Polishing a Classic Mini...
Old Jun 20, 2007 | 10:50 AM
  #26
Prima Car Care's Avatar
Prima Car Care
Originally Posted by ImagoX
Ouchies... I just don't know if that level of body restoration is within my skill range. It actually might be easier to replace the entire wing in a year or two than to carve out a section and replace it smoothly enough that the perimeter of the repair will not show. I can probably scare up a few people that I know that can spot weld but that...? I'll have to ask around and see if anyone in my local community has those skills - I get the impresison talking to some of my local restorers that they generally just "do the job right" and pluck off the entire offending panel.
I guess I can check it from the inside when I see it and see how bad it is in there - I hear that kind of damage is fairly common.
Thanks!
Originally Posted by MiniMaybee
Matt, I think what Nick was trying to say is that you will need to remove all the rust from the surface of the fender under the paint. I doubt you would need to cut out a piece of the fender. I would first use a Dremmel to remove a square section of paint to expose the rust and find good metal. Then you can either grind out the rust down to bare metal or use Naval Jelly to convert it. Then sand the area smooth, Bondo to flush and sand again. Primer and paint. All this can be fairly localized and is a lot less difficult than it sounds.
Thanks MiniMaybee for clarifying Nick's post... Nick is FULL of incredible information but he isn't very good at expressing it sometimes. I think it's so wrapped up in his head full o' info that it just comes out kooky sometimes!
I just knew that the situation was over my head so I had to call in the *real* expert.
-Heather
Old Jun 20, 2007 | 10:52 AM
  #27
Prima Car Care
You guys are hilarious! Actually though, I think Matt is hitting on you MM...
And yes, MiniMaybee, I'd have to say that the scraping of the naval comment was definitely beyond gross!
-Heather
Old Jun 20, 2007 | 11:48 AM
  #28
OctaneGuy's Avatar
OctaneGuy
I've been here the whole time, just lurking. Nick's got the right answer--glad you found a potentially workable solution----back to polishing for me. And yes Naval Jelly sounds very strange.
Bump - hopefully Richard will see this one... Thanks!
Old Jun 21, 2007 | 07:38 PM
  #29
MDK's Avatar
MDK
Naval Jelly.... you didn't just go old school! I haven't heard of that mentioned in 20 years. It does work as described.
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Aug 6, 2016 07:19 AM
boholio
Nov 9, 2015 03:50 PM
Greezyman
Classic Mini Talk
Oct 3, 2015 12:03 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
