Anyone run a tire wider than a 225?
Old May 3, 2012 | 11:52 AM
  #26
KidLuck's Avatar
KidLuck
I know... anything over 27.7 would need cut work.
That 215 geolander should work, but if ive learned anything from these forums, its to do youre own research... i ended up with 2 sets of tires that needed to be returned because i took someones word for it...
Old May 3, 2012 | 01:50 PM
  #27
frstrtdmac's Avatar
frstrtdmac
Originally Posted by KidLuck
frstrtdmac: i apologize if my wording is ambiguous. Sometimes tone is tough to interpret through text. No problems here. Im good. Thanks for the complements.
It rides pretty smooth. Not as tight cornering as stock(some roll at high speeds) Breaking feels a bit top-heavy. Acceleration, i dont think, feels much different. Biggest plus is the confidence you have when hitting gravel or loose stone roads with big pot holes and debris in the way. Not a speed performance upgrade at all, but does help with the more off-road stuff.
Gotcha! I love the look. Thinking of doing the same without raising it. I have an off road truck for going off road. But I do like the 20's with normal height!
Old May 3, 2012 | 05:34 PM
  #28
MotoGreg's Avatar
MotoGreg
Thanks for the info KidLuck. I'm looking at a 245/40/19 that has a section width (the widest part of the tire) of 9.6" which is just narrower than your tires which are 9.8" but also a full inch less diameter (26.7" vs your 27.7") - but still larger than the stock 25.9" tires.
I've recorded as many different specs from other CM owners as I could, and ran them all through the offset calculator to see what fits and where the limit is. This setup has only 2mm less clearance than the wheel/tire setup that NM Engineering sells for the CM, so I should be good. Our car gets here in two weeks so I'm going to order the wheels/tires any day now so they're be here waiting for the car.
Old May 3, 2012 | 05:57 PM
  #29
KidLuck's Avatar
KidLuck
sounds good!
throw up some pics when you get her all set up...
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
tylewis
Aug 18, 2015 06:53 AM
