upper strut brace R53 s (hood not closing properly)
Old Jan 20, 2013 | 12:39 AM
ozziekid's Avatar
ozziekid
Question upper strut brace R53 s (hood not closing properly)
hey guys just wondering attatched strut brace and closed hood but it not closing properly any suggestions. It fixed polishing alluminium bar with easy clearance over battery box. but think it will warp my bonnet
Should i cut out or mould the inside heat lining of hood hezrd of people soaking it with water or something or just wait and hope it slowly moulds into place
Ps It is ebay special but no one else had problems wiyh items.
Old Jan 20, 2013 | 06:02 AM
Braminator's Avatar
Braminator
You might want to post this in the right section to get the answers you need. You posted this in Countryman threads.
Old Jan 20, 2013 | 07:18 AM
buzzsaw's Avatar
buzzsaw
Same situation on our R53. Sprayed distilled water(they say to prevent staining) on the area to soften it up, closed the bonnet and let it sit over night. After two applications of water and bonnet closings, problem solved.
Old Jan 20, 2013 | 02:43 PM
JCWSLAYER's Avatar
JCWSLAYER
Buzzsaw method works also have seen people put chalk on bar close hood and then use a razor knife and cut the insulation away that is marked.
Old Jan 21, 2013 | 07:03 PM
astroBlackMetallic_Mini's Avatar
if its that cheap *** 40 dollar ebay thing, prepare to be disappointed. wish i had saved my $40. i dont think that pos does doodely, except lighten your pocket.
and, yes, the water thing works. hose it real good, then just rest the hood down till it molds proper.
Old Jan 21, 2013 | 07:16 PM
cm.d's Avatar
cm.d
You gotta get the R60 one, not R53.
Old Jan 22, 2013 | 08:32 AM
jonnieoh's Avatar
jonnieoh
My m7 bar made the bonnet bulge up too, so I cut away the insulation on the bottom of the bonnet with a utility knife, and it fixed the problem. I used the chalk trick to find exactly where it touched the insulation.
Some guys go the extra mile, and actually remove the insulation and cut away the area needed from the top of the insulation, where it touches the bonnet. That leaves the bottom of the insulation completely normal looking, but now dented, leaving room for the bar. That takes more time and patience, but looks much more "stock" when the bonnet is open.
Another solution is to simply remove all insulation from the bonnet altogether. It's only there for sound deadening, isn't it?
Old May 23, 2025 | 12:51 PM
MINIR52JCW's Avatar
MINIR52JCW
Hi, I bought an identical strut Brace like the genuine part and I have the problem to close the hood.
please, can you tell me a solution?
the hood is raised higher in the gap I indicate in the photo because it hits the bar from below
see the pictures attached
Old Jul 30, 2025 | 08:43 AM
Like my M7 Speed brace you have to wet the hood insulation and let the hood close for a couple days in the heat. The insulation them forms around it. If that does not work, you trim back some of the insulation.
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Toolman
Jan 20, 2016 06:50 AM
Dec 23, 2015 10:36 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
