DC Metro MINIs (Archive) The old DC Metro MINIs club forum, now closed. Visit their new forums at www.dcmetrominis.org/forums
Possible Tire Leak?
Old Oct 3, 2006 | 06:10 AM
Griff's Avatar
Griff
Possible Tire Leak?
This morning on the way to work the low tire pressure light came on... When I stopped at the station to see what was going on, the left rear tire only had 25 psi. I did not see anything in the tire and the MINI only has 700 miles on it. Has anyone else had problems with tires losing pressure?
Old Oct 3, 2006 | 06:14 AM
mdsbrain's Avatar
mdsbrain
Weather changes can effect a tire's pressure. I'd pump it back up and keep and eye on it.
Old Oct 3, 2006 | 06:16 AM
royal4mac's Avatar
royal4mac
I have had problems with the indicator. Had to shut the car off to reset it. If the tire looks good, throw some soapy water around the stem. It could be unseated.
I had to reply to your note, b/c my name is Griff. Actually Griffin, but it looks like you just use that as your screen name.
Good Luck
griff
Old Oct 3, 2006 | 06:20 AM
mdsbrain's Avatar
mdsbrain
Hitting the reset button next to the e-brake didn't clear yours?
Old Oct 3, 2006 | 06:51 AM
Griff's Avatar
Griff
Griffin
Good Luck
griff
My family name is Griffin, we are originally from North Carolina
Old Oct 3, 2006 | 07:00 AM
HEMI-MINI's Avatar
HEMI-MINI
The ambient temps so far have not been extreme enough to cause this but I do agree with putting air in it and keeping an eye on it.
I prefer Nitrogen in my tires....it reacts very little to ambient temp changes. Its very expensive for the service station to have this system but more and more are popping up. My local Costco uses a Nitrogen system.
Old Oct 3, 2006 | 07:49 AM
xcaligali's Avatar
xcaligali
Do you have the stem caps that feature the low pressure indicators on your tires? If so, there is your problem.
Old Oct 3, 2006 | 09:18 AM
Griff's Avatar
Griff
Well I found the culprit, a screw punctured the tire. Damn, only 739 total miles on the MINI. Has anyone ever patched or plugged one of these guys?
Old Oct 3, 2006 | 09:22 AM
mdsbrain's Avatar
mdsbrain
If the puncture is in the tread are it can most likely be patched.
Old Oct 3, 2006 | 09:47 AM
JustJAY's Avatar
JustJAY
I just recently plugged a RF tire. Make sure they use the patch/plug method meaning they remove the tire from the wheel. Only go to a Tire Rack certified shop because I went to NTB and they damaged my wheel They also said that the tire is no longer considered a RF becasue it has been repaired. Not sure what that means since it is the sidewalls that make it a RF.
Old Oct 3, 2006 | 09:52 AM
HEMI-MINI's Avatar
HEMI-MINI
Thats a new one......
Never trusted NTB anyway. I have never had any issues with patching tires on my own but since it is so brand new....take it to a decent shop. If it is too close to the edge they will most likely not touch it.
Old Oct 3, 2006 | 11:14 AM
Griff's Avatar
Griff
I just returned from Just Tires in Vienna where they have a special tire press to handle the run flats. They had me in and out in an hour and appear to have done a great job with no noticible damage to the web spokes.
Thanks for all of the comments and advice
Old Oct 3, 2006 | 06:48 PM
1996 328ti's Avatar
1996 328ti
Normally a plug/patch lowers the speed rating to the next lower letter.
Old Oct 4, 2006 | 06:55 PM
FlorencePS's Avatar
FlorencePS
2003 MCS w/tire leak
"Never mind." 8^)
Last edited by FlorencePS; Oct 4, 2006 at 07:00 PM. Reason: My thought not pertinent any longer.
PhoR53
May 30, 2022 10:37 PM
speedyg56
May 18, 2020 08:52 AM
woodstudio
Mar 15, 2020 08:28 AM
gmonde
Sep 8, 2015 06:37 AM
Powershift
Aug 16, 2015 05:14 PM
