R53 Rear Hatch dripping water after wash
Old Mar 4, 2023 | 09:39 AM
Chucho Shoots's Avatar
Chucho Shoots
Does anyone have any info as to why this happens? It literally has been dripping out behind the trim. I am trying to keep my car clean, but requires cleaning after the original clean LOL.
The back hatch area in general is hard to keep clean, so if anyone has tips on that, or if there is a diffuser which can maybe minimize the vortexes that bring dust/grime on the back!
Thanks again!
Old Mar 4, 2023 | 05:13 PM
BRGPA's Avatar
BRGPA
It could be the gasket for the antenna. Some people have had problems there. Does it leak in the rain or just after added pressure from the wash?
Old Mar 4, 2023 | 10:12 PM
Chucho Shoots
just regular pressure from a wash
Old Mar 4, 2023 | 10:47 PM
RB-MINI's Avatar
RB-MINI
A couple of common leak causes are the third brake light or hatch handle seals. The holes for the belt line trim clips can also let in some water. Check your battery box to make sure it isn’t full of water.
Old May 15, 2023 | 10:29 PM
Brad S's Avatar
Brad S
By rights you will get a more dusty rear door after adding a diffuser that works to any extra degree over the standard airflow.
Old Jun 24, 2023 | 02:41 PM
ghostwrench's Avatar
ghostwrench
I traced the cause of 3" of water in my battery box to a water leak from the trim piece that houses the license plate lamps and release switch for the boot.
offroadMini
Sep 11, 2021 10:43 AM
rphox2003
Jan 3, 2016 06:52 PM
R58
R58 :: Coupé Talk (2012+)
15
Jun 25, 2014 11:42 AM
LIVNLRG
Oct 20, 2011 04:53 PM
