What to do after removal of bonnet stripes
Old Apr 2, 2011 | 04:37 PM
silvia's Avatar
silvia
I just removed my white bonnet stripes and my mini is naked now. I washed it with Meguiar Gold Class wash and conditioner, rinse with cloth and then dried.
Is this about it?
I am going to do some car detailing next week.
1/ Gold Class Wash and conditioner
2/ Dry car with Meguiar water magnet drying towel
3/ Use clay bar, ultimate detailer ( spray bit on area, use clay bar in circular motion, wipe with Meguialr shine Microfiber towel)
4./ Ultimate compound
5. Ultimate liquid wax
Is the above correct? When do I use the even coat applicator pads?
Will one clay bar be needed for the entire mini cooper S?
Old Apr 4, 2011 | 09:28 AM
Stealth 993's Avatar
Stealth 993
Read up on things.
1. NEVER clay in a circle! Straight lines ONLY!
2. Break the clay in half, keep needing it as you work the panels. It should last (one half) for many clayings. Clay is done when you can feel a lot of grit in it, or it starts to fall apart (not all clay does). Bad clay can cause more damage then good.
3. Do you have a real "compound" or is it a polish?
4. What are you using to apply & remove the polish/compound?
5. You use the app pads for wax, use less then you think, lighter coats are way better then one thick coat.
6. What are you using to remove the wax?
Old Apr 4, 2011 | 09:58 AM
silvia's Avatar
silvia
using even coat applicator to apply and supershine microfiber towel to remove. both from Meguiars
Old Apr 4, 2011 | 11:50 AM
alanzilo's Avatar
alanzilo
Removal of Bonnet stipes...
what
Old Apr 4, 2011 | 11:53 AM
silvia's Avatar
silvia
In reply to question 4 from Stealth
Old Apr 4, 2011 | 11:54 AM
alanzilo's Avatar
alanzilo
I meant "what process did you use to remove the stripes ?" thanks
Old Apr 4, 2011 | 12:04 PM
silvia's Avatar
silvia
Not OEM vinyl stripes but from cooper flag which someone installed for me.
I used the hot setting on the hair dryer, blew on the top part of the vinyl for about 20seconds, pulled from the corner down to about 1/4 way , then used hair dryer again, peeled another 1/4 way, repeated process till I was finished.
No residue except for the bit of built up wax on the edges where vinyl stripes used to be. NO sticky stuff beneath the stripes and they came off very easily
caiken
Aug 27, 2015 06:55 AM
Drumsound
Aug 25, 2015 02:25 PM
minicoclub
Aug 25, 2015 09:07 AM
bctf1
Aug 6, 2015 12:55 PM
