the one at the CS were
a little too flimsy for garage use as it felt too light and fragile... but it
might not be bad for light use. i wish someone can make a small
plastic one with high quality quality drawers and casters that
i can roll around the garage in tight areas. not necessarily just for
detailing, but to do electronic work on cars. i don't need a full blown
service cart to do stereo and interior installs... and i dont want any
carts with metal edges as it will ding/scratch car panels if it rubs
agains it.
here's the Elfa from CS... not strong enough for gargage use...
Old Nov 21, 2006 | 07:28 AM
  #27
S Curvz's Avatar
S Curvz
My shelves look like the ones from Griots, but just silver. That cart looks nice, but I too would worry about that around the cars.
Old Nov 21, 2006 | 08:39 AM
  #28
ImagoX's Avatar
ImagoX
How do you clean off synthetic wax, Octane? I usually use dish soap and hot water and a LOT of scrubbing, and it seems like all of the wax never comes out. I worry about it curing inside the pad foam and making it stiff/scratchty... Am I being too ****?
Old Nov 21, 2006 | 08:43 AM
  #29
kenchan's Avatar
kenchan
oh, ok. those are good shelves. Im using a Metro shelf (i believe is
the same ones Griots sells) in white. that's the shelf you see that i
converted into a workbench/shelf. I im using several layers of plywood
on the top along with several layers of MDF. Im also using a 2" trim on
the edges to dress it up a little (layers of wood does not look real nice).
It's pretty solid especially after loading it up with the tool boxes.
It's a huge space saver for my garage and looks nice.
The shelves you see on the sides are from HomeDepot. i forgot the
brand but it's the typical household use one in gray.
Old Nov 21, 2006 | 08:44 AM
  #30
S Curvz's Avatar
S Curvz
only issue I have with wall mount shevels, is in the garage they fall
Old Nov 21, 2006 | 08:50 AM
  #31
kenchan's Avatar
kenchan
really? perhaps you loaded up too much?
ive never had one fail yet. not that it means it never will...
but i don't load it up too much.
Old Nov 21, 2006 | 08:51 AM
  #32
S Curvz's Avatar
S Curvz
There wasnt much on them when they fell. For some reason they do not hold well in my garage, even when in the studs. They work great in the basement though. No car to scrach if they fall
Old Nov 21, 2006 | 09:10 AM
  #33
ImagoX's Avatar
ImagoX
Use longer screws or screws with wider threads if they're falling. Unless you're storing rims/wheels or your weight set on them?? If you're going intot he studs, the shelf supports should buckle before the screws pull out of solid wood, bro.
Old Nov 21, 2006 | 09:15 AM
  #34
kenchan's Avatar
kenchan
hummm.... maybe your stud's rotting?
mine are solid. i use large screws and make sure not to overtorque
them. i have a ladder on one of the walls above my MCS and for that
i have a backup latch i made on it so that if the hooks fail it will not
fall on my car. i would have to literally cut the latch to get it
off the wall...so only when i really mean to really use it does it come
off the wall.
Old Nov 21, 2006 | 09:18 AM
  #35
kenchan's Avatar
kenchan
it will never hurt to clean the pads thoroughly to the point there is no
wax in it, but i think the most important aspec of cleaning the pads is
to make sure the top surface is clean.
if you can get most of it out you should be fine. That's why you
want to dedicate a pad for each wax or polish you use.
Old Nov 21, 2006 | 10:16 AM
  #36
S Curvz's Avatar
S Curvz
Wow thats bright! I knew I needed more light, but I didnt realize I was lacking that much!
Longer screws would work, but I gave up on it. I also like the ablility to move my schelves. You will see why soon enought.
Old Nov 21, 2006 | 10:49 AM
  #37
ImagoX's Avatar
ImagoX
Mounting the ballasts like that is an interesting idea... I'm planning on adding two ballasts on the ceiling in a few days.
  #38
kenchan's Avatar
kenchan
^^ yah, i have 2 full sized flourescent lights on that wall, 3 units
on the other wall, i also got 4 more on the gargage door opener
unit (additional lights), one on the ceiling, 4 more lights on the
walls. yes, it is nice and bright in the garage when needed.
and they all are connected wirelessly so easy to turn on/off. even
the fan is on wireless switch.
