adams interior cleaner
Old Feb 20, 2012 | 04:51 PM
HHFD633's Avatar
HHFD633
Help!! bought some adams interior cleaner not to long ago seems everytime i use it something is wrong...I get this white residue on anything blk or gray. Has anyone else had a problems with this stuff? Might just go back to simple green never had a problem there..
Chris
Old Feb 21, 2012 | 05:11 AM
daflake's Avatar
daflake
Which one do you have? I have been using Adam's polishes for years and not had any problems.
Old Feb 22, 2012 | 05:31 PM
HHFD633's Avatar
HHFD633
adams leather and interior cleaner
Old Feb 23, 2012 | 05:20 AM
daflake's Avatar
daflake
Hmmm... I use that on a regular basis and don't have that problem with the black leather. I do use it to clean the dash but then follow that up with something like armor all to finish it off.
For my leather seats, I use the cleaner and then use a conditioner so that might also remove the haze you are talking about.
As for Simply Green, if you have leather, don't use that stuff, it will dry your seats out. It is ok for spot treating but you need to be conditioning your seats or they will dry and crack.
Adam's usually stands by their products, so maybe you should contact them and see what they say. I suppose it is possible that you got a bad batch of the product and that is causing your headaches.
Old Feb 26, 2012 | 06:44 PM
Poop Juice's Avatar
Poop Juice
There have been discussions around Adam's interior cleaner having a sodium component to it's formula. If you're using it on dark surfaces you probably want to spread it out a little more than you're used to. If you still have white residue; light application (ie. dabbing or damp towel not soaking) with water will get rid of it.
Old Apr 2, 2012 | 02:45 PM
HHFD633's Avatar
HHFD633
i was reading adams forum today.. some bad input about this cleaner. some say to acidy, other dilute it 50% and it works great... Any thoughts on that?
Old Apr 3, 2012 | 05:53 AM
daflake's Avatar
daflake
Might be worth trying to dilute it. However, if it isn't working for you there are other cleaners out there that are just as good.
Old Apr 6, 2012 | 02:12 PM
HHFD633's Avatar
HHFD633
well i cut it 50% and wow what a diff. No more white residue, a mch better mat sheen to it after and no chem smell...How is there in and out spray
Old Apr 6, 2012 | 02:50 PM
daflake's Avatar
daflake
Haven't used it, sorry...
OutMotoring
Mar 3, 2017 06:29 AM
NorthWestEuro
Oct 20, 2016 06:41 AM
Sep 30, 2015 11:25 AM
Sep 30, 2015 11:24 AM
Sep 29, 2015 12:11 PM
