Clay lube?
Old Jan 25, 2012 | 10:51 AM
Jeremy Brooks's Avatar
Jeremy Brooks
Clay lube?
If I'm going to be using the Hydro system, what's the right choice for lube during the claying process? Just use the Slick?
Old Jan 25, 2012 | 02:08 PM
richardsperry's Avatar
richardsperry
Soapy water.
Old Jan 25, 2012 | 04:18 PM
Nrob's Avatar
Nrob
Prima does have a product with the that specific purpose called Glide. I just use what ever QD I happen to have in my detailing cabinet at the time.
Old Jan 25, 2012 | 04:24 PM
RJKimbell's Avatar
RJKimbell
Griot's Garage Speed Shine!!
Old Jan 25, 2012 | 07:28 PM
JeffreyC's Avatar
JeffreyC
Soapy water works great, as well as that bottle of Mequires QD that you can by at Wal-Mart. Nrob's got it right...whatever QD you have in the garage will work
Old Jan 26, 2012 | 12:14 AM
OctaneGuy's Avatar
OctaneGuy
Prima Glide is an excellent lube however most any quick detailer or even soapy water can be used. If you are claying after a wash, it makes sense to use soapy water, but IF the paint is already cleaned and dried, a QD makes more sense. The best thing about using a QD/lube is that used properly you don't need to wash your paint after you clay and because there are cleaners in the QD, inspecting your process after you clay will easily show you how clean, shiny, and smooth the paint is whereas with soapy water you might get some residue that you need to rinse or clean off as well.
http://www.showcarsupplies.com/shopexd.asp?id=123&bc=no
Richard
Last edited by OctaneGuy; Jan 26, 2012 at 08:46 AM. Reason: typo..missed "IF" which changes how its read.
Old Jan 26, 2012 | 08:15 AM
greengobln's Avatar
greengobln
I prefer a QD. Right now I have some slick and hydro in the cabinet. I also use the meguiar's QD especially if I plan on polishing afterward. The soapy water mix will run on the plastic trim and if i already black wowed the car I will have to touch up some places if the soap took it off or distorted the finish.
Old Apr 17, 2012 | 06:21 PM
clos8's Avatar
clos8
I use some detailer pro waterless diluted. WOrks great as a quick detailer or clay lube
Old Apr 18, 2012 | 05:23 AM
phil@detailersdomain's Avatar
Prima Slick would be a great choice
Old Aug 6, 2012 | 01:33 PM
IbisS5's Avatar
IbisS5
Dodo juice clay lube.
Old Aug 6, 2012 | 01:59 PM
BayStateDetailing's Avatar
BayStateDetailing
The clay lube specific stuff imo works so good!!
Now if you are looking for the best bang for your buck this is what I use https://detailersdomain.com/Optimum-...ULA_p_154.html and honestly once you go no rinse you never want to use regular wash again!! It dilutes like 30:1 for clay lube/quick detailer.
I always used megs and it works great but when you do it all the time it gets expensive.
ps. Don't waste the extra money on Ultimate QD for clay lube.
David.R53
Sep 13, 2015 03:44 PM
kevinminict
Sep 8, 2015 04:13 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 03:01 PM
minipopkart
Aug 13, 2015 05:22 AM