Old Nov 21, 2006 | 10:55 AM
  #39
S Curvz's Avatar
S Curvz
Matt, Its how I spell it when I am at work...
Ken, Wireless? Can you explain?
Old Nov 21, 2006 | 11:00 AM
  #40
kenchan's Avatar
kenchan
scurves- wireless switch...so i don't have to do any hardwiring.
Old Nov 21, 2006 | 11:03 AM
  #41
S Curvz's Avatar
S Curvz
Just somehting you can get at HD or Lowes? I havent looked yet, but with the possiblity of moving soon, I would like to be able to take the lights with me...and I dont like wireing.
Nice
Old Nov 21, 2006 | 11:10 AM
  #42
kenchan's Avatar
kenchan
^^ you can get them at RadioShack. flourescent lights are a little
tricky to use wireless as some of them flash while off...it's like static
electricity built up in them that it has enough power to turn itself on
on occassion if you dont use the right switch.
there's one wireless switch RadioShack sells that prevents this
from happening... and i can't find the model at their site... hummm....
I think it retails for like $19... i got it at a RS store that was closing
down at 1/2 price.
Old Nov 21, 2006 | 11:22 AM
  #43
S Curvz's Avatar
S Curvz
If I can get the lights for Christmas, I think I should pop for the few extra bucks for the switch. Do you have a switch for each of yours? thats alot of remotes!
Old Nov 21, 2006 | 11:55 AM
  #44
kenchan's Avatar
kenchan
I have 3 remote transmitters on the wall. one for the right wall
(channel A) one for the left wall (channel B), and using a
4 channel transmitter for the center lights, wall incandescent light,
fan, and auxiliary.
Old Nov 21, 2006 | 12:16 PM
  #45
ImagoX's Avatar
ImagoX
Just run wires or get the ballasts that plug into a standard 120v. outlet and run them off a surge protector. I'm planning on using one of those adapters that convert a standard ceiling light fixture into a pair of 120v. 3-prong outlets and just running them off my wall switch. You can run the cord across the ceiling with nail-in cable clips (available for about $3).
Old Nov 21, 2006 | 12:22 PM
  #46
kenchan's Avatar
kenchan
^^ yep, i do that too. there's an outlet on the ceiling for the garage door
opener so just ran extension cords to the walls. from there, i plugged
the RF switch and walla!
Old Nov 21, 2006 | 03:53 PM
  #47
OctaneGuy's Avatar
OctaneGuy
I've only tested carpet cleaners used for those heated carpet shampooers from Bissel, Dirt Devil, etc.. and conventional products like Simple Green. Haha, stay away from Gasoline and Acetone if you consider those as cleaners too.
Any cleaners I should stay away from?
Yep that's what I do too. I think my situation is different from others. I'm using my pads weekly, several times a week, and although I'm alternating pads to give them a rest, I don't have issues of pads getting hard. I've always just washed them in warm water to soften them.
Regardless, you should clean off your pads when you finished using them, before storage by wrapping them with a terry towel with the PC on. As you grip the pad, with the towel around it, the product will get absorbed into the towel, and you will have far less product saturating the pad. Do this a few times, and you should be fine.
Richard
Old Nov 22, 2006 | 06:35 AM
  #48
S Curvz's Avatar
S Curvz
Thats what I was going to do, but use the switches so I do not have to have them on all the time, unless the extra light is needed. but I will just run one swtich for now...
Old Nov 22, 2006 | 06:36 AM
  #49
S Curvz's Avatar
S Curvz
Richard
Haha, I was not thinking gasoline or acetone, I was thinking spotshot or resolve.
Old Nov 22, 2006 | 10:05 AM
  #50
kenchan's Avatar
kenchan
anyone try Draino? I hear it fixes constipation too. jk jk
gsredmini
Oct 20, 2015 07:43 AM
molala
Oct 2, 2015 01:53 PM
OdzBodkinz
Sep 11, 2015 07:20 PM
hardy616
Sep 2, 2015 08:32 AM
