Prep for Clearbra install?
Old May 15, 2008 | 10:02 AM
misslindsey's Avatar
misslindsey
Since I've bothered my installer enough already, I don't want to call his poor wife... again. But I also don't want to wait 'till she calls Monday to confirm my appt. Tues to ask how I should prep my car for him to install the clearbra on Tuesday.
Background is this: Lewis is about 8 months old. Due to an unfortunate garage accident, his bonnet was repainted a few weeks ago. After seeing all the paint chips he had picked up already, I figured this was a good time to get a clearbra installed.
I've been driving around with fresh paint, being very careful to stay away from anything throwing crap at me. But he's dirty. I assume that the surface to be paint-protected shouldn't have any wax on it? So I need to Dawn wash him (At least the front, I don't plan to full detail until he returns)? I know I'll have to be super careful to not get swirlies on him since I won't have a chance to correct them, any advice? And then there's all the bugs. It's spring in Michigan, and... ew. If I goo-gone them off with something suitably soft should I then rinse it was some alcohol?
Thanks!
Old May 15, 2008 | 10:18 AM
ScottRiqui's Avatar
ScottRiqui
For the bugs, soak some old towels in water and drape them across the front of the car for an hour or so. The water in the towels will "reconstitute" the bug guts and they'll wipe right off.
The installer will do a final cleaning of the surface before applying the film, but it's a good idea to wash the car first just to make the job easier and minimize the chance of ending up with dirt under the film. You're correct that you shouldn't use any wax/sealant/quick-detailer on the paint before taking it in.
Old May 15, 2008 | 12:44 PM
tdm156's Avatar
tdm156
Ruling the curves
I would make sure its clean bu like Scott said the installer will do a good clean on the areas for the install
Old May 15, 2008 | 02:19 PM
thulchatt's Avatar
thulchatt
You should check with the people that painted your car to see if it is safe to put the clear bra on yet. Most paint needs to out-gas for a while (60 -90 days) before being sealed (waxed) so the same may apply to a clear bra. Not sure myself but a question I would ask the painters.
Old May 15, 2008 | 02:37 PM
MLPearson79's Avatar
MLPearson79
That's not really true with modern paints. Just make sure it's clean and unwaxed (and the installer will do the same, if he's any good), and you'll be fine
Old May 15, 2008 | 06:22 PM
ScottRiqui's Avatar
ScottRiqui
Well, modern paints still have to off-gas (unless it's a factory-type finish that's baked immediately after application), but if it's been a few weeks, you're probably fine. Also, the clearbra material isn't 100% airtight, so if the paint isn't completely done off-gassing yet, it can finish up even after the clearbra's been applied.
Old May 15, 2008 | 07:05 PM
thulchatt's Avatar
thulchatt
Good to know, I was unsure if the clear bra would allow the gas exchange.
Old May 15, 2008 | 07:13 PM
ScottRiqui's Avatar
ScottRiqui
In fact, don't be surprised if you see some hazing or tiny bubbles under the film for the first few days after a clearbra installation. The moisture will evaporate off through the film and it will clear right up.
Old May 15, 2008 | 07:30 PM
cutters68's Avatar
cutters68
Clearbra over sports strips?
I am thinking of ordering the 3M clearbra and install in myself with the help of the instructional DVD. Will save 70% if it works. Its a gamble I am willing to take. My question is does the clearbra go on over the sports strips. Thanks!
Old May 15, 2008 | 07:49 PM
MLPearson79
I would recommend putting the stripes over the clear bra. Otherwise I'd the stripes fade, get chipped, or you just want a change, you'll have to pull up the film and replace it to get at the stripes.
Old May 16, 2008 | 05:22 AM
misslindsey
Body shop said 30 days - it's been about that. I asked that specifically, he said it was baked but it would still need time to cure. Thanks for the replies!
Old May 16, 2008 | 07:31 AM
rockridge's Avatar
rockridge
I did the clear bra install myself over the stripes. The car is only 8 Months old, but looking good. Who knows 5 years from now...
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
