First time paint correction + ceramic coating
Old May 27, 2018 | 10:00 AM
tallskinnymatt's Avatar
tallskinnymatt
Hey Guys,
I recently picked up a 2004 R53 Mini Cooper S with 84k miles back in February. The paint was decent, but had tons of swirls and scratches. Since then I really wanted to take a stab at doing a paint correction myself and start getting more into the actual detailing of a car. I decided to do just that. I started at 7am, and finished with everything around 7:30pm. A lot more work than I anticipated, but the results are well worth it
Polisher: PORTER-CABLE 7424XP
Pads: Chemical Guys Hex Logic Orange and White Pads
  • Step 1: Wash
  • Step 2: Carpro Iron-X
  • Step 3: Chemical Guys Clay Bar
  • Step 4: Carpro Eraser
  • Step 5: Cut (Meguiars Ultimate Compound)
  • Step 6: Polish (Meguiars 205)
  • Step 7: Meguiars Ultimate Black (Plastics)
  • Step 8: Carpro Eraser
  • Step 9: Cquartz Ceramic Coating
  • Step 10: Carpro Reload
Results (Not bad for a 14 year old car):
Old May 27, 2018 | 10:48 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
That is awesome!!! Looks great. Wish I had the patience to do that to my car.
Old May 27, 2018 | 11:31 AM
Goldsmithy's Avatar
Goldsmithy
MINI Alliance Ambassador
GREAT WORK...you should be very proud. Your car looks better than new...
Old May 30, 2018 | 05:36 AM
GPMini's Avatar
GPMini
Looks great! I did mine a couple weeks ago. It sure is a lot of work, but so worth it.
Old May 30, 2018 | 11:32 AM
Dave.O's Avatar
Dave.O
Great job! I know it’s hard the first time you prep, Polish and ceramic coat a car but in the end it looks excellent.
The best part is it will look that way for well over a year , which most people that use sealant and wax don’t get.
Old May 30, 2018 | 06:37 PM
tallskinnymatt
Thanks Definitely requires a lot of patience, but I'm happy with the result.
Thank you! Not quite better than new, but looks good for its age. haha
Awesome! Definitely worth it.
Appreciate it! I have my weekend car ceramic coated as well, and it makes life so much easier. I'm curious to see how long the CQuartz will last. I have Gtechniq on my other car.
Old May 30, 2018 | 06:39 PM
tallskinnymatt
Here is one picture that best shows the condition of the hood before. As you can see, it wasn't in the best shape.
Also here is a short video I took of the paint after just one pass of the compound! In total I did two passes of the compound, and one pass of the polish so the finished product looks even better than on the video.
Old May 31, 2018 | 07:30 PM
Dave.O's Avatar
Dave.O
When you are ready to try an easy ceramic coating system look up Gyeon Syncro. You will not be disappointed with the ease of application and removal and the results.
CQuarts should last at least a year or longer with proper washing and maintenance like CarPro Reload.
Old May 31, 2018 | 09:12 PM
tallskinnymatt
Great info! I'll definitely check out Gyeon Syncro. A year is not bad for the CQuartz. Doing a polish and reapplying CQuartz once I year won't be too difficult.
Old May 31, 2018 | 09:55 PM
Paul's Avatar
Paul
Looks awesome! I wish I had the skill to do this.
Old Jun 1, 2018 | 05:15 AM
Whine not Walnuts's Avatar
Whine not Walnuts
A great looking Gen1
Old Jun 1, 2018 | 10:16 PM
tallskinnymatt
Thanks! This was my first time, and it wasn't as hard as it looks. I'm sure you would do fine
Thanks! Been one of my favorite cars so far.
Old Jun 2, 2018 | 11:03 AM
tallskinnymatt
Decided to re-do my hood, as there were some deep water spots that were not quite gone the first time. Results turned out great. Did 1 pass of Meguiars 205 to remove the coating, 2 passes of Ultimate Compound to cut, and topped it off with another pass of 205. Re-coated it with CQuartz and applied Reload. Turned out really nice and not more water spots. I ordered new white racing stripes as well, so the front will look brand new.
