wheel cleaner
Old Nov 23, 2005 | 05:15 AM
  #26
hugh's Avatar
hugh
Originally Posted by joker
i've only used soap & water & light wax on mine and 33k miles later wheels still l00k/clean like new.....i also use vaseline on the inside of my wheels for brake dust ...werks NiCE!
Does the vaseline cut thru/remove hardened, calcified brake dust?
Old Nov 23, 2005 | 06:57 AM
  #27
J0kER's Avatar
J0kER
as of yet i dont know if it cuts thru/remove.
i've used it for years and have not had a brake dust problem it also repels road tar fairly well!!!
it sticks and stays longer than any wax i've tried in the past!!
Old Nov 23, 2005 | 11:23 AM
  #28
jwardell's Avatar
jwardell
is this an acid based product?
No, it is the same ph as water.
I've been using Sonus Rim Bright as it is just as good as the P21S Gel but a bit cheaper.
Old Nov 23, 2005 | 01:01 PM
  #29
J0kER's Avatar
J0kER
k00l... =0)
Old Nov 23, 2005 | 02:49 PM
  #30
Zarrik's Avatar
Zarrik
What do you use to remove the gritty brake dust that is engrained into the wheel? I went a few months before first cleaning my wheels, and can only get new dust off, not the black specks :(
I've been using the P21S spray bottle with some success.
Old Nov 23, 2005 | 02:56 PM
  #31
kyriian's Avatar
kyriian
those are encrusted rubber! at least that's my case
i dont let it stay on in the first place, but i do have a few, i try my best to just get it out but it never works once it is into the metal... that's why everytime i get home from a track day... i just spray the wheels
Old Nov 23, 2005 | 06:33 PM
  #32
agranger's Avatar
agranger
If the bits are really in there, remove the wheels and wash well with whatever wheel cleaner you want, inside and out. Rinse well and slop on some fresh wash water with auto detergent. Clay bar. Rinse well. Dry and apply wax, NXT or a sealant like Zaino or Klasse (sealing is recommended)
Old Dec 23, 2005 | 10:07 PM
  #33
Suzannne's Avatar
Suzannne
Zaino on wheels...
I've read via multiple posts that Zaino can be used on the wheels to help repel brake dust, but I'm unsure of which specific Zaino product is the best for use on wheels? I just received my kit today and want to be super sure before I do anything silly...
Old Dec 24, 2005 | 07:48 AM
  #34
jwardell's Avatar
jwardell
Generic references to "using zaino" mean Z2.
It should help a little but often the difference is barely noticable.
The only real solution is to get rid of those stock brake pads.
But then again every little bit helps.
Old Dec 24, 2005 | 08:31 AM
  #35
Suzannne's Avatar
Suzannne
You mean I have to spend MORE money on the MINI?! Tis the season to spend, why not on the car, eh?
Old Dec 24, 2005 | 08:40 AM
  #36
RaiderZA's Avatar
RaiderZA
I have a sticky mark on my wheel from where the dealer balanced my wheels and replaced the weight. By the time I noticed it, it had become black with brake dust. How can I remove it w/o scrtaching the finish? Regular wheel cleener (Griots) won't do it by itself, and I am loathe to scrape it off.
Any suggesttions?
Old Dec 24, 2005 | 09:29 AM
  #37
GoodOlDan's Avatar
GoodOlDan
I've had good results with the Castrol "Super Clean" cleaner/degreaser... the purple stuff in the purple bottle. I use it as a "pre wash" before washing the car.
The MINI wheel cleaner (I received a bottle a s a gift) is OK but not as good as many other wheel cleaners I've used. Definitely not as good as the Castrol cleaner.
Dan
Old Dec 24, 2005 | 12:07 PM
  #38
BradB's Avatar
BradB
Any suggesttions?
I use bug and tar remover for this sticky stuff. Works great. Soak the remnents of the foam backing from the old wheel weight that was there then use an old rag soaked with additional bug and tar remover and wipe back and forth to remove the rest.
I change tires and wheels several times a season (several sets of track tires!) so I am doing this constantly!
Also, a really cool accessory/tool to get is a "plastic" razor blade. It's just what it sounds like- a single edged, straight razor blade that is made of plastic instead of metal. They are fantastic. I use these a lot to remove the thick sticky backing, stickers, etc. They will not hurt your wheels. Check your local art supply store, google them to find them, etc. They are cheap and come in many colors, too!
Old Dec 24, 2005 | 06:17 PM
  #39
Byron's Avatar
Byron
wheels
Greenstuff brake pads to reduce dust and windex to wash the weels and they will look new all the time
Old Dec 24, 2005 | 06:52 PM
  #40
yumhaggis's Avatar
yumhaggis
I just use the stuff my Mini dealer sells, made by Mini for Mini What could go wrong :impatient
Old Dec 24, 2005 | 07:14 PM
  #41
SoCar S's Avatar
SoCar S
Griots Wheel Cleaner... Non-acidic... Love the stuff... Endorsed by BBS.
Old Jan 12, 2006 | 02:43 PM
  #42
paul_'s Avatar
paul_
If you're being sarcastic, you sure are convincing.
Just in case: NEVER use Windex anywhere but windows!!! It contains ammonia which will damage the clearcoat on the paint and wheels
I wish I new something about detailing before we got the MINI! Life would be so much easier... course I did say the same thing about elementary school
Old Jan 12, 2006 | 03:06 PM
  #43
Wagnbat's Avatar
Wagnbat
I've never taken my wheels off to clean them before, and I've been driving my 'own' car for about 6 years now. Now to be a part of my 6 month full wash/wax/claybar program. (Will wax touch-up wax in between). Thanks for the tip guys!
Old Jan 12, 2006 | 04:32 PM
  #44
chows4us's Avatar
chows4us
Holy Bat Wheels!!!
Now THAT is dedication
iggi
18
Feb 9, 2026 01:00 AM
Alkaidovich
Jan 30, 2021 01:35 AM
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
