Floor matts no longer Shiny help please
So, I have had my '03 MCS since March and it came with Rubber Floor matts. Over time my driverside floor matt has lost its shine entirely, it now has a white dusty look that will not go away, I have tried soap & water, tire dressing, engine degreaser/dressing. Nothing will bring it back to the shine that my other 3 matts still have, any thoughts/ ideas on how to make them shiny again?
Thanks in advance
Austin
Thanks in advance
Austin
sounds like you wore the top layer of shiny rubber off. you can armor all them or tire shine them but they will be slippery and gather dust faster. My suggestion would be to either buy new ones or deal with them.
concur
you can apply goose grease but they will slip and gather dust
might try back to black
black wow
or my fav' Zymol Vinyl
http://www.zymol.com/zymolvinyl85oz.aspx
kept the top on my Miata good for 12 years . . .
all I use on my vin' and rubber now . . .
in the days it was new I applied Armour All to my motorcycle seat
forgot to warn the Mrs
at out first red light I took off and she slid right off - left sitting in the intersection . . . .
black wow
Black WOW has a pre-conditioner designed to remove the white opaque color black plastic gets.....wonder if that would do it.
Not sure I would want WD4O on there. Liable to get the soles of your driving shoes slippery and your foot would slip right off the brake !
At one time, there was a MINI dealer who advertised in eBay. The rubber mats for just the fronts were $53.00 and that included shipping. .......if you wanted the "S" mats they were a bit more.
Do not use black-wow inside the car...
It will evaporate and then condense on the windows, fogging them if I remember right (the residue will be like that foggy stuff on a smokers car...don't remember where I saw/read the warning, but know I did).
Back to black should work...by it might become a loosing battle, or have unintented concquences...not sure if it might get slick in a hot car when summer comes....
Try this, DocBaileysLeatherBlack , non-slippery, you can use it inside the car and it should do the trick much better than Back to Black. We've been using it for years on motorcycle leather (jackets, seats, saddlebags, etc) and I use it on all the vinyl trim on the Mini, once it dries it won't come off on your hands or clothing. You can order from them, but I found it cheaper on ebay.
Do you have supporting facts for this? Black Wow will not evaporate, lol.
I think you are confusing BW with armorall.
But to the OP, I would not use any type of tire dressing or rubber dressing on the floor mats. The potential to step on it, and make the controls slippery is too great. I find that restoring the blackness and uniformity of the floor mat goes a long way towards making it look new again...you don't need the shine. =)
I use, and I recommend Black WOW!! Great stuff!!
I could have sworn I saw a Q&A that said not to use it on interior surfaces...said that it was for exterior only, since it would cause the windows to fog. Maybe evoperate is not the right word...off-gas/re-condense?!
Lol.
Whoever wrote that Q/A has some misinformation then.
I have never said that about Black Wow. I have said not to use it on the interior because usually a matte finish is desirable and on the exterior the shine naturally wears away thanks to exposure to the environment but inside the car, that doesn't happen as readily and will retain the shine. That could make it easier to accidentally transfer product from surfaces to shoes to clothes, etc...there is no harm to using BW inside..but I would caution against using it on the floormats because the potential to slip is too great...or transfer the BW to the brake or accelerator pedals which would be very bad.
Richard
I have never said that about Black Wow. I have said not to use it on the interior because usually a matte finish is desirable and on the exterior the shine naturally wears away thanks to exposure to the environment but inside the car, that doesn't happen as readily and will retain the shine. That could make it easier to accidentally transfer product from surfaces to shoes to clothes, etc...there is no harm to using BW inside..but I would caution against using it on the floormats because the potential to slip is too great...or transfer the BW to the brake or accelerator pedals which would be very bad.Richard
I bow down to the seller/maker/developer!!
A dumb detailer used a degreaser on my mats and turned them all white. He tried to say it wasn't his fault but he didn't do the rear driver side mat and it was still black.
I am going to try the 303 Aerospace Cleaner which works wonders on the exterior and engine compartment rubber and vinyl.
embiggenedmini
Oct 15, 2015 12:36 PM
