Polish removes swirls
Old Sep 13, 2006 | 01:19 PM
  #26
ImagoX's Avatar
ImagoX
Heather knows her stuff... if we ever contradict, believe HER over me.
All I know, I learned from asking endless questions in here and doing some hands-on polishing with another NAM member's RO polisher. It really is easy and fun, and leaves even factory-new paint gleaming like a mirror!
Old Sep 13, 2006 | 02:10 PM
  #27
Prima Car Care's Avatar
Prima Car Care
<blush> Thanks for your confidence in my advice, ImagoX. You clearly know what you're talking about out there too. Indeed, you learn alot by asking questions and then doing alot of the stuff over and over (and then asking more questions, then doing, etc, etc!).
And, it's even better getting the experience when you're using a friend's polisher! LOL
-Heather
Old Sep 13, 2006 | 03:23 PM
  #28
MiniMaybee's Avatar
MiniMaybee
On your friends car!
Old Nov 3, 2006 | 02:16 PM
  #29
AggieMini
wow...I recalled seeing this thread before I ever got MINI...now that I have her and swirls...I hunted this bad boy down and started reading.
I guess I just need to try one and see what I think.
thanks for the good info...I may try Meguiars because I am anxious to try it and I see I can get it at most local stores...ex. Target.
Old Nov 4, 2006 | 04:42 AM
  #30
umberto's Avatar
umberto
just read through this...my paint has very very minor swirls which are only rarely visible in direct sun reflections and get filled in by Z5 pretty nicely so I'm not planning to address this now, but has anyone compared Srcatch-X to Zaino's Z-PC? (both for use by hand)
Old Nov 4, 2006 | 05:20 PM
  #31
MiniMaybee's Avatar
MiniMaybee
I've used both by hand on my MINI. I believe that the Z-PC is more aggressive than Scratch-X. The Zaino seemed to work quicker. When I say more aggressive, I don't mean that to sound scary - I did not get any hazing. The Z-PC removed the swirls in an area with 2 applications versus 4 applications of the Scratch-X. Both got the swirls out and both are similar in that the use a diminishing abrasive, however the Zaino worked faster by hand.
Old Nov 5, 2006 | 08:48 AM
  #32
OctaneGuy's Avatar
OctaneGuy
Heh heh, sorry for replying to an old thread, but I kinda missed all these comments that definitely need addressing.
This isn't correct. ScratchX is fine on both "show cars" and daily drivers. The diminishing abrasives in ScratchX are very mild. Please carefully read the "diminishing" part--not directed just to you ImagoX--- not all polishes that contain abrasives break down to finer and finer grits as you work with them--which is important to achieve a high level finish.
Originally Posted by ImagoX
And I've heard form the ShowCarGarage guys that the ScratchX is fine for anything other than a "show car"... In other words it's "perfectly acceptable" for regular cars. I guess "show cars" need to be polished with products that use platinum flakes or powdered semiprecious stones as a abrasive or something.
Predmini--thank you so much for the kind comments on my DVD!! It's amazing how in 2.5 hours that an entire perspective on paint care can change for the better simply by watching a pro work his magic.
Every manufacturer defines the term POLISH differently. Some interchange the term wax with polish. Meguiar's likes to define the polishes as products that improve the appearance of your paint but don't offer any protection. You've got a pure polish like #7 Show Car Glaze which just deepens the color and richness of your paint and adds gloss but doesn't contain any abrasives. Then you got Paint Cleaners like #80 Speed Glaze that contains polishes and fine diminishing abrasives to remove swirls while adding gloss.
Originally Posted by PredMini
Depends on the polish. Polishes go from no abrasives to light to heavy abrasives. Will you be doing this by hand or with a polisher? OctaneGuy's video on how to use the PC for show car results covers both both the by hand and polisher methods. - www.showcargarage.com There are clips from the DVD there. I would highly recommend getting it.
