is it bad if i use my pressure washer?
Old May 11, 2008 | 01:05 PM
moji2006's Avatar
moji2006
does it ruin my paint if i use a pressure washer?
Old May 11, 2008 | 02:45 PM
kenchan's Avatar
kenchan
as long as it's not a super high pressure washer it'll be fine.
Old May 11, 2008 | 02:47 PM
donniebronx's Avatar
donniebronx
No.
You are okay.
If you start seeing your paint come off, then you have a problem.
I've used my gas powered pressure machine with no problems.
I actually prefer to use it over the hose for the wheels and wheel wells.
Old May 11, 2008 | 03:50 PM
Frisco's Avatar
Frisco
Pressure washing your MINI.
Watch the doors, as water getting in, drives the window
control nuts. Many have suffered this fate, without high
pressure hoses.
Old May 16, 2008 | 07:06 AM
rockridge's Avatar
rockridge
I have been using my power washer for last 3 years. Works great on my landrover. On the Mini, the Power washers help make cleaning brake dust of the wheels and brakes much quicker..
Old May 16, 2008 | 09:12 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
As long as you adjust the washer to provide a fan-shaped spray rather than the sharp pencil spray, and keep about a foot away from finishes, you should be fine. Avoid spraying in areas that have been chipped, since the spray can get under the clearcoat or paint and spread the damage in some cases. Avoid spraying directly at electrical connections and devices when cleaning under the hood. Directing the spray downwards where the window moldings meet the glass can help rinse out the large amounts of dirt that collect under these moldings. In fact, it's worth it to occasionally pull off the beltline moldings in order to clean the crud that collects there. Using a pressure washer helps a lot here, follow up with a brush and soap, then rinsing, alowwing to dry before replacing the moldings. The same is true for the wheel opening moldings, it gets nasty under there!
Old May 16, 2008 | 01:12 PM
OPC's Avatar
OPC
RATTUS Deserticus
Not to hijack the thread, but any advice regarding the pressure washer and a newly installed clear bra? I would guess try not to get under the edges, but should I wait a certain amount of time before washing the car?
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
Sep 3, 2015 02:06 PM
Sep 2, 2015 11:15 AM
