Scuffs on Dash and steering wheel
Hi all, sorry if a repost but I just got my kindly used mcs and she has a large white scuff on the dash and another on the center logo of the steering wheel. Any ideas to remove them? They are definately not scratches. I was thinking a white eraser?? Thanks
Hard to say what it is without seeing it.
Not sure what you have it your car detailing arsenal, but you could try a couple things which may help you find out what the stuff is. I'm sure you have tried glass cleaner or a 409 type cleaner. Next you could try something that will cut through rubber mars like isopropal (rubbing) alcohol. Denatured alcohol is stronger and will also work. Finally, I would use a foam wax applicator and rub a fine scratch remover (back and forth motions, not circular) over the scuff.
Try one of these steps and report back.
trw92a
Aug 26, 2015 01:47 PM
Interior/Exterior R53 Speedometer Replacement
maniacalmorgan
Aug 21, 2015 03:03 AM
R50/53 R53 Speedometer Replacement
maniacalmorgan
Aug 20, 2015 01:08 PM
