Removing air bag warning from body-color interior panel.
Old Dec 13, 2004 | 10:04 AM
Squirlz's Avatar
Squirlz
My usual procedure for stickers (on other cars) has involved careful peeling with a hair dryer followed by 3M adhesive cleaner. Hate to do anything to mess up my new car though. Any thoughts?
Old Dec 13, 2004 | 10:27 AM
Phil_Kidd's Avatar
Phil_Kidd
I was able to gently peel the label off, then used a little Goo Gone to clean off the glue. Worked like a charm.
Old Dec 13, 2004 | 11:42 AM
gr8britwjh's Avatar
gr8britwjh
If you gently peel it off SLOWLY (whilst the car is still relatively new) it should come off in one piece and leave no residue behind
Old Dec 13, 2004 | 12:03 PM
wmba's Avatar
wmba
As mentioned above... I was able to remove mine just by peeling slowing. No residue or marks were left at all. It is impossible to tell where the sticker was. Now.. I did remove it in the summer.... so it is possible that the warmer weather made it peel more easily. Might not be a bad idea to use a hair dryer... or just get the car nice and toasty with the heat (this of course is assuming that you are in a cold climate)
Good luck
Old Dec 14, 2004 | 05:00 AM
Aqualung's Avatar
Aqualung
Others have used denatured alcohol....https://www.northamericanmotoring.co...atured+alcohol
Old Dec 14, 2004 | 05:31 AM
wmba's Avatar
wmba
Oh.. I just realized something. I was talking about the sticker on the dash just above the glove box. That one shoud come off without too much trouble, or just a little heat.
However, if you are asking about the ones on the visors, then you will probably have to use denatured alcohol like the person above mentioned.
Old Dec 14, 2004 | 06:01 AM
MarkS's Avatar
MarkS
Ah, I was wondering. I tried just peeling them off the visor, thinking that's what was being discussed, and I couldn't even get a tiny bit of a corner lifted up. I did do the sticker on the dash, though. Harder than I expected to get off but it all did come up just by peeling, in about two or three pieces.
Mark
bneer
Jul 15, 2019 04:41 PM
eatsleepautox
Oct 30, 2015 06:46 AM
Zettinger
Aug 25, 2015 04:04 PM
JamJam43087
Aug 16, 2015 02:02 PM