I've watched most of the video and the polisher method is WAY easier. You could probably buy yourself a nice setup of chemicals and a polisher for what you'd pay a good shop to do the work for you.....These steps are explained in great detail on the PC DVD. Watching the time it takes to do it by hand over the PC is quite a sales pitch for the polisher! You could probably have polished and waxed the entire hood (or more) in the time it took him to do a 15" x 15" test spot by hand. The end result of the PC applied finish is 99.9% of the time going to look better than a hand applied polish. You just can't physically duplicate the results of the polisher. That is unless you've had some 6 Million Dollar Man parts installed!
Oh and don't forget starting with a test spot...."if it doesn't work on one small spot, you don't want to be doing it to the whole car"
As has been mentioned-- no, Scratch X contains very fine diminishing abrasives.
Originally Posted by bamatt
Isn't Scratch X a bit harsh to use all over the Mini for swirl removal (unless your finish is in really bad shape)? I only use Scratch X as a spot treatment for major scratches.
Yep very good point---Meguiar's polishes actually remove swirls and fine scratches. That's why you have to work ScratchX in. You don't just apply it, and wipe it off.
Another thing to realize---atleast for Meguiar's products. When working with a polish/paint cleaner, you use it, then wipe it off immediately. If you're applying a wax, then you let it dry before wiping it off. This helps you remember which product needs to be left to dry or not when working.
Originally Posted by Detailers Paradise
Something worthy of note regarding polishes...
Many products state that they "remove" scratches/swirls/etc. In reality, some products physically remove scratches/swirls, while others remove the appearance of scratches/swirls (aka temporarily fill/conceal them until a wash or two later). ....
So, be aware that product statements can be deceiving about scratch/swirl "removal."
-Heather
Old May 31, 2007 | 03:16 PM
  #33
Red Scooter's Avatar
Red Scooter
After my first clay bar, I notice my black top has more swirls, etc. than I'd care to admit! Black seems a lot worse than the red for showing this kind of stuff (CR/B MCS 2006).
I have a couple of products "in stock" - ICE Liquid Clay Bar, Kit Scratch Out and NuFinish Scratch Doctor - and need some input on what to use.
I read the current posts about different levels of abrasive and the wood/sandpaper analogy but I don't know where these products fall. I have no idea how to rate ICE Clay Bar but the Scratch Out and Scratch Doctor seem VERY close. By "feel" I'd say the Scratch Out is a little less abrasive.
Thanks!
Old May 31, 2007 | 04:22 PM
  #34
OctaneGuy's Avatar
OctaneGuy
ICE Liquid Clay Bar is NOT a clay bar at all. It's about as effective as using a paint cleaner/polish on your paint. Don't bother with it if you're trying to clay your finish and make it smooth as brand new class.
It's true that black shows everything! That's why finding a swirl free black car is pretty rare unless it's a show car!
As for the polishes you've listed, why not save them for a friends car and just use what works?? Scratch X from Meguiar's or get a PC and go at it with Swirl and a white or orange pad??
Richard
Thanks!
Old May 31, 2007 | 06:42 PM
  #35
Red Scooter
Richard
Excellent! That's exactly what I needed. Some definitive advice! Was wishing I ordered some Swirl with the Hydro and Epic I just received today! Doh!
I've heard different stuff about ICE "clay bar". Was glad I checked in with the folks here first. I used real clay bar and find it amazing. I'm still finding bits here and there but I just go over the bumpy area again. Not sure exactly what to do with the ICE stuff now though. Use it when I need a cleaner?
Thanks again Richard. For now, I'm off to get some Scratch X!
Old May 31, 2007 | 07:00 PM
  #36
OctaneGuy's Avatar
OctaneGuy
I started a review here to test the claims. My results though not posted in that thread was that it didn't do the claims--it didn't remove swirls, and it wasn't effective as a claybar either.
http://www.showcardetailing.com/foru...light=ice+clay
Crimguy
Sep 10, 2015 01:07 PM
broncobuddha
Sep 1, 2015 06:32 PM
Sep 1, 2015 04:02 PM
greekzilla
Aug 23, 2015 03:44 PM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
