Anyone run a tire wider than a 225?
Old Apr 4, 2012 | 12:15 PM
TrueBlueR60's Avatar
TrueBlueR60
Just purchased some VMR V718 wheels 18x8.5 in matte black and am trying to decide what size tire to run. The wheel has a 45mm offset. I know 225/45/18 will fit, but I'd really like to run a 235/40/18. Any thoughts?
Old Apr 4, 2012 | 01:48 PM
eggmole's Avatar
eggmole
Not completely sure but from what I read and Pics. It looks like the 235 might be to wide unless you get a different offset or spacers for the rims. but the 50 and 55 have been tried and have had good results but depends on the look you are going for. Good Luck and psot some pics when you get them on!
Old Apr 4, 2012 | 05:43 PM
Steve_LV's Avatar
Steve_LV
According to this website:
http://www.rimsntires.com/specs.jsp
You should be good. Assuming the factory wheel/tire combo is 18x7.5 offset 52, 225/45R18, it says that a 18x8.5 offset 45, 235/40/18 setup will be:
Suspension: 100% clear (leaves even more room than OEM)
Fenders: Package will stick out 12 mm (0.5'') farther. Acceptable for most cars.
Wheelwells: 100% clear (leaves even more room than OEM)
Your tire will be 1/2 shorter, so your speedo will be off.
Old Apr 4, 2012 | 07:17 PM
TrueBlueR60
That's a great website - thanks for the info. Still not convinced enough to pull the trigger yet. I'd really like to hear from someone who is running a 235....
Old Apr 15, 2012 | 09:38 PM
TrueBlueR60
Ok guys -- I bit the bullet and ordered my tires. Here is my setup - 18x8.5 with a 45mm offset VMR V718 wheels and 23/40/18 General Gmax AS03 tires. They fit - barely. There is about a quarter inch between the wheel/tire and the suspension components in bopth the front and rear. I'm getting my NM springs installed on Tuesday - will post pics after that.
Old Apr 18, 2012 | 06:20 PM
TrueBlueR60
Here is the before and after picture...
Old Apr 20, 2012 | 08:46 PM
frstrtdmac's Avatar
frstrtdmac
Wow looks good without the lower! Will 245 fit with spacers?
Old Apr 20, 2012 | 09:18 PM
frstrtdmac's Avatar
frstrtdmac
So wait are these pics after without the lower? Wonder what it will look like lowered?
Old Apr 22, 2012 | 11:07 AM
MotoGreg's Avatar
MotoGreg
I can't speak for TrueBlue, but it looks pretty clearly that the first photo (side view) is stock height, while the second photo (car at an angled view) is lowered.
Old Apr 30, 2012 | 07:13 AM
TrueBlueR60
Sorry for the delay in response guys....I was out of the country for a bit. The first pic is with the stock springs and the second pic is with the NM springs installed. To the post asking if a 245 would fit -- I seriously doubt it...with my set up, it's really tight. If you went with a 40mm offset wheel instead of a 45, it might work.
Old May 2, 2012 | 02:20 PM
KidLuck's Avatar
KidLuck
Just finished my 2 month long wheel/tire project. I installed a 2" lift (FinishLineWest) threw on my 20"x8.5" TSW Nurburgring wheels wrapped with 245/40/ZR20 Continental ExtremeContact DWS tires. Needed to use H&R bolt-on 30mm wheel spacers to fit the 245s. Was really hesitant about the spacers, but talked to a friend of mine who's a mechanic for Mercedes. He said the newer bolt-on type spacers are much better than the slip-on type... Really love the extra wide rally look.
Old May 2, 2012 | 02:28 PM
frstrtdmac's Avatar
frstrtdmac
need to lower that mini!
Old May 2, 2012 | 02:35 PM
KidLuck's Avatar
KidLuck
I did say i just lifted it... with the intent to raise its height. i like big wheels.
Old May 2, 2012 | 02:39 PM
frstrtdmac's Avatar
frstrtdmac
it was a joke :P
any pics of this before you raised it??
Old May 2, 2012 | 03:08 PM
youthanasia's Avatar
youthanasia
What's the offset on the TSW rims?
Old May 2, 2012 | 03:25 PM
bmwr606's Avatar
bmwr606
damn you kidluck,
now i am going to have to lift mine!
love it!
looks like you have as much ground clearance as my p/u truck
scott
Old May 2, 2012 | 04:42 PM
KidLuck's Avatar
KidLuck
frstrtdmac: sorry, spent lots of time, effort & money on this project and couldn't believe the first comment was criticizing... thanks.
before the lift shot.
youthanasia: 20"x8.5" offset+43
bmwr606: yeah, clearance is crazy now... if you do get it, think about bigger wheels or tires... after the lift, my stock wheel/tire looked cartoon tiny in the wheel well.
Old May 2, 2012 | 05:07 PM
bmwr606's Avatar
bmwr606
kidluck,
i was thinking of 225 or 235 in 70 or 75 profile on 16" rims in an AT type tire tread
http://www.tirerack.com/tires/tires....WLV2&tab=Sizes
this is the BFGoodrich All-Terrain T/A KO
scott
Old May 2, 2012 | 05:49 PM
JasonCarp's Avatar
JasonCarp
bmwr606,
I want to go to a taller tire with more AT capability too. (Mich & Wisc. similarities???) Don't want to lose much handling and performance with the taller softer (no runflats next time) sidewall tires. May go a little more normal this time and go Allseason non-rf, and plan the lift for the next set of tires.
Old May 2, 2012 | 11:14 PM
MotoGreg's Avatar
MotoGreg
KidLuck... I see that you put spacers on. I was wondering if you tried to fit the wheels/tires onto the car without the spacers, and if so, where/what exactly was rubbing. Did both the front and rear rub? Was it on the strut or something else? Did the tire sidewall rub against something, or did the edge of the rim actually come into contact with something? Thanks for any info you can provide.
Old May 3, 2012 | 01:54 AM
KidLuck's Avatar
KidLuck
bmwr606: That's a great idea. yeah, for the winter i'd like to try something like that...
motogreg: at 245 there was front and back rubbing for the front tires and the rear tires wouldn't fit onto the hub. 235s might work, but i didn't try them.
Old May 3, 2012 | 08:59 AM
frstrtdmac's Avatar
frstrtdmac
Really hard to tell peoples emotions on here. I think this looks bad ***! How does it ride after lifted??
Old May 3, 2012 | 09:25 AM
KidLuck's Avatar
KidLuck
Originally Posted by bmwr606
kidluck,
scott
Just checked those tires out... they look good, but from what i've learned, the largest overall diameter tire that will fit, regardless of lift, is around 27.7"
To get a bigger tire (overall diameter) you'll need to cut out some wheel well.
Old May 3, 2012 | 09:51 AM
KidLuck's Avatar
KidLuck
frstrtdmac: i apologize if my wording is ambiguous. Sometimes tone is tough to interpret through text. No problems here. Im good. Thanks for the complements.
It rides pretty smooth. Not as tight cornering as stock(some roll at high speeds) Breaking feels a bit top-heavy. Acceleration, i dont think, feels much different. Biggest plus is the confidence you have when hitting gravel or loose stone roads with big pot holes and debris in the way. Not a speed performance upgrade at all, but does help with the more off-road stuff.
Old May 3, 2012 | 10:12 AM
bmwr606's Avatar
bmwr606
kidluck,
27.7? that sucks, even the 215/70-16 is 28 inches
then how about this one? yokohama geolander a/t-s in 215/65-16 ... 27 inch diameter
http://www.tirerack.com/tires/tires....OATS&tab=Specs
scott
