Intercooler Rub Marks
Old Apr 12, 2005 | 06:26 PM
CARdiac's Avatar
CARdiac
The foam from the hood leaves ugly marks on the intercooler and my JCW badge . I was able to get them off with rubbing alcohol... but how do you keep them off or prevent them from happening again?
Old Apr 12, 2005 | 08:05 PM
Turbogeo's Avatar
Turbogeo
Place clear Mylar type tape on it and replace it as needed. Mylar type tape is similar to the invisable bra material. Good Luck .
Old Apr 13, 2005 | 12:09 AM
JCW04's Avatar
JCW04
I e-mailed JCW about this last year. They told me to use brake cleaner! When the intercooler is installed the foam gasket is oiled to make a better seal.
I have used Simple Green and Windex. Brake cleaner is a little too nasty to be using in the engine compartment.
I wipe the engine compartment and intercooler down every morning. Even though I keep it clean I can see the JCW badge is beginning to discolor, turning a light yellow color like honey. I guess the plastic or clear vinyl is reacting to the oil.
I spoke to my SA and he said it's not covered by the warranty. I'm planning on buying a couple of extra badges for spares.
Aloha!
JCW04
Old Apr 13, 2005 | 04:59 AM
Tarzan's Avatar
Tarzan
rubs off
The yellowing does rub off during the application of wax. Protect the decal with a layer of wax to ease cleaning.
Old Apr 13, 2005 | 07:22 AM
agranger's Avatar
agranger
I'd bet that WD-40, sprayed onto a cloth and rubbed on, would also remove the black stuff...
Maybe a good coat of wax or polymer (Zaino / Klasse) would help it from happening again?
Old Apr 13, 2005 | 10:28 AM
CARdiac's Avatar
CARdiac
Where do you find it?
Old Apr 13, 2005 | 10:56 AM
jwardell's Avatar
jwardell
I originally used simple green and nearly an HOUR of scrubbing to remove it...but then I discovered, WD-40 will remove it instantly! You may wish to follow up with simple green or other soap to remove the WD-40.
Old Apr 13, 2005 | 12:32 PM
minicoopermike's Avatar
minicoopermike
My hood actually scratched the lower part of the JCW intercooler cover not to mention make it dirty before the dealer performed the recall for the hood foam . The front badge is also quite beat up from 30,000 miles of road debris. I am going to see if the dealer will replace these items under warranty next time I go in for service.:smile:
Doc Pain
Mar 10, 2021 04:50 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
