Cooper (non S) Modifications specific to the MINI Cooper (R50).
backpressure
Old Aug 13, 2006 | 10:29 PM
justintime's Avatar
justintime
backpressure
I took the cat and muffler out of my MC. Weird thing is I expected that to give me more power but instead it boged it down alittle. does running catless mess up the compression in a minicooper? I've never heard of a car running better with backpressure...
Old Aug 13, 2006 | 10:38 PM
flannelhippie's Avatar
flannelhippie
Im no expert, and most likely completely wrong, but possibly, the ecu is not used to it.
Motor On's Avatar
Motor On
Get a header put the cat back on and stay close to 3" pipes is what I've heard is how to get the best backpressure. The weak link in the process on these cars is the head, which needs bigger exhaust valves, so I'm told.
BTW: no cat on the street is a $1500 EPA fine. just an FYI
Old Aug 13, 2006 | 10:40 PM
Motor On's Avatar
Motor On
Good point without a simulator the programming will bog down as the pre and post cat readings send the ECU into closed loop not open loop which will also hurt preformance good call.
Old Aug 13, 2006 | 11:19 PM
justintime's Avatar
justintime
1500? haha dang well I left the muffler hanging in the back so it looks like an exhaust. I didnt even think about the ecu..
Old Aug 14, 2006 | 04:34 AM
dominicminicoopers's Avatar
dominicminicoopers
Was it bogged down at higher RPMs at WOT? I know on the S version, the o2 isn't used while at WOT. With a lower restriction exhaust set-up like you describe, you're possible going to gain some top end, but definately going to loose bottem end torque.
Old Aug 14, 2006 | 10:06 AM
justintime's Avatar
justintime
no it was lower end rpms like from the get go that it was bogged down. High way seemed fine except in 5th gear if I used full throttle it still wouldnt go anywhere at 4,000 rpms.
and what does WOT stand for?
Old Aug 14, 2006 | 02:19 PM
xtremepsionic's Avatar
xtremepsionic
You need some backpressure to generate torque in low RMP in a NA car. It is natural that you feel a loss of power if you remove the cat.
Old Aug 14, 2006 | 02:52 PM
kurvhugr's Avatar
kurvhugr
Backpressure is a highly debated subject. I've read plenty and still don't know what to think. It's long, but if you want a look at one side of the argument spend some time with this thread.
Old Aug 14, 2006 | 04:57 PM
justintime's Avatar
justintime
I've read plenty on it myself. Im with the pro-less backpressure = power. however this is making me think differently.
Old Aug 14, 2006 | 05:14 PM
UKSUV's Avatar
UKSUV
I was always taught.....NA = you need "some" BP........Turbo applications = No BP
Old Aug 14, 2006 | 05:32 PM
justintime's Avatar
justintime
ya I never thought about that. I guess it helps turbo and superchargers from their highflow. Im tempted to put it back but I dont wanna loose the rumble >___< next paycheck ill have my money for the exhaust. but I still dont see how a high flow exhaust can help hp??
MNIPWR
Dec 26, 2012 08:32 AM
BostonR56S
Aug 17, 2010 05:18 PM
blkkouki
Aug 18, 2008 06:10 AM
mcsmike
Dec 17, 2007 06:17 PM
Minirowski
Feb 2, 2006 06:33 PM
