How to rotate tach glass
Old Jul 13, 2005 | 01:01 PM
kaelaria's Avatar
kaelaria
I need to rotate the glass on the tach - someone put a little scratch on it, and it's right over the readout. If I can just rotate it a few degrees I wouldn't even notice it.
Old Jul 13, 2005 | 01:08 PM
C4's Avatar
C4
Gimme a break man!
Old Jul 13, 2005 | 01:23 PM
eMINI's Avatar
eMINI
I'd start with suction cups or two-sided tape on opposing sides of the lens. If neither technique is helpful, I guess you could try to remove or loosen the bezel. Best of luck.
Old Jul 13, 2005 | 01:25 PM
Yucca Patrol's Avatar
Yucca Patrol
Try taking a banked curve at speed to rotate it a few degrees????
Old Jul 13, 2005 | 01:28 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Have that "someone" buy you a new tach.
Old Jul 13, 2005 | 01:40 PM
sandtoast500's Avatar
sandtoast500
You may want to ask here:
https://www.northamericanmotoring.co...612#post593612
Old Jul 13, 2005 | 01:42 PM
kaelaria's Avatar
kaelaria
I would if I knew where it came from. Sometimes I feel like everytime I take it somewhere, I need to do a complete inspection before driving away!!
Old Jul 13, 2005 | 01:47 PM
kaelaria's Avatar
kaelaria
Originally Posted by sandtoast500
Thanks, I did!
Old Jul 13, 2005 | 01:48 PM
kaelaria's Avatar
kaelaria
I actually already tried that - it's sandwiched in pretty good, no go.
Old Jul 13, 2005 | 02:27 PM
Tarzan's Avatar
Tarzan
Good idea...
I do.
As for the tach glass (it's plastic btw) you may be able to buff out your scratch...
Old Jul 13, 2005 | 02:59 PM
kaelaria's Avatar
kaelaria
With my luck lately...that would more than likely give me a severely scuffed tach :(
Old Jul 13, 2005 | 05:09 PM
Rossii's Avatar
Rossii
I am surprised how easily the plastic scratches........I went to wipe some dirt off and DOH! What do you use to buff scratches?
Old Jul 13, 2005 | 05:19 PM
kaelaria's Avatar
kaelaria
I tvery well *may* have ben me that scratched it, but since I know how soft it is in the first place, I never wiped them with dirt on them - and never noticed a scratch after cleaning. I noticed it after the last round of being in the shop, but I can't say for sure when it appeared. It IS VERY soft plastic though. It should DEFINITELY be harder!
Old Jul 13, 2005 | 06:13 PM
sandtoast500
Well, you could probably use that stuff from Moss that you can cover the headlights and foglights with, that thick plastic, and you could even get it in a blue or red tint to give a little trick look. as long as it doesn't obstruct the gauges that much... just an idea...
Old Jul 13, 2005 | 06:17 PM
scooterboy's Avatar
scooterboy
It's not sandwiched in - the lens is not a separate round piece of plastic that will rotate. Look at this pic:
Try some Plexus plastic polish.
Old Jul 13, 2005 | 07:47 PM
kaelaria's Avatar
kaelaria
Crap. Well that explains why it doesn't rotate! LOL
I'll try the polish.
Old Jul 14, 2005 | 06:47 AM
Squirlz's Avatar
Squirlz
Another good polish is Novus #2. I use it to buff out paint jobs on model cars. If necessary, follow with #1 for any remaining haze.
Old Jul 14, 2005 | 07:11 PM
Rawhyde's Avatar
Rawhyde
Try Happich's Simichrome polish. I have used it on many plastic parts over the years that need a scratch buffed out. Make sure you use a clean cotton cloth. Paper will just make more scratches.
Rawhyde
Old Jul 14, 2005 | 09:31 PM
RustyPaint's Avatar
RustyPaint
Use Meguiar's #17 Clear Plastic Cleaner to get rid of the scratch.
#10 (Clear Plastic Polish) to clean up the plastic once in a while. Then use Plexus to protect from scratches.
Always use Micro-fiber cloths. Anything else will scratch the plastic.
FYI.... Meguiar's #17 works wonders on CDs and DVDs.
Old Jul 14, 2005 | 11:51 PM
Eric_Rowland's Avatar
Eric_Rowland
Ok, who's going to be the guinea pig to try the plastic polish on the tach/speedo to see if it makes it better vs. worse?
Mine came (used) looking like Rossii tried to wipe dirt off of it
I've used the plastic polish to good effect on a miata rear window - but I'm afraid of it's effect on the hard, always visible tach.
Old Jul 15, 2005 | 12:13 AM
lotsie's Avatar
lotsie
My gauge lens look like new. I use a swifer on them to dust them.
Keep one in the car all the time.
Why would you touch them otherwise
Ya got both hands on the wheel, unless shifting right
Old Jul 15, 2005 | 04:37 AM
Battle Cattle's Avatar
Battle Cattle
go to walgreen's photo... and ask if you can have a couple of the white cotton gloves...they are made to handle film and not leave prints and they work fine for taking things apart...you can also clean with them too... I will see if I can get a pic tonight at work...
-Josh
Old Jul 15, 2005 | 08:43 AM
agranger's Avatar
agranger
I'd worry about the stitching in the cotton gloves, but it's not a bad idea.
I like my Zaino plastic polish (link below) used with a glass microfiber that I got at a local auto-parts store.
http://www.zainostore.com/Merchant2/...ory_Code=Zaino
Old Jul 15, 2005 | 07:36 PM
White_Knuckles's Avatar
White_Knuckles
Cotton gloves? I clean my tach lens in a clean room dressed in full surgical garb. Doh!
Okay, plastic is forgiving, try any of the recommended plastic polishes. Mirror Glaze or CD/DVD liquid restoring stuff works great. Start by applying horizontally to the vertical scratch. You're polishing out the scratch by wearing the optically noticed edges. Then apply with it's direction. Do it mounted in the car. Buff between applications - shes gone.
Now, put on the gloves and run about scaring children.
Old Jul 16, 2005 | 02:23 PM
Battle Cattle
yea yea yea call me **** but it works and they arent cotton... if I would have read the label they are 100% nylon.. and more of a mesh
-Josh