Old Jun 2, 2018 | 11:38 AM
Whine not Walnuts
This reminds me of an another post that I made recently on HP mods, something like just as men will never figure out women and shopping, they will never figure us out with our cars.
Old Jun 3, 2018 | 04:20 PM
Whine not Walnuts
Did you have any issues with Carpro Reload streaking? I have read posts about people having issues with it. From similar discussions it appears that HydroSilex Recharge does not have as many issues.
Old Jun 4, 2018 | 11:29 AM
Dave.O's Avatar
Dave.O
CarPro Reload works great. The key is remember to shake it between sprays.
I also see people get streaks all the time because they use way too much.
It’s the same with glass cleaner. I have seen people pump 5-6 squirts on one side window. It just one window, you only need one squirt and move it around with your towel.
Most times I only spray the towel and not the glass or the paint.
Old Jun 6, 2018 | 06:47 PM
tallskinnymatt
This. I only sprayed reload on the towel itself. After reading many posts and watching many youtube videos, it seems like the safest bet. I did not experience any streaking using that method.
Old Jun 20, 2018 | 12:23 PM
tallskinnymatt
First wash. I love the way water beads on a ceramic coating
Old Jun 20, 2018 | 01:13 PM
bratling's Avatar
bratling
Super Moderator
Your mini looks amazing. So good!
But don't polish every year if you can avoid it. Polishing removes clear coat (and eventually base coat paint).
Modern (post-1980s) car paint is around 6 thousandths of an inch thick (~150 microns); about 1/3 of that is clearcoat. That's half the thickness of a sheet of paper.
A light polishing is good for 0.5–1 microns; a heavy correction runs around 4. Sounds like you should have plenty, with 50 microns of clearcoat to work with. But, it seems the ultraviolet light protectants reside in the top 25% of the clearcoat. Based on this, you've got about 12 microns before you seriously expose the base coat to UV and fading.
Aggressive polishing can eat up that 12 microns fast. Take care of your paint and do the minimum possible polishing. It's definitely a case where prevention is better than cure. Try to stay ahead of the swirls so you don't need to do a heavy correction again.
Anyway, I'm really posting to praise your car and the work you've done. Indeed it looks better than new, and you've done a better job than I usually do
Old Jun 20, 2018 | 01:18 PM
tallskinnymatt
Great info, thank you! With proper care, I shouldn't need to do a polish every year. On my other car, I exclusive use Chemical Guys ECO-RU to clean it + 500gsm micro fibers, no water. No swirl marks for the past 4 years. Since this is my daily, I typically take it to the coin wash to power wash the surface dust/dirt away, and then bring it home and use the ECO-RU to finish it up. In my experience it's been the safest way to avoid swirl marks.
Definitely appreciate the kind words, and I'm thrilled the way it turned out!
Old Jun 20, 2018 | 01:20 PM
tallskinnymatt
I know this is not necessarily detailing, but my new parts just arrived as well! Did a ceramic coating on my new wheels, so they will keep them protected and aid with washing. This will be an aggressive fitment, but should be able to dial in enough camber to make it work.
Old Jun 29, 2018 | 11:27 AM
bee1000n's Avatar
bee1000n
Just want to say 12 hours to do all that work seems really fast to me - nice job!
I had CQuartz Classic put on my 04 R53 three years ago and have just been adding Reload ~3 times a year since then. No idea if the coating is still under there, but the surface is amazingly smooth after periodic lightly claying and Reload-ing.
For Reload, my detailer had the same advice as people above - just spray a tiny amount on a fluffy microfiber towel and rub & wipe. I have white MF towels reserved just for Reload.
Old Jul 2, 2018 | 10:28 AM
tallskinnymatt
Appreciate it! CQuarz and Reload is such a good combo. It has made cleaning the car so much easier and I love how good it makes the paint look. My sister-in-law couldn't believe that the car was 14 years old. haha
CPap
Sep 5, 2014 10:02 AM
toolazyforalogin
Oct 13, 2012 11:17 AM
TonyB
May 29, 2006 05:52 PM
The MINITOR
Jan 13, 2006 04:18 PM
jbsf3
Oct 15, 2005 09:21 PM
